Drives: 2012 Yaris hatchback Join Date: Mar 2026
wheel adapter
Hello fellow Yaris owners! Quick and easy question. I just received 4 brand new wheels and tires from a Honda Civic (1993 Del Sol) and want to put them on my 2012 Toyota Yaris. Anybody know where I can get adapters? Same size tires and wheels . . . the studs just don't line up on the wheels. Again, 1993 Honda wheels . . . trying to put them on my 2012 Yaris. Thanks, pfm2@lehigh.edu My username here is: Gmund1949
From Google Ai
"The Honda Civic del Sol (1993–1997) uses a 4x100mm bolt pattern (4x3.94 inches). This 4-lug configuration is standard across all del Sol trims, including the S, Si, and VTEC models. It uses M12x1.5 lug nuts, and typically requires high positive offset wheels (around +35mm to +45mm)." Since the Yaris is 4x100, I can't see why your wheels are not lining up with the studs.
| ABS, BRAKE, Harness Troubleshooting Diagnostic Guide XP90 2nd gen | IndestructibleYaris | DIY / Maintenance / Service | 0 | 09-05-2024 05:19 PM |
| Wheel bearing / Outer TRE / Control Arm replacement howto | shepd | DIY / Maintenance / Service | 3 | 09-14-2015 04:20 PM |
| Steering wheel hub adapter | spdfrk | Cosmetic Modifications (Exterior/Interior) | 7 | 02-18-2011 04:44 PM |
| Steering wheel adapter for TS | sadha | Yaris TS Talk | 4 | 07-14-2010 09:32 AM |
| forged rims Vs. alloys | red-jdm | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 14 | 07-23-2007 08:30 PM |
