Old 11-02-2008, 03:37 PM   #1
kurokoma-kun
Drives: 2007 Yaris HB
front stabilizer link and bar questions
Old 11-02-2008, 04:51 PM   #2
m911gt
Carless in Chicago
m911gt's Avatar
Drives: 08 Blk LB
I am no expert but I would think it'd be best to tighten the nut while unloaded, as I'm assuming was the case at the factory. If you really want to, you could jack it up, loosen the nut and retighten it.
Wanted: Forced Induction
Old 11-02-2008, 06:44 PM   #3
whoguy
Drives: Yaris YRS Sedan
I reckon it should be tightened loaded..... but not too tight as it will wear the rubber bush prematurely.
whoguy is offline   Reply With Quote
Old 11-02-2008, 07:41 PM   #4
rob323
Don't drive it, RALLY it!
Drives: 1999 echo PRC rally car
If both front wheels are at the same height from the guard (ie. fully jacked up off the ground, or sitting on level ground), then there is no load on a sway bar, or it's links so it won't matter either way .
rob323 is offline   Reply With Quote
Old 11-02-2008, 08:07 PM   #5
largeorangefont
Break'em off some.
largeorangefont's Avatar
Drives: 07 Yaris LB, 04 Cobra
It is actually loaded when you jack the car up from that corner. It is unloaded with both front tires on the ground, or both front wheels in the air.
It is fine to tighten that endlink bolt to spec loaded or unloaded.
Don't worry about it.
Progress 22mm Rear Sway Bar PRE-ORDER SPECIAL 03Z33 Items for Sale by private party 85 04-13-2007 12:48 PM
ultra racing front strut bar installed smurf Performance Modifications 9 03-10-2007 06:58 PM
