Old 01-28-2009, 03:56 AM   #1
NonStopTuning
NST Now Offers Braille's Full Line
TAKE A LOOK: http://www.nonstoptuning.com/BRAILLE...Batteries.html
EIGHT REASONS TO CHOOSE BRAILLE:
1. Excellence
Great all around performance for small displacement motors. Using AGM racing technology, Braille Batteries have the highest PCA and CCA, more than any other battery in each weight class.
2. No Spill, No Corrosion, No Maintenance
Technically registered as a "sealed valve regulated" design, this patented technology completely eliminates acid spills and corrosion on terminals. This design is environmentally safe does not need filling and maintenance. Air shipping approved.
3. Exclusive Dual Terminal Design
A Braille Battery exclusive! This feature allows the battery to be mounted in a variety of positions. It is designed to accept racing, powersports and automotive terminals vertically and horizontally.
4. Stainless Steel Terminals
Stop loose battery connections with our robust stainless steel threads. These heli-coil design threads allow higher bolt torque and help keep your battery connected even in high vibration environments.
5. ExclusiveBrass Auto Terminals
Included with every Braille Auto Battery are patent pending high quality brass SAE terminals. Designed to distribute the electrical load into and out of the battery. Designed for high amperage, high stress use of racing and audio competitions.
6. Green from Start to Finish
We employ a manufacturing process with the highest concern for the environment and quality. Recycled lead, plastic and stainless steel ensure we'll have a future to race towards.
7. Solid Top Lead Connectors
Shaken, not stirred - From 6 "G" NHRA drag launches, to 4 G cornering loads in Indy this design holds the internals firmly in place.
8. Performance Certified - Fully Charged
Every Braille Battery is individually tested and certified before shipping, eliminating DOA batteries. Fully charged and ready to install at time of shipping.
YOUR SEARCH FOR THE BEST BATTERY ENDS AT NonStopTuning
Please feel free to contact us directly to enquire about the best battery for your application. We would be more than happy to chat with any of our valued customers.
EXCELLENT THIRD PARTY ARTICLE ON LIGHTWEIGHT BATTERIES
http://www.hondatuningmagazine.com/t...ion/index.html
MIKE @ NST
www.NonStopTuning.com
Old 01-28-2009, 04:54 PM   #2
NonStopTuning
For those who may be interested in dropping more than 20lbs from their front end...
I would recommend the 11.5lb Braille, Item Number B14115 or B14115C (carbon fiber.)
This is an awesome battery with the most PCA and CCA for any battery in this weight class.
Please note: Braille batteries can be mounted with universal Jhook tie downs. Custom mounting kits and boxes, like the one shown above, are sold separately.
We have access to the FULL line of Braille products. If you want something that we do not list on our website, please grab the model number from the Braille website and give us a call at 281-917-0221.
Thanks again everyone!
MIKE @ NST
Old 01-28-2009, 06:10 PM   #3
Black Yaris
der Zeck
Black Yaris's Avatar
cheeper and lighter than an optima
Old 01-28-2009, 07:36 PM   #4
RagnaCaT
HacKers WanTed!
RagnaCaT's Avatar
Drives: Yaris S HB & Yaris S SD
Hey mike what are the Dimensions on that battery B14115
R-CaT
Project Yar 2ZR
RagnaCaT is offline   Reply With Quote
Old 01-29-2009, 12:28 AM   #5
NonStopTuning
B14115
11.5lbs/5kg
904 Pulse Cranking Amps
15 Amp/Hr Reserve
5.8” x 3.4” x 5.8”
Left Side Positive
MIKE @ NST
Old 01-29-2009, 04:14 PM   #6
RagnaCaT
HacKers WanTed!
RagnaCaT's Avatar
Originally Posted by NonStopTuning View Post
B14115
11.5lbs/5kg
15 Amp/Hr Reserve
5.8” x 3.4” x 5.8”
Left Side Positive
And how much are those nice battery holders?
R-CaT
Project Yar 2ZR
Old 01-29-2009, 06:59 PM   #7
NonStopTuning
We'll be adding those holders (sold separately) to our site within the next couple days. In the meantime, you can get info, pricing, and model numbers for those holders from the Braille site and get in touch with us.
The Batteries can be installed with standard J-hook tie downs, which is what most people have been using to put these batteries in their cars.
Thanks again!
MIKE @ NST
Old 02-04-2009, 08:16 PM   #8
NonStopTuning
Our first shipment of 11 and 15lb batteries came in today. I knew they would be small, but I must admit I was blown away by how small they actually are in person.
They definitely look to be of very high quality and I love the fact that each battery comes with its own tech card, showing size, specs, date on which the battery was manufactured, and CA test results. Each battery also comes with a full one year warranty.
Most of the batteries we received in our first shipment are already spoken for, so I have placed an order for a second shipment, scheduled to arrive Friday.
I would recommend the 11lb to most customers not running extra lighting or stereo components. If you have much of the latter, then you may want to consider stepping up to the 15lb or larger.
MIKE @ NST
Old 10-21-2009, 12:22 AM   #9
advocate
Drives: car
Fog lights and HIDs wouldn't fall into the category of 'extra lighting' if the car came with normal halogens and no fogs right?
Old 10-21-2009, 02:19 AM   #10
NonStopTuning
If your OEM battery is doing OK now in your daily driven car, then the 11lb would be a great fit.
The 15lb would provide you with some excellent weight reduction as well, and would provide that much more peace of mind.
Either option would be a great fit for the Yaris.
MIKE @ NST
Old 10-22-2009, 11:17 PM   #11
NonStopTuning
MIKE @ NST
Old 02-05-2009, 06:26 PM   #12
Jerkratt
Jerkratt's Avatar
ok i have one of the billit battery tie downs from the group buy a while ago (www.microimageonline.com) sells them aswell... would these batterys fit.. or should i say will the tie down still work?
"It hurts more when its wet"
Old 02-05-2009, 11:02 PM   #13
NonStopTuning
No, a battery tie down designed for the OEM battery will not fit the much smaller Braille. You can however, purchase aluminum mount kits designed specifically for the Braille, and we are working on our own NST versions as well!
MIKE @ NST
Old 02-05-2009, 11:11 PM   #14
NonStopTuning
Here are a few comparison pictures...
We tested an 11lb Braille in a Yaris today.
I will post a few pics here. More to come soon...
OEM Toyota Yaris battery pictured here
OEM Toyota Yaris battery vs Braille 11lb battery
OEM Toyota Yaris battery vs Braille 11lb battery vs Red Bull can
Braille 11lb Carbon Fiber in the OEM battery location
More pics to come soon
MIKE @ NST
Old 02-06-2009, 12:51 AM   #15
Jerkratt
Jerkratt's Avatar
...wow i wanna see what that would look like with the custom tray and hold down... ill deff be down.. with tax returns coming in soon
Old 02-06-2009, 08:13 AM   #16
Klink10
Klink10's Avatar
I would be down with that also. My problem is I like the location on the stock battery where the rod used to hold the hood is affixed. I would like to see a kit keeping that fitting in the same location or will have to come up with something on my own.
Old 02-06-2009, 08:49 PM   #17
Jerkratt
Jerkratt's Avatar
i lost that when i put the billit bat tie down.. so i take it out and install it when needed... i keep it in one of those slits behind the front seats lol
Old 02-06-2009, 11:37 AM   #18
Nagoya_TRD.
Drives: None.
+ 1 for braille, i used to have this in my old car, and loved it.
Nagoya_TRD. is offline   Reply With Quote
NST NonStopTuning Pulley Kits NonStopTuning NonStopTuning 19 11-08-2014 10:23 PM
NST (NonStopTuning) Short Shift Kit Info, Specs, User Data... NonStopTuning Performance Modifications 195 12-23-2011 12:44 AM
