Green is good
Did anyone installed apexi SAFC ??
I have a SAFC 2 but still pending to install
because I can't find the wiring diagram for my NCP91 also failed to get it at the apexi official web. anyone can help me ?? thank you |
You could search for the diagram for the old Yaris TS(Europe).
I am pretty sure you have the same engine!
#3 | |
Green is good
but I found the ECU location, socket and wires are different. anyway, i will try for it, thanks |
The ECU location is in the hood isn't it?
The old one had it in front of the passenger's seat.
![]() ![]() ![]() ![]() Drives: Sc'd Yaris Sedan. Join Date: May 2007
I hate to bring back an old thread, but how did it work out.
I have an safc 2 laying around and thought why not hook it up. I can't find a wiring diagram for mine. But just curious how yours worked out. :)
Tantum religio potuit suadere malorum. |
![]() ![]() ![]() Drives: 07 Join Date: May 2007
The SAFC comes with a install booklet and ECU pinouts in it. I'm pretty sure there was a 1nzfe pinout.
It doesn't go past 02.
Edit: Okay, I found the Vitz 1nz-fe. This will be the same for the Yaris? I realize it's the same engine and all but still, It is a different car.
You can test the wires. TPS should be 0-5v, and increase in voltage when throttle is applied. 12V is easy to test, and so is ground. Try it :)
?? I don't know what that means. :) I'm not good with electrical stuff. I prolly shouldn't be doing this.
At least you admit it. I recommend taking it somewhere if you cant solder anyway, DO NOT use crimp connectors!!!
Oh? It came with them.
Anyway, I just took off my ECU, which was a chore in itself, and I don't know what the hell I'm doing. I don't know of anyone around here who does that kind of stuff either. If anyone has any better installation pics than what Apexi gives with the SAFC-II I would greatly appreciate it. I'm off to see if my car will start or if I broke something.
Where are you located?
South Central PA.
Pay me a lil bit and I will do it for you, I'm in the pocono area.
Really? Hmm. sending pm :)
Any news?
Yeah. I gave up. It's way too complicated for something that would yield gains too small. Unless I find some really good diy pics I'm done. :(
Τοο bad.I thought that the wiring diagrams were easy to find.
| PICS OF TRD INTAKE INSTALLED! | elsteverino889 | Performance Modifications | 9 | 03-03-2007 04:12 PM |
| Anyone tried to appy Apexi SAFC or anything similar on their YARIIIII?? | oscarying | Performance Modifications | 25 | 10-21-2006 09:42 PM |
| Tanabe Concept G Exhaust Installed | Toddhata | Performance Modifications | 65 | 10-06-2006 06:19 PM |
| Tanabe NF210's installed...got a question though | Terrorize | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 32 | 09-29-2006 07:45 AM |
| installed head unit... | punch | In Car Entertainment + Electronics (audio / video / alarm) | 16 | 06-29-2006 12:06 AM |
