Old 10-25-2008, 01:44 AM   #1
phenoyz
phenoyz's Avatar
Drives: yaris
yaris sedan bolt pattern
hello
what is the BOLT PATTERN ofr a 2008 YARIS SEDAN BASE MODEL?
i am planning to get a 16x7 rims
thanks
phenoyz is offline   Reply With Quote
Old 10-25-2008, 02:17 AM   #2
Shroomster
'07 to '12:2 wipers to 1?
Shroomster's Avatar
4x100
also find out whether you will need hub-centric rings as well.
Old 10-25-2008, 08:45 AM   #3
kimona
kimona's Avatar
Drives: 2014 White VITZ
Like the shroomster posts, bolt pattern is 4x100. 16x7 works very well on the Yaris. You have 3 tyre size choices depending on wheel offset and whether you lower the car or not: 195/50/16; 205/50/16; 205/45/16.
Old 10-25-2008, 12:45 PM   #4
03Z33
03Z33's Avatar
Drives: TCR10
hub bore id is 54.1mm
03Z33 is offline   Reply With Quote
Old 10-25-2008, 01:19 PM   #5
as noted, 16 x 7 (+42mm) with 205/50/16 works really well:
Yaris Bolt Pattern miniboon Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 06-17-2007 10:29 PM
Yaris Sedan Vs. Yaris 4dr. hatch Meow General Yaris / Vitz Discussion 11 10-29-2006 03:11 PM
yaris sedan remote trunk relase question pls help soon fantabulousbaby New YARIS Purchase Forum 4 08-05-2006 02:26 AM
