Old 09-18-2007, 01:51 AM   #1
Thirty-Nine
Small cars are a big deal
Thirty-Nine's Avatar
Suspension install: Spring Compressors?
Every suspension install I've ever done I've had to use spring compressors -- except my xB. The front springs just popped off, unlike most springs, they weren't under a lot of tension.
Do you need to use spring compressors for the Yaris front suspension?
I assume the rears are like the xB, where you simply unbolt the rear struts and "wiggle" the rear springs off their perches?
Old 09-18-2007, 02:09 AM   #2
Slummy
Slummy's Avatar
Drives: Black LB
when i did the springs on my car, the rears came out easily, the fronts...they didnt seem to be under too much load but i'm glad i had compressors.
Slummy is offline   Reply With Quote
Old 09-18-2007, 02:16 AM   #3
Thirty-Nine
I'll probably use them just in case, then. Better safe than sorry, eh?
Old 09-18-2007, 03:08 AM   #4
Nexus1155
Bathroom + Laptop = <3
Drives: Audi
*Ahhhhhhh My Eye!!!!!*
Old 09-18-2007, 03:48 AM   #5
slvryaris
slvryaris's Avatar
Drives: 2007 Yaris Sedan S
Ya I used compressors when I did mine. Heck just go to Auto Zone and get some. I think they do the rent a tool with springs compressors just pay a deposit and then bring it back and get your money refunded.
slvryaris is offline   Reply With Quote
Old 09-18-2007, 04:26 AM   #6
didn't use one when we installed my set up.
Old 09-18-2007, 12:42 PM   #7
Thirty-Nine
I assume the fronts weren't under a lot of tension (like the way my xB was)? Literally, I undid the nut on the top and they just kinda popped and that was it. Same with the Yaris?
Old 09-18-2007, 12:47 PM   #8
PetersRedYaris
PetersRedYaris's Avatar
Drives: 2005 Scion xB
You'll need spring compressors to remove the front springs from the strut but not to install the new springs into the strut, at least not with Tanabe springs. I suppose you could remove the front springs without a compressor but be careful, a spring under load can be a dangerous thing.
Just rent them from an Autozone or Checker Auto. You get all your money back if you return them in 2 days. Free rental...
PetersRedYaris is offline   Reply With Quote
Old 09-18-2007, 03:24 PM   #9
Thirty-Nine
Well, I'm installing coilovers, so I don't need to take the springs off the struts. However, I believethe Megans requre you to use some parts from the OE shocks.
I've rented spring compressors many times; they're just a PITA!
Old 09-18-2007, 03:29 PM   #10
largeorangefont
Break'em off some.
largeorangefont's Avatar
Drives: 07 Yaris LB, 04 Cobra
You do not need spring compressors to remove the stock springs, or install lowering springs. There is little to no tension on them, they pop about 3 inches. The coilovers probably require you to use the top hat on the front struts, so the front springs need to be removed from the struts.
Old 09-18-2007, 03:32 PM   #11
yeah, pretty much. but to be on the safe side, we faced the top down and twisted from the bottom (facing up).
Old 09-18-2007, 04:25 PM   #12
Thirty-Nine
Gotcha -- thanks, guys.
Old 09-18-2007, 04:28 PM   #13
nqd
Drives: 07 Yaris LB Absolute RED
I thought it was the other way, and you put youur face directly over it!
v
nqd is offline   Reply With Quote
Old 09-18-2007, 11:39 PM   #14
yup, and make sure your eye is 1 cm away from it too.
Old 09-18-2007, 11:55 PM   #15
Nexus1155
Drives: Audi
better yet just stick your eye to the bolt, and twist from the bottom
Old 09-18-2007, 11:59 PM   #16
Black Yaris
der Zeck
Black Yaris's Avatar
or just do what I did and cut a bunch of coils off your stock springs.... then them bitches will come right off when you want to put new coils on :)
I am still holding off for coilovers
TANABE DF210 Spring Install [pics] Chris07LB DIY / Maintenance / Service 148 07-16-2007 10:26 PM
n00b suspension install question The Stig DIY / Maintenance / Service 25 07-12-2007 09:58 AM
Tanabe NF210 spring install help Jerkratt Performance Modifications 8 06-08-2007 11:13 AM
NorCal: Suspension install The Stig California 12 06-05-2007 01:51 AM
Spring Install Price redglare45 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 1 06-30-2006 09:32 PM
