what up foo
Drives: '07 blk LB Join Date: Oct 2008
LED ignition light
I was gonna hook it up yesterday using the DIY but then...you know
can anyone who installed it tell me where the red wire goes? the black is just a ground right? |
Depends on when you want it to come on,
most people wire it into the courtesy light above your head . So when you unlock your car it turns on . |
- Donnie Demonic -
Drives: '07 Yaris Sedan Sport Join Date: Oct 2006
Whenever I do mine I am tapping into the parking light relay. I figure the most useful time to have it on is when its dark out.
Hey everyone.... I'll take a couple of pics on the wiring of the ignition light and post it for ya'll. I won't have pics of the physical install of the light around the ignition switch with the steering column cracked open but I'll give you some notes about it.
As for the wiring, I'll show pics of how mine is wired. It comes on when the doors are opened along with the dome light. Mine also "times out" with the dome light after the door is shut. I'll take these pics sometime today or tomorrow. I hope it will help. Later... Bikegerm ... yet to be re-established.. |
#5 | |
Tiny Giant Clothing
Drives: 2008 Blazing Blue Yaris 3D LB Join Date: Oct 2008
Sold the yaris... rocking an 89 vw cabriolet now :) |
![]() ![]() Drives: 2007 5 Door Hatch Join Date: Jun 2007
Do these come in amber as I do want to get this but do not want to change the led?
- Donnie Demonic -
Its the pink wire Tiny Giant |
Stoln they come in blue and white, I only got blue this time.
From the picture above I can tell you how to wire your ignition light. Pull the dome light connector Donnie has pointed to. It's a 6 pin connector. You need to splice your black ground wire to the pink wire which is off of pin 2, and splice your red power cable to the blue wire which is off of pin 5.
When it is wired here, your ignition light will come on when you open your car door. It will then shut off with the dome light when it times out or when you start your car. When you shut your car off, the ignition light comes on, then times off with the dome light. This is where I wired mine. As for the physical installation of the light. It's preety easy. Just remove the two phillips head screws behind the steering wheel. There's one on the left and one on the right. You'll need to spin the steering wheel to get to each screw. Pop the plastic covers loose. I dremmeled the opening around the ignition switch slightly on both the bottom and top covers. This helped the fit once the plastic light is placed around the ignition switch. I also put a small black shroud around my light so it would reduce the bleed of the light inside the column, through the side column seams. I hope this helped. Sorry I don't have any pictures. I installed mine two weeks ago based on a previous DIY. |
HacKers WanTed!
Drives: Yaris S HB & Yaris S SD Join Date: Aug 2007
The poison in your poison
Drives: 2008 Black Liftback MT Join Date: Oct 2008
Top Notch!
I wanna see this completed. Post pics when your done.
Tiny Giant Clothing
what is the power supplied at the dome light circuit ?
Hey Tiny. Do you mean in volts? When I opened the door I think it was around 12 volts. I guess I could measure it again. My memory sucks !! This install was 2 weeks ago. Here's a couple of pics. You'll see by the close up, I still need to "trim" my light leakage.
Tiny Giant Clothing
yeah in volts.. didnt know if it ran on 12 or if it was brought down a little
Germ.....having never done or seen this....are those pins you refer to numbered so that you can see the the numbering or are you going off a diagram?
And I remember it being a little under 12 volts. Here's a pin out of the connector.
http://www.etimago.com/yaris/repairmanual/Lighting.pdf / Page LI-19 . Connector 4K |
Top Notch!
Looks kickass!
| Bulb Replacement Guide (led Sizes) | theFEVA | Cosmetic Modifications (Exterior/Interior) | 113 | 02-28-2017 12:02 PM |
| LED Tag Light? | Kaeon | Cosmetic Modifications (Exterior/Interior) | 10 | 08-09-2010 01:42 AM |
| LED tail light question | Julz | Cosmetic Modifications (Exterior/Interior) | 4 | 06-19-2009 09:25 AM |
