Old 07-23-2007, 11:21 PM   #1
whooppee777
I used to have 1700 posts
whooppee777's Avatar
Drives: 2008 Yaris Hatch
megan header issues
has anyone had trouble installing their megan header or and weird vibration noises afterwards? what happened to the thread that had the dyno results for the header?
Old 07-23-2007, 11:24 PM   #2
brickhardmeat
Lonesome Cowboy
brickhardmeat's Avatar
Drives: 2007 WHITE HATCHBACK
if I'm not mistakin' in chris's diy you need to re-torque them there bolts shortly there after but I ain't no certified mechanic, it could be a cat hung up in there or somethin'
pop the hood
SPONSORED BY
Old 07-23-2007, 11:54 PM   #3
whooppee777
his exact words were "retorque to specs" and i couldnt find any specs so i just tightened the bolts. theres a brace on the lower en of the header that i was unable to put back on because the stock bolt didnt fit the megan header. the wonders of aftermarket parts. i think the lack of the brace is whats making it make the vibrating noise. maybe i dunno
Old 07-24-2007, 12:38 AM   #4
Shijima
Drives: 07 HB
Personally, after seeing the thread about the 'gains' from this header I opted out of it, but If I recall someone said megan sends the wrong size bolts, and they had to get some other size.
Shijima is offline   Reply With Quote
Old 07-24-2007, 08:03 AM   #5
Chris07LB
Chris07LB's Avatar
Drives: Yaris Liftback
You should have gotten all the correct hardware for the install, if purchased from Megan. Seems all the "other" Megan sales people have been getting elsewhere, have had these issues with the hardware.
This may or not be the problem in your case, as I dont know where you got yours from.
The vibration is coming from the heat shield "shell" just above and around the collector area... take your finger and "flick" on edge of the shield, you will make the noise, and see how very flimsy it is.
Old 07-24-2007, 01:16 PM   #6
whooppee777
now i see what you're talking about. should i just take that off or what. my friend says i really dont need it. but he is retarded.
Old 07-24-2007, 08:54 PM   #7
Shijima
Drives: 07 HB
Alotof people take it off, basically its just there to say, DONT TOUCH ME IM HOT, to prevent people who dont know how hot the exhaust gets from touching it.
Old 07-24-2007, 09:56 PM   #8
Chris07LB
Chris07LB's Avatar
Thats not the part I am talking about. You are refering to the heat shield bolted to the stock header. Re-read my post, I am talking about the reflective heat shield (attached inside the tunnel) at the collector area. This keeps the floor board from transfering heat from the exhaust, into the car.
The heat shield on the stock header will not, and is not, designed to fit the Megan Header.
Old 07-24-2007, 10:14 PM   #9
my Megan header did not come with the correct bolts. Fortunately, my friend at the shop had the correct size.
Old 07-25-2007, 02:04 AM   #10
whooppee777
hells yea. high five. thats what i had to do and since we were in my friends shop we did the same thing. i'm probably going to take off that heat shield thats above the collector area. wont hurt anything i suppose.
while looking at the engine in my friends place today the shop manager said my engine was shaking too much and that it looked like my engine was miss firring. but it looked normal to me and if it was miss firring wouldnt it set a code, or wouldnt i feel or hear something as a result of it miss firring?
Old 07-25-2007, 02:51 PM   #11
It would be unusual for it to misfire, and yes, it would throw a CEL if it did it. Toyota's intelligent tester tool would be able to tell you exactly if that is the problem, so if in doubt, go to your toyota service center and ask them to check it out. My guess is, because of the low idle of the engine, it could look like it's shaking, once it's warmed up. You could always invest in a torque damper, that will keep things in place
Old 07-25-2007, 04:48 PM   #12
ROCKLAND TOYOTA
TRIM HUNTER
ROCKLAND TOYOTA's Avatar
NOR DID JERKRATT'S....
Old 07-25-2007, 06:28 PM   #13
Chris07LB
Chris07LB's Avatar
Those with hardware issues.. were did you order yours from?
I know of knowone from the original Megan GB way back when, reporting any issues. Wondering what's going on over at Megan, or whoever builds these for them. Sucks.
Old 07-26-2007, 05:48 AM   #14
Jerkratt
Jerkratt's Avatar
actually my friend was an idiot and thought the studs went somewhere else i have since gotten the studs installed still gotta find where the heat shield is being hit
"It hurts more when its wet"
Old 07-26-2007, 09:37 AM   #15
whooppee777
do you have a link to the c-one torque damper?
Old 07-26-2007, 09:40 AM   #16
Jerkratt
Jerkratt's Avatar
of course i think i posted one earlier... let me find it and update this post
EDIT: bulletproofautomotive has them... here
ask c2auto he might be able to order them also
ima go get dressed and try and find that heat shield problem.... be back later
Old 07-26-2007, 11:19 AM   #17
whooppee777
it says its for the NCP91 model yaris. would that fit our yaris'? let me know how searching for that noise works out. so i know whether or not to take off my heat collector under there.
Old 07-26-2007, 01:31 PM   #18
Jerkratt
Jerkratt's Avatar
ok so i went to the dealer today and they said its most likly the donut gasket thingy inbetween the header and the j pipe...... dam i dont got money to buy another donut/gasket.....
Megan Header Install [pics] Chris07LB Performance Modifications 132 09-29-2010 04:41 PM
Are We Still Stuck With the 4-1 Headers? Sabretooth Performance Modifications 31 02-20-2009 09:57 PM
Megan Header Advice jamal1984 Cosmetic Modifications (Exterior/Interior) 1 02-20-2007 08:22 PM
Weapon-R Header (4-2-1) CASTREX Performance Modifications 28 02-19-2007 02:57 PM
GROUP BUY - Megan Racing 4-1 Header... riceboy Items for Sale by private party 489 01-10-2007 07:45 PM
