Old 10-21-2008, 08:23 PM   #1
joelitton
joelitton's Avatar
Drives: 2008 Yaris Liftback
Send a message via AIM to joelitton Send a message via Yahoo to joelitton
Rear wiper: EZ mod so it pulls back all the way
Yet another of the posts that was lost with the site hack ...This is a real quick fix that will allow the rear LB wiper to pull back the way a wiper should so you can clean the window.
There's a plastic cover at the base of the rear wiper. It's an inch or two long. You can remove that cover by just pulling it off ...or with your fingers spread the sides of the cover outward a little and then remove it. If you then flip the cover over, you'll see this little tab:
Using your fingers or a needle nosed pliars, pry that little tab back and forth a few times and it'll pull or twist/pull off:
The cover will snap back in place at the base of the rear wiper arm, and NOW the wiper can be pulled back when you want to wash the window. I did this many months ago and have had no problems at all. The wiper works just fine. I have no idea why Toyota put that tab there.
Here's the rear wiper with the cover back in place after the tab was removed:
OK, it's not a fancy mod - shouldn't really even be called a mod, since it's not like adding a turbo or something. But it does make washing the car a helluva lot easier :)
2008 Blazing Blue LB. 5-spd MT, Power Package, side airbags, antilock brakes, rear spoiler, bumper guard, splashguards, power locks/ alarm. Added: Tanabe front strut tower bar, Beatrush aluminum underpanel, NST short shift kit, NST crank pulley, WeatherTech side window deflectors, Wheelskins steering wheel cover and shift boot, dual loud FIAMM horns, 30% tint all around, wheel locks. Yet to install: NST alt and WP pulleys. More to come :)
joelitton is offline   Reply With Quote
Old 10-21-2008, 08:25 PM   #2
slothman86
slothman86's Avatar
Drives: 07 Yaris Liftback
Good info! I was really wondering why I couldn't pull it back all the way...
Old 10-21-2008, 08:57 PM   #3
joelitton
joelitton's Avatar
Originally Posted by kurokoma-kun View Post
clever trick joe litton!
hope you will also repost pics of your aluminum underpanel, it's a beaut... didn't you enter the engine contest also?
OK, just posted the underpanel pics:
http://www.yarisworld.com/forums/sho...935#post151935
I'll find the pics of the cylinder head cover and post 'em.
LOL ...I should be working right now, but it's too much fun hanging out here again ...been way too busy for far too long!
Old 10-22-2008, 05:53 AM   #4
ddongbap
Why'd Toyota do that in the first place?
Old 10-22-2008, 05:56 AM   #5
DFA
Compulsive Washer
DFA's Avatar
Drives: 08' AT Meteorite Metallic LB
Send a message via MSN to DFA
Some crazy American regulation/feature. My Panamanian Yaris doesn't have it.
DFA is offline   Reply With Quote
Old 10-22-2008, 06:13 AM   #6
PHXDEMON
PHXDEMON's Avatar
Drives: 2007 Red Liftback
Cool easy little mod Just did it to mine and took under a minute.
Old 10-22-2008, 10:25 AM   #7
TheRealEnth
Beast
TheRealEnth's Avatar
Drives: 2007 Blz Blu LB
Someone said on the last post that it was to keep it from blowing back and possibly snapping off due to high pressures of.. lets say a carwash or something. I don't know, whatever MORE POWER TO YW
Its a Chao!!!
Old 10-22-2008, 10:25 AM   #8
Sodium Duck
╚══════════RN
Sodium Duck's Avatar
Drives: 2008 Liftback
It has to do with carwashes. Something about it being able to recoil back, blah blah blah.
From a post in the Yaris secrets thread:
we have that stupid dealy called the drive-thru car-wash...I think it was finally factualized that the nub is to keep the wiper arm from lifting off the glass far enough to recoil.
Old 10-22-2008, 10:30 AM   #9
TheRealEnth
Beast
Yeah, we went over this on many threads... CARWASH IS THE DEVIL!!!!
Its a Chao!!!
Removing rear wiper fred812 Cosmetic Modifications (Exterior/Interior) 34 01-27-2013 12:22 AM
Rear wiper function, is this normal? Yaris Dick General Yaris / Vitz Discussion 7 11-08-2006 09:46 AM
Slight mod to rear NickNickNick Cosmetic Modifications (Exterior/Interior) 4 05-11-2006 01:03 AM
