37HSSV
Hubcentric Rings!?
Anyone happen to know the size for the Yaris offhand???
I have checked online, and really cant find much. I would only assume it is the same for xA/xB/Echo... Just making sure before I spend 30 bucks on a set... And, is it better to buy plastic or aluminum? wondering if it made a difference. I would only assume that aluminum would probably last longer, especially in high heat areas...plastic would degrade faster over time in areas like Florida (High heat/Humid Summers and Cold Winters)
07 Toyota Yaris Hatchback -sold- 11 Mazdaspeed 3 -SRI/TIP, 3 inch TBI, Custom FMIC, Tuned by Cobb Accessport, HKS ssq2 BOV, Upgraded HPFP- Clean stock look... Killer performance. |
Resident Scion Guy
Drives: 2008 Mazda3 S Sport Join Date: Mar 2006
Take it to a Discount Tires Store & they will try the xA/xB ones & if they don't fit, they will measure to find the right size.
Code:
DiabolicJourney_SpaRky |
Go with aluminum, they will last longer. Either way be sure to use an anti-seize when installing them.
37HSSV
Thank you sirs.... I will be making that Priority #1 this weekend.
'07 to '12:2 wipers to 1?
Drives: '12 5-door LE & '14 5-door LE Join Date: Apr 2007
lol every time I go to discount they tell me not to put antiseize on the rings...and I tell them everytime...I don't want them to seize to the hub....then I get the "yeah....ok" eye roll dealy....I should brake clean spray them then glue 'em to the hub and let them buy me another set and hubs for when they can't get them off hehe.../end rant
but yeah the ones I got @ discount were like 25 or so and they're neon purple... I had plastic on my civic for like a year and they seized and deteriorated even with antiseize....turned brittle and were PITA to get off...go with aluminum... |
![]() ![]() ![]() Drives: Yaris Hatch /Landrover D2 Join Date: Jun 2007
$30? WTF. we sell them for around $10 for all 4 in CND Dollars.
umm that's cdn so you're trying to say that we in the us could get the same ones you're talking about for like 6 bucks? are you sure you're talking about aluminum hubcentric rings? and a whole set of four?
| found some wheels... | joey1320 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 7 | 06-11-2007 11:51 AM |
