Old 08-16-2007, 02:45 PM   #1
jm1681
Janghwa, Hongryeon
jm1681's Avatar
Drives: 20th AE VW GTI
Custom exhaust Q's
I did a quick search and came up with mixed opinions and tons of options. So, here goes with a few basic questions...
Pipe diameter. If one is looking to keep things simple and stay NA, what is the best choice for pipe diameter? My gut tells me 2" and apparently a couple people agree.
Resonators. If one does indeed go with 2" piping, is a resonator required to keep the noise below "legal" (And I use that term loosely as most cops simply use their own discretion) and bearable limits? I'd like to avoid it for several reasons.
Mufflers. I was looking at this muffler. My wife used this muffler on her Acura with great results in both sound and performance. Anyone have any experience with Magnaflow mufflers on their Yaris?
22B | 藤原とうふ店 | Fatal Frame | 呪怨 | 장화,홍련 | Strong Bad
How to survive a Zombie attack
"The inerasable scars, left by the palms of my hands"
365tuners
jm1681 is offline   Reply With Quote
Old 08-17-2007, 08:08 AM   #2
jm1681
Janghwa, Hongryeon
jm1681's Avatar
Anyone?
365tuners
Old 08-17-2007, 09:45 AM   #3
ChinoCharles
Drives: LB
There aren't many members here with custom exhausts, so that is probably why you're seeing a lack of responses. IMO 2" piping for an N/A setup sounds about right and Magnaflow components are always nice, so you can't go wrong.
Old 08-17-2007, 09:48 AM   #4
jm1681
Janghwa, Hongryeon
jm1681's Avatar
...2" piping for an N/A setup sounds about right and Magnaflow components are always nice, so you can't go wrong...
Cool, thanx man :)
How about ditching the resonator?
The Magnaflow doesn't allow for a silencer of any type (I don't believe in using those anyway), and while I don't want it to be excessively loud, I'd like to avoid a resonator if possible.
365tuners
Old 08-17-2007, 09:52 AM   #5
ChinoCharles
Drives: LB
I only know of one person that has gone straight through on their exhaust, and from what he told me it was LOUD. Like, uber loud. Now, myself... I don't mind it. Some do. IDK, that is your call. I'm not afraid of no cops!
Old 08-17-2007, 10:41 AM   #6
jm1681
Janghwa, Hongryeon
jm1681's Avatar
I only know of one person that has gone straight through on their exhaust...
Not sure if this is what you mean by straight through, but I wouldn't be cat-less if that makes a difference...
As long as it doesn't drone, I wouldn't really mind a good noise.
Then again, I suppose I could simply stick with the stock exhaust and replace the resonator with a 1.75"-2" straight section. Probably won't net much in terms of power, but the main reason I'm trying to get rid of/avoid using one is its usually the simplest place to knock off 15-20lbs.
Personally, I'll take weight savings over [miniscule] power gains any day of the week.
365tuners
Old 08-17-2007, 12:52 PM   #7
Galavoxx
Galavoxx's Avatar
Drives: Yaris Hatch
I have a custom magnaflo. I would recommend leaving the resonator as it is going to be way loud without it. I am running a more traditional offset inlet/outlet type muffler than the one you're thinking about. I'm not sure what model it is but it hangs down a little and I don't like the look. On top of that, the drone at highway speed is terrible. I've actually been thinking of switching to another exhaust. Before I do that though, I think I'm going to sound insulate the floor pan. It seems part of the problem with the noise is that there is no sound insulation at all, just bare metal from the rear seats all the way back. It's like a dam tin can back there and I'm sure the lack of insulation is 3/4 of the problem with the noise resonating through the car.
Galavoxx is offline   Reply With Quote
Old 08-17-2007, 02:18 PM   #8
jm1681
Janghwa, Hongryeon
jm1681's Avatar
Thanx for the info :)
I thought I was crazy for insulating the spare tire well in my old car. Glad someone else has done the same thing to deaden noise ;)
More, more :)
365tuners
Old 08-18-2007, 09:03 AM   #9
ROCKLAND TOYOTA
TRIM HUNTER
ROCKLAND TOYOTA's Avatar
More, more :)
good to see you live close to me.....
Old 08-17-2007, 03:45 PM   #10
Ran Kizama
That Anime Guy
Ran Kizama's Avatar
Drives: 5-Speed Liftback
Send a message via AIM to Ran Kizama Send a message via MSN to Ran Kizama
I'm about to put on a custom exhaust piece to connect my Megan header and Blitz axle-back. Do you think leaving off a resonator would make the exhaust raspy?
Ran Kizama is offline   Reply With Quote
Old 08-17-2007, 05:43 PM   #11
Galavoxx
Galavoxx's Avatar
Drives: Yaris Hatch
Raspy? We'll, at WOT, yes. That's usually when any exhaust sounds raspy. But at normal cruising spped,where you'll be 90% of the time, the noise is going to be obnoxious with a straight through muffler. You should really leave that resonator. It's basically like a mini muffler. If you think the resonator is going to decrease flow to the rest of your system, get an aftermarket resonater that is longer than the stock resonator. This will decrease exhaust noise when cruising even more than the stockie but will give a nice raspy note on WOT. Heck even without a Megan header and having the stock resonator, my magnaflo sounds raspy when pulling hard up a hill at WOT. For some reason that extra load on the engine makes the raspyness come out.
Old 08-17-2007, 04:12 PM   #12
slvryaris
slvryaris's Avatar
Drives: 2007 Yaris Sedan S
Here are a couple youtube videos of some different exhausts if this will help. Violin on here has tried some different ones out.
http://youtube.com/watch?v=9rFxlZHgFwY
http://youtube.com/watch?v=iROp9aPaltc
http://youtube.com/watch?v=wfZPCtp5tWg
slvryaris is offline   Reply With Quote
Old 08-17-2007, 05:51 PM   #13
Ran Kizama
That Anime Guy
Ran Kizama's Avatar
Raspy = Bad
I'd rather not sound like a poorly tuned Honda if I can help it. I'd like it a little louder tho.
Old 08-17-2007, 05:54 PM   #14
Galavoxx
Galavoxx's Avatar
Drives: Yaris Hatch
Raspy = Bad
+1
Old 08-17-2007, 10:47 PM   #15
Spades
The Hated One
Spades's Avatar
Drives: 07 White Manual Sedan
my piping is large in preperation for a supercharger that will be comming later...2" cat back for a mildly tuned N/A application is good.
I removed the resonator completely and no rasp...i am using a Borla Stainless Turbo Muffler...very deep tone, and even with my excessively large pipe i havent had HP loss (2.5" cat back).
be carefull about pulling the resonator with other exhausts...with alot of the mufflers out there sound like ass without a resonator...if i had something to capture audio clip with i would...
the tone is very deep, no rasp or "wing" sound to it, no fart or trumpet sound...best tone i could find for a 4 cyl application.
be forwarned...while they sound good, flow better, and are stainless...the borlas arent cheap...they start at over 100 bucks.
Old 08-18-2007, 01:06 AM   #16
Doug007
Doug007's Avatar
Drives: 2007 Yaris S Sedan
I have a fairly inexpensive muffler and nice looking tip (see my garage). It was just above stock in terms of sound yet was much more free flowing. I wanted to have just a bit more noise so removed the resonator and replaced with straight pipe. I really like the sound, not too loud but certainly audible without sounding ricey. With my 5 speed going through the gears, it sounds great and has a peformance tone to it.
2007 Silver Streak Mica Yaris S Sedan 5 Speed
dojo TSUKAMI Shift Nob
Brake Light Pulser
Daytime Running Lights
http://www.webelectricproducts.com/products.htm
Doug007 is offline   Reply With Quote
Old 08-19-2007, 04:03 AM   #17
dngz
dngz's Avatar
Drives: black yaris sedan
http://yarisworld.com/forums/showthr...t=dngz+exhaust
dngz is offline   Reply With Quote
Old 08-19-2007, 04:36 AM   #18
John_v63400
Drives: 2007 Yaris 4dr. S
I just put a custom Cat back System on my 2007 Yars S Sedan
2 inch piping from the resonator all the way back to the Magnaflow Mufler.
I put a Magnaflow Muffler on it. left the resanator because we tried it with out it, and it was anoying driving down the road. PLus the resanator has a good flow threw it I loked not at all bad for such a small engine. I put it back on and the
2" piping with a magnaflow sounds great!
No rasp, no fart, no crappy oval honda exaust sound, none.
And the power gain was noticable. A little but with inatake, pully and Exaust, I cant wait!!
So go 2" piping from resanator back...Thro a Magnaflow On.
You will have a great sounding car. Sounds awsome trust me. Not too loud but people look to see what kind of car it is, not cause its loud cause it sound so klean...Fukkk those rice oval exaust.
Sounds Good trust me, I love it, and driving down the freeway at 80 isnt going to give you a eadheach, thats what I didnt whant. Hope it help, bye
John_v63400 is offline   Reply With Quote
How much has your custom exhaust cost you? whooppee777 Performance Modifications 7 07-21-2007 11:20 AM
Custom exhaust.... forpinks Performance Modifications 3 03-31-2007 07:43 AM
GReddy prototype = Free Exhaust! Chris_Lum California 30 02-27-2007 10:13 PM
Fujitsubo Exhaust!! MC-BPT Sponsors Classifieds Area 17 11-16-2006 10:36 AM
Custom Exhaust dngz Performance Modifications 17 10-28-2006 09:12 PM
