Old 08-20-2007, 09:15 PM   #1
nqd
Drives: 07 Yaris LB Absolute RED
something wrong with my brakes?
tonight i was driving with the radio off for once.....and i noticed when i brake it makes a weird noise....like there is some on the brake disc...every time it hits the spot it makes like a paper against paper rubbing sound
should i take it to the dealer?
This is my first new car so i got a few q's
if so, I'm guessing its better to put OEM wheels on huh...
problem is dealer has already seen my car with rims and suspension...
can i got to another toyota dealership?
v
nqd is offline   Reply With Quote
Old 08-20-2007, 09:20 PM   #2
cdmyaris
cdmyaris's Avatar
Drives: 07 Yaris Liftback
i asked my dealer about aftermarket on suspension and rim. He said its okay if they are causing problem then its voided. That what i was told.
Toyota Yaris FTFW!!
cdmyaris is offline   Reply With Quote
Old 08-20-2007, 09:27 PM   #3
brickhardmeat
Lonesome Cowboy
brickhardmeat's Avatar
Drives: 2007 WHITE HATCHBACK
I'm trying to imagine what that sounds like
is there a vibration feeling, is this during hard or fast braking or just normal stopping?
SPONSORED BY
Old 08-21-2007, 01:37 AM   #4
yes, unless the dealer can exactly pin-point the problem to the modification with some diagnostic tests, then it is illegal for them to void any warranty.
http://www.ftc.gov/bcp/conline/pubs/.../warranty.shtm
some of you guys may like that.
Old 08-20-2007, 09:35 PM   #5
nqd
only hard braking
v
Old 08-20-2007, 10:16 PM   #6
brickhardmeat
Lonesome Cowboy
hmmm, well I wouldn't be too concerned but I'm not sure exactly what is going on, they may try to tell you it is your tires or something
this is up front I would assume
SPONSORED BY
Old 08-20-2007, 10:42 PM   #7
churp
Clean and (dis)Functional
churp's Avatar
Drives: Yaris 2dr--Black Betty
Very easy to tell if the rims rub the caliper....take the wheel off and anywhere there is contact will show on the wheel and the caliper. If there is, take a grinder or file to the spot on the caliper (not the wheel) and barely remove some material...doesn't take much. Sort of doubt that this is the problem with newer aftermarket wheels though.
____________
Old School Cobble Jockey
churp is offline   Reply With Quote
Old 08-20-2007, 11:04 PM   #8
Masteraal
Masteraal's Avatar
Drives: Black Yaris YRS 3dr Manual
its not worn brake pads right?
Masteraal is offline   Reply With Quote
Old 08-21-2007, 01:00 AM   #9
ddongbap
I kinda doubt suspension and rims would cause any braking issues. You shouldn't let it go without a fight, if the dealer tries to blame it on the suspension and brakes. Unless they say that the rim was rubbing on the caliper, or the suspension exploded, taking the inner half of the caliper, or something like that. Not that that's what happened.
Old 08-21-2007, 01:50 AM   #10
reznunt
Hi!
reznunt's Avatar
Drives: EF Sedan
pull off your wheels, inspect the rotors and pads for unusual wear or foreign objects. if you can see what's causing the sound, that's a good thing because it can be easily fixed! good luck.
reznunt is offline   Reply With Quote
Old 08-21-2007, 02:48 AM   #11
slvryaris
slvryaris's Avatar
Drives: 2007 Yaris Sedan S
I had a piece of corn stalk caught in mine once. Its scared the piss out of me. Ya like the others said just pull the wheel off and inspect. It might be nothing at all.
slvryaris is offline   Reply With Quote
Old 08-21-2007, 03:11 AM   #12
seanele
seanele's Avatar
Drives: '07 Blazing Blue LB, '09 Jetta
best solution, buy another Yaris.....jk man!!
current: '07 Yaris LB - '09 VW Jetta
ex: '06 Beetle S(19x8.5 Audi A8) - MK4 GLi BMP(18x8 OZ, K04) - '03 GTi(17x7.5 Ronal, APR93) - '01 GLS - '88 GTi - '86 GTi - '83 GTi
seanele is offline   Reply With Quote
Old 08-24-2007, 09:47 PM   #13
brickhardmeat
Lonesome Cowboy
driving yaris through corn field not recommended
SPONSORED BY
Old 08-24-2007, 08:42 PM   #14
is it maybe the dust sheild on the back of the rotor rubbing on something when you brake?
Brakes Geelmeel General Yaris / Vitz Discussion 16 06-29-2007 07:58 PM
Will this work or I got the wrong harness? TDL In Car Entertainment + Electronics (audio / video / alarm) 2 04-19-2007 02:26 PM
Brakes and Shocks question jamal1984 DIY / Maintenance / Service 6 03-18-2007 04:26 PM
Brakes question MeggiemobileSFLA DIY / Maintenance / Service 23 03-16-2007 05:17 PM
Changing drum brakes to discs? eTiMaGo Performance Modifications 5 09-25-2006 04:17 PM
