Old 09-09-2007, 12:53 AM   #1
Nexus1155
Bathroom + Laptop = <3
Drives: Audi
Converting Yaris from DBW to DBC?
Does anyone have a clue on how to convert the yaris from the Drive by wire system to Drive by Cable... I know I would need a new throttle body that isn't electronic and a new pedal and whatnot, but i think thats about it. Has anyone else looked more into this subject? Thanks for the input!
Old 09-09-2007, 02:37 AM   #2
well mechanically that's all that would be needed, yeah, but you'll also need to look into the electronic side of things, the ECU will still be looking for the throttle position signal, and will probably go nuts when it can't get it.
The simplest solution, I guess, is to keep the original electric throttle somewhere, still connected, but just not doing anything...
Old 09-09-2007, 10:23 AM   #3
Tapper
Tapper's Avatar
Drives: 2008 Black RS 2dr
Yeah, a little trickey eh.
Tapper is offline   Reply With Quote
Old 09-09-2007, 10:51 AM   #4
Nexus1155
Drives: Audi
yeah, just so the sensor is tricked that it is there, but just not active... I was trying to make a ITB kit for the car, but i keep scratching my head when all the throttle bodies are cable driven...
even the ones Danstoy uses are cable driven so there must be something different here..but I have no clue, it completely stumped me..and im not going to be an ass and ask Danstoy all his secrets hahah, I need to figure out SOME things
Old 09-09-2007, 11:10 AM   #5
Nexus1155
Drives: Audi
What i also found on a Lexus board where they were trying to convert was
Hell, if you want to get rid of DBW on the stock TB... just unplug the throttle control motor, open up your accelerator pedal position sensor assembly, rotate a few degrees to give the cable connection full control over the butterfly, and call it a day.
but this conflicts with it
I did this with my altezza's TB but what i found was that since my throttle lever and TPS are one unit i had to rotate the TPS sensor as well. With the TPS rotated the bolt holes didnt line up again so that was problem # 1. Problem #2 was that the throttle cable was too long when i did this. With the Altezza the DBW controls idle and is active throughout the complete throttle range. The manual cable only turns the butterfly at about 60% throttle and opens it till about 75% throttle.
Old 09-09-2007, 11:16 AM   #6
Well you could do something real clever and use the DBW's motor to turn a lever that pulls on the ITB throttle cable, that could do the job too without having to change pedals or anything. Of course, you'd still have the characteristics/disadvantages of a DBW throttle.
Old 09-09-2007, 11:22 AM   #7
Nexus1155
Drives: Audi
Yeah, that is true, i don't really care for the Yarii system of DBW its like eh... too jumpy for me, but its my girls car... but hmm...maybe cap off the cable lever on the ITBs and link the wires up ? might work a little more fab than i expected but thats ok..
Old 09-09-2007, 12:47 PM   #8
largeorangefont
Break'em off some.
largeorangefont's Avatar
Drives: 07 Yaris LB, 04 Cobra
Wait for reflashing ability. Converting it to cable is not worth the hassle.
The DBW gain and pedal travel to TB blade travel are fully adjustable.
Old 09-09-2007, 02:03 PM   #9
Nexus1155
Drives: Audi
I can flash the ECU, how is that going to help me lol...aghhhh im stuckkk
Old 09-10-2007, 11:38 PM   #10
largeorangefont
Break'em off some.
You can adjust the DBW response in the factory ECU
Old 09-09-2007, 03:02 PM   #11
caveatipse
Drives: 2007 Black Yaris
Could someone explain the difference to me between DBW and DBC? Thanks!
caveatipse is offline   Reply With Quote
Old 09-09-2007, 03:10 PM   #12
Nexus1155
Drives: Audi
drive by wire is electronic while drive by cable is cable driven... look at an older car, you can grab the cable and tug on it and it will rev the engine...
Old 09-10-2007, 07:43 PM   #13
Black Yaris
der Zeck
Black Yaris's Avatar
try to PM Teruyume, he did an xB retro fit of a supercharger... pretty sure he swapped his car over to DBC to accomidate the xB throttlebody... just a though
Old 09-10-2007, 08:36 PM   #14
Nexus1155
Drives: Audi
thanks for the info! will do
Old 09-11-2007, 03:33 AM   #15
Masteraal
Masteraal's Avatar
Drives: Black Yaris YRS 3dr Manual
how? i just got my car the other day and it shits me how the first 5mm on the pedal doesnt actually do anything.but i guess ill just get used to it
Masteraal is offline   Reply With Quote
Old 09-11-2007, 12:14 PM   #16
Nexus1155
Drives: Audi
you need to be able to reflash the ECU, and thanks for the idea, I just didn't think the TPS on the pedal kicked in in those first 5mm, but if its adjustable from the ecu that would be alot easier, and I figured out a way to wire another throttle body and tap into the existing tps and just trick the ecu...
Old 09-13-2007, 05:32 AM   #17
rx100
Drives: yaris hatch
maybe this will help..
http://www.autops.co.uk/html/sprint_booster.html
rx100 is offline   Reply With Quote
Old 09-13-2007, 01:04 PM   #18
Nexus1155
Drives: Audi
it just looks like it would be a few resistors in there... like they just upped the gain is all, I'll take a look around see if i can find a DIY, do it and post up pics....
Tree 1 - Yaris 0 gabagooo General Yaris / Vitz Discussion 19 04-25-2007 05:24 PM
