![]() Drives: Yaris HB Join Date: Oct 2006
Dimly Lighted Battery Indicator Light
Okay, I got a 07 Toyota Yaris with 135,000miles. I just replaced the alternator two days ago. The alternator has been making whining noise nonstop for the last two months, so finally I found the whining noise coming from the alternator bearing. I had replaced the belt last month prior to replacing the alternator. So today, after about 250miles with the remanufactured duralast alternator, the battery indicator light stayed on, but the light is very dim. I have seen a brighter light when the original toytoa alternator was in the car. (The INFAMOUS voltage regulator issue). I tested the battery when the car is running, it's at 13.85V. The belt looked good, nice and tight. I am mystified why this little bugger is giving me such a headache lately. Any suggestions what to do next? Thank you
sorry, just to clarify, you're referring to the charge indicator light on the dash?
What's your battery reading with the car off after it's been sitting for a couple of hours? If it's 13.8-13.9V at idle (750-800 RPM) then that's in the acceptable range. Try testing the output at 2000 rpm or higher. Should be around 14.4 ish V. |
![]() ![]() Drives: 2008 5 Speed Sedan Join Date: Jan 2011
is there a MIL code that needs to be cleared ? check the contacts to make sure they're clean and free from corrosion. battery could be bad because of the bad alternator or possibly the belt is too tight? As Bluevitz said check the voltages and let us know. the battery should sit slightly above 12V when the car is off. also when checking voltages, turn off your radio, lights ac etc. to get a proper reading.
Someone else PMed me a while back with the same issue after installing an aftermarket alternator. I wonder if the aftermarket alternators do not properly feed the charging signal on the light blue wire to the cluster.
okay, the battery reading with the car off is 12.68V. While it is idling, it's at 13.85-14.0V. When I revved it up, the reading briefly jumped to 14.15-14.3V, then dropped to 14.0V. I have cleaned all the contacts, and I applied the battery anti-corrosion disc on each terminal. The charge indicator light went out after the rain shower we had yesterday for about 150miles, but it came back and stay lighted dimly for another 50 miles with no rain. So if CTScott is correct, then it's just another annoyance I have to live with till I sell the car. Boy, I am not too impress with toyota quality. I didn't expect a Denso alternator to go back after 120K miles. On the other hand, it has been trouble free for 4.5 years and the gas saving is great. Thanks all for your help :)
#6 | |
sorry scottCT, I don't know where is the connector with the sky blue wire? Can you show me a pic and tell me how I would measure the voltage? Thanks
#8 | |
| Electrical System Upgrade Advice | sqcomp | In Car Entertainment + Electronics (audio / video / alarm) | 6 | 03-23-2016 01:15 AM |
| DIY: Braille Battery install | texkid | DIY / Maintenance / Service | 39 | 02-19-2013 02:40 PM |
| Charging voltage for stock battery | Vinceb | DIY / Maintenance / Service | 3 | 02-12-2011 12:10 AM |
| Fog lamps as back up low beams. | ellenbetty | General Yaris / Vitz Discussion | 114 | 10-22-2009 03:40 PM |
| Installation of a Battery Isolator | frostbitten | In Car Entertainment + Electronics (audio / video / alarm) | 3 | 10-07-2009 12:11 PM |
