Old 04-07-2007, 08:17 AM   #1
razzorjet2
razzorjet2's Avatar
Replacing Bulb in AT Gearshift
Anyone know how to take the gearshift grip and trim off to replace the bulb?
the razzor man
razzorjet2 is offline   Reply With Quote
Old 04-07-2007, 11:06 AM   #2
brickhardmeat
Lonesome Cowboy
brickhardmeat's Avatar
Drives: 2007 WHITE HATCHBACK
You have to lift up the whole center console. Violin posted the instrutions somewhere ,try search box. My led is still sitting here with a pile of other stuff to slap on.
SPONSORED BY
Old 04-07-2007, 12:32 PM   #3
BokChoi
Mada Mada Dane...
BokChoi's Avatar
Drives: Toyota Yaris LB
My Car
My Garage
BokChoi is offline   Reply With Quote
Old 04-07-2007, 04:59 PM   #4
razzorjet2
razzorjet2's Avatar
Bulb
Thanks Bok-Once you get off the console box where's the bulb?
the razzor man
Old 04-07-2007, 05:12 PM   #5
BokChoi
Mada Mada Dane...
BokChoi's Avatar
actually i don't know, still haven't had time to do the mod, but these are the correct instructions, so i'm sure it will be easy to find.
My Car
My Garage
Old 04-07-2007, 05:36 PM   #6
razzorjet2
razzorjet2's Avatar
It isn't clear on the instuctions after you unsrew the gear handle if the top of the gearshift console(where the gears are marked) has to be dissassembled before you can remove the console box as per the instructions
the razzor man
Old 04-07-2007, 06:18 PM   #7
brickhardmeat
Lonesome Cowboy
I'm thinking you don't have to do all that. The thing should just lift up and the bulb is right there from what I'm told. I think this should only take a few minutes. Violin didn't make it sound like much at all.
SPONSORED BY
Old 04-07-2007, 06:35 PM   #8
BokChoi
Mada Mada Dane...
BokChoi's Avatar
my post was taken from violin's diy
My Car
My Garage
Old 04-07-2007, 06:40 PM   #9
brickhardmeat
Lonesome Cowboy
Right, I remember it and I pm'd him about this as well because he is the only person I know of who has actually put the LED in. I don't recall anything about taking the handle off of the shifter or anything. He said remove the clips, unplug any electronics, take the bolt out of the cup holder lift up and pop the bulb in.
SPONSORED BY
Old 04-07-2007, 06:43 PM   #10
brickhardmeat
Lonesome Cowboy
What I'm getting at is why would you need to take the handle off or the "gearshft console" the thing with the pr123 on it, just because the pisture shows it that way? I don't think it's necessary. Trust me this guide is not for changing that bulb but it is all that could be found and from what I have been told you do what it says and list the whole consol up. The bulb can't be too hard to find.
SPONSORED BY
Old 04-07-2007, 08:43 PM   #11
razzorjet2
razzorjet2's Avatar
Thanks Brick - My bulbs for the shifter and climate control knobs should be here next week along with 50 blue LED's for the integrated cd player. I hope I can get the face off of the thing to get at the backlight board to replace the LED's for the front display. Any info on that?
the razzor man
Old 04-07-2007, 09:17 PM   #12
brickhardmeat
Lonesome Cowboy
That part is totally easy. As someone told me you just start pulling, all that stuff will come of with your hands. Don't go crazy and break anything but you'll get a feel for it. Check the search box on this one. There is a very easy to follow DIY on the ac knobs. I did mine in a 10-15 minutes. I would suggest using a small screw driver to turn and remove the bulb that are in there now and it worked wll for me when I dropped the new ones in. Very easy install. Good place to start.
SPONSORED BY
Old 04-07-2007, 10:41 PM   #13
Violin
Violin's Avatar
Drives: 2007 Yaris LB Auto
You have to unscrew the shift knob before you lift the console off of it. The whole process takes about 7 minutes. It's EASY. You'll find the bulb on the left of the shifter.
Old 04-07-2007, 10:42 PM   #14
Violin
Violin's Avatar
Don't mess with the part where the numbers are marked - the console lifts right off of that.
Old 04-07-2007, 10:45 PM   #15
brickhardmeat
Lonesome Cowboy
I knew he would chime in. Thanks again. Maybe someday I'll actually do this. Hopefully before the damn LED get's lost in the mix.
SPONSORED BY
Old 04-08-2007, 08:22 AM   #16
razzorjet2
razzorjet2's Avatar
Thanks much Violin. (and Brick.) My Yaris is about 3 weeks old and after finding the site I realized I needed to personalize it a bit. Once the knob is unscewed and the bolt in the back of the console is out, when you go to pull the console box out are there any wire harness or clips that need to be undone? I don't wanna rip any wires out.
the razzor man
Old 04-12-2007, 05:15 PM   #17
vodkalush
I drive a yarrrris
vodkalush's Avatar
Drives: 07 Sedan Polar White
If the lb is anything like the sedan (which they are) you wont need to un/re-do any wiring, I simply untiwisted mine and twisted the new one back in its place..
will work for parts
vodkalush is offline   Reply With Quote
Old 05-27-2007, 06:58 PM   #18
redyaris
Shiny Chromey Coolness
redyaris's Avatar
Here is where youll find the auto shifter light. Posted for any noobs trying this.
Bulb Replacement Guide (led Sizes) theFEVA Cosmetic Modifications (Exterior/Interior) 113 02-28-2017 01:02 PM
Tutorial : Speaker Changing, Headlight Painting, Center Control Colour,Panel Removal hasher22 DIY / Maintenance / Service 88 03-06-2014 07:40 AM
Bulb sizes for all Yaris Models DJ_SpaRky Cosmetic Modifications (Exterior/Interior) 16 07-22-2009 11:23 PM
Accessory Bulb Types, anyone know? Ayka Cosmetic Modifications (Exterior/Interior) 135 04-29-2007 09:33 AM
bulb covers 90tsi Cosmetic Modifications (Exterior/Interior) 2 03-03-2007 02:18 AM
