Old 12-29-2025, 05:49 PM   #1
CrazyCrazy
Drives: yaris 2008 1.0 maual
Advice about adding features to old yaris
I have a 2008 yaris 1.0 manual (KSP90L-CGMRKW(1B))
Right now, the car gets unlocked by physical key and you need to turn the keyyy to start it too.
I'd like to add several features to the car:
- Remote start & shutoff, lock & unlock
- Keyless start
I'd also like to add (if possible) from anywwhere in the world through a phone app or browser:
- Remote diagnostics (like seeing speed, engine codes, sensor results etc. through OBD2 port)
- GPS
What I've found thus far:
https://www.yarisworld.com/forums/sh...ad.php?t=24860
I see several 'universal' kits on aliexpress, but I don't know if they include a sim card slot to "control" the car from afar or what the different parts do:
https://nl.aliexpress.com/item/10050...origin_prod%3A
As far as I can understand, i need to buy one of these universal kits and add a sim card / gps myself with a cheap gps/lte enabled microcontroller with which I can communicate with the mainboard of the aliexpress kit.
I don't mind having to code or solder stuff myself.
Any help or pointing me in the right direction appreciated!
CrazyCrazy is offline   Reply With Quote
Old 01-03-2026, 04:35 PM   #2
komichal
As far as I know Netherlands are active salt users during winter and your car is pretty much the same age as mine which is so rusted that in one year it will hit the scrapyard.
I would not spend unnecessary money on anything unless you took extremely good care of her and there are no severe rusting issues.
Old 01-09-2026, 06:59 PM   #3
CrazyCrazy
Thanks for the response.
You're right it's rusting, has a leak in the front airco radiator, needs a new clutch plate and new tires soon, is getting lower efficiency but as long as I can still get some (inexpensive) fun out of it why not?
Tags
diy, help wanted, keyless, remote control, remote start
2007 Black Yaris 1.3VVT-i - Advice needed Mattmcc Cosmetic Modifications (Exterior/Interior) 2 08-27-2015 02:55 AM
Some advice req for my Yaris tyrone_yaris General Yaris / Vitz Discussion 3 02-04-2012 01:20 PM
Yaris 06 T Spirit advice needed ! nocturne_sa General Yaris / Vitz Discussion 1 01-03-2010 06:24 AM
