Old 05-31-2006, 04:22 PM   #1
markpeppie
Drives: yaris 2007aero
air conditioning
have a yaris sedan aero ,,,,,,,,,is it me or does the ac work like shit??? maybe i'am just overreacting!!!
markpeppie is offline   Reply With Quote
Old 05-31-2006, 04:25 PM   #2
David81
Drives: Yaris
I hope it works good, cause i bought a yaris sedan aero also and i added ac for like 1500.
I'll know how the ac is once i get my car
David81 is offline   Reply With Quote
Old 05-31-2006, 04:26 PM   #3
stuffy
stuffy's Avatar
Drives: 06 yaris 5-dr le man
the a/c on mine doesn't feel super-cold, but i think it works fine, the one thing i am happy about is that it doesn't put a big drain on the small engine.
my old car was terrible, as soon as i turned on the a/c, the engine just bogged down.
stuffy is offline   Reply With Quote
Old 05-31-2006, 04:31 PM   #4
markpeppie
my old car was a 99 accord 2.2 L it seemed like the car would really cold, which i liked, should i have the dealer check it out???
Old 05-31-2006, 05:42 PM   #5
swng
swng's Avatar
Drives: 06 3-dr auto RS
It is nice to find out that some members are sharing their experience about the Yaris' A/C here.
I have an RS hatchback. My A/C is switched on these days most of the time. I agree it is not super strong but given time, it can cool the car down. I remember that the car's manual has suggested something like running the car with the windows open for a few minutes if the car's interior is very hot, like it has been parked under the sun. The manual has also advised to use the recirculated air instead of fresh air position of the air intake selector knob if fast cooling is desired. I would personally suggest to remember to switch back to fresh air later.
I usually turn the fan speed to at least level 3 at the first few minutes when the A/C is switched on and then turn it down to level 2 for quietness. Also, I would switch the air flow knob to the panel position. At that position, cold air is blown out from both the centre and the side vents.
Recently, I have purchased a sun shade at around Cdn $12 which I can put under the windshield after I have parked to prevent the sun from heating up the interior too much.
With all these measures, I believe I can help my car's A/C do its job without overworking itself. When it works comfortably, I save some fuel and the sun shade's cost will be compensated by the saving in fuel costs over a long time.
More information can be found in P.157-167 of the car's manual.
swng is offline   Reply With Quote
Old 05-31-2006, 09:20 PM   #6
foober
Drives: two yaris liftbacks
I've found that with the black front dash the car is continually drawing heat into it. So I bought a grayish dash mat. But it hasn't gotten here yet for me to see if that helps. But the black front dash really does seem to heat the car up and its a battle between that and the air conditioner to try and cool the car down.
foober is offline   Reply With Quote
Old 06-01-2006, 09:43 AM   #7
Ziv
It's all about VVTI
Ziv's Avatar
Drives: Yaris 5Dr LE White
Same here. I found the A/C good but not great. For sure its much better on a full side sedan (such as an accord).
I use the same method of turning it on 3 for few minutes and reduce that to 2. I found 2 is 'cooler' than 3 with time, 3 is just to get rid of all the hot air within the car. And yes, if you know you will be at your destination soon, turn off the A/C for about a few minutes and let the fan run for a bit. Without letting the fans goes on for a bit before you shut down your car, you could get a weird smell next time you start the car.
Ziv on Vitz '06.
Ziv is offline   Reply With Quote
Old 06-01-2006, 07:38 PM   #8
swng
swng's Avatar
Thanks for the advice. You are right about the funny smell. I have noticed it too. When I took my car to Toyota for service this afternoon, I complained about the A/C and they tested it. On the bill, they stated that the A/C was working fine . However, they have deodorized it for me .
Regarding running the fan for a few minutes before switching off the car, I would further suggest to run it at the highest speed and on humid days even run it with the thermostat set to the warmest. This will hopefully remove the residual moisture and prevent bad smell from building inside the system overnight.
Old 05-31-2006, 09:29 PM   #9
markpeppie
where did you order the mat? what does it look like?
Old 05-31-2006, 09:33 PM   #10
YotaYarisUSA
Drives: Yaris Sedan,Pacific Blue
Well,I think the ac is ok,I put it on 4 and it keeps me cool enough I suppose. Also, I got a sun shade to put in ,to cool the car and protect it while I'm at work or what ever.
I wouldn't say the ac was sh##,after all it is a smaller car,and its good to have an ac that is not going to hurt the engine or use up more gas.
Have a greay day and have fun with your Yaris!
YotaYarisUSA
YotaYarisUSA is offline   Reply With Quote
Old 05-31-2006, 09:39 PM   #11
foober
Here's the webpage. http://www.autobarn.net/ordasdascov.html Go down the page and go to (Click here to order a Dashmat Dashboard Cover for your vehicle). And it will walk you through how to order the mat. I tried other dash mat sites but none of them had one for a yaris as of yet. This one supposedly does.
Old 05-31-2006, 09:59 PM   #12
markpeppie
thanks great website, just ordered one!!
Old 05-31-2006, 10:36 PM   #13
swng
swng's Avatar
Please post again to report the effectiveness of the cover when you have it. I may need one too. Thanks!
Old 06-01-2006, 12:30 AM   #14
eight_heads
eight_heads's Avatar
Drives: '07 Yaris Liftback
yeah, i'd like to know as well... it's pretty hot here most of the year round in Louisiana, US
'07 Yaris Liftback
-Red 5spd w/convenience
eight_heads is offline   Reply With Quote
Old 06-01-2006, 01:21 AM   #15
swng
swng's Avatar
Just wish to emphasize that my A/C is in fact O.K. However, if something not too costly can reduce the burden of my A/C, I would like to consider it because reduced workload for the A/C will mean less fuel consumption and less maintenance. In the long run, I may even save some money. In other words, the item will pay for itself. It will take a very long time to achieve that though.
Old 06-01-2006, 09:09 AM   #16
Dylanby
Drives: RS 5-DR
Do you have your windows tinted? Even a 50% tint (50% light transmission) should cut the heat by about 40% (less while parked in the sun).
Dylanby is offline   Reply With Quote
Old 06-01-2006, 07:12 PM   #17
swng
swng's Avatar
No my friends. My windows are not tinted as yet. I agree tinting can probably keep the car cooler and improve the look. I have budgetary concerns but may consider tinting when I have spare money to spend later. I like to spend money in things that can eventually pay for themselves. The Yaris itself is one such thing because it uses a lot less fuel compared with a bigger car and its maintenance costs should be lower too.
As for tinting, I guess it will take my Yaris almost its whole life time to generate enough additional savings (through tinted windows which will reduce the fuel required to run the A/C) to pay me back the money so invested.
Still want to thank you for the great idea! I am sure that it will work and will be an added benefit to those members who will tint anyway.
Old 06-20-2006, 02:45 AM   #18
TRD_Yaris
Yarii Hunter
TRD_Yaris's Avatar
Drives: 2007 Yaris Liftback and S13's
Toyota Yaris 2007 2dr Perfect Cut Window Tint
http://cgi.ebay.com/ebaymotors/Toyot...spagenameZWD1V
just get a spray bottle, distilled water, a bit of dish soap, and a good SQUEEGEE and you have as good of tint as your skills allow
TRD_Yaris is offline   Reply With Quote
Cold Air Intake yariman Performance Modifications 21 10-03-2010 07:20 PM
Are the optional airbags worth it ? avenno2g7 General Yaris / Vitz Discussion 46 12-07-2008 02:40 AM
Cold Air hirosho General Yaris / Vitz Discussion 10 05-22-2006 10:59 PM
Cold Air Intake ? pegcityrs Performance Modifications 47 04-17-2006 07:43 AM
