![]() Drives: 2007 Yaris Sedan Join Date: Sep 2007
"Klunk!" One Time Noise When Backing Up
Hi everyone, this is my first post. I got my 07 red Yaris sedan last week. It has A/T
Every time (I even noticed that at the dealership) I start the engine and start to back up from my driveway, I always hear that one-time "klunk" noise (for a lack of better description). It only happens once after the engine is started, and it wont happen again until the next time I start the car again. My first guess is something to do with the transmission???
My auto. doesn't do it...
![]() ![]() ![]() Drives: 07 Yaris Liftback Join Date: Jul 2007
if it happens again and again. Take it to dealership or Transmission shop.
Toyota Yaris FTFW!! |
![]() Drives: Yaris Hatchback LE Join Date: Jul 2007
I can confirm this, I own a 07 Hatchback LE Auto, and I can hear this "klunk" noise you described here, it's very faint, if you don't pay attention to it it's hardly noticeable. I hear it almost everytime when I back out of my driveway, I only hears it once, and won't hear it again for the rest of the drive. I think it also happens when I go forward too.
I took it to the dealer once, but couldn't replicate the problem to the technician. I have figured out now if I shut off the engine and wait a while, then restart the engine and move the car, it will produce that "klunk" sound. Well at least now I know it's not just my car, though I really hope this is not a serious issue. |
Your Toyota Technician
if its a click/light clunk its your brake pads/shims shifting...most toyota's do it
MORDSITH
Drives: 2007 Yaris Hatchback Join Date: Apr 2006
there seems to be such a clunk when i throw my car into reverse (manual transmition) after starting it.
ive not worried about it though, figured it might be nothing or not that unusal. it ONLY happens when going into reverse after starting the car.
2007 Yaris Hatchback 5 Door LE, Manual, Package B, Bayou Blue Metallic |
#7 | |
![]() ![]() ![]() Drives: 2007 Yaris Liftback Join Date: Oct 2008
B
Visualize whirled peas. Peace, Love and Good Smoke! --Tommy Chong
![]() ![]() ![]() ![]() Drives: 2007 Yaris Sedan "D" package Join Date: May 2006
well for the auto matics, its from parking on any slite slope, any surface thats not level, and not using your emergency brake to hold the car, but relying on the tranny to hold the car...
out of respect for nutzoid, I changed my avatar.
#9 | |
I'm interested to find out more about why brake pads/shims shifting can cause this "klunk" sound. |
#10 | |
because they can shift, theres enough space to make a bit of noise. i have used brake lube on the shims and inserts on highlanders, corolla's, tc's, camry's, avalons, rav4's...and so on from this complaint. |
Spool'd
Drives: 07 yaris, 16 gen coupe rspec Join Date: Aug 2007
Our Saturn used to do that too. It is the brake pads, don't worry about the noise at all. The brake pads have to move inside the caliper, otherwise how would the brakes work. Sometimes there is just more room for play, but the pads will never come out or fall out of place in any way. You're perfectly fine.
![]() Drives: 2008 Yaris sedan 5 speed Join Date: Mar 2007
[QUOTE=Toyotech;146150]because they can shift, theres enough space to make a bit of noise. i have used brake lube on the shims and inserts on highlanders, corolla's, tc's, camry's, avalons, rav4's...and so on from this complaint.[/QUOTE
Would the brake lube be included on a brake cleaning/adjustment at the dealer? |
#13 | |
'07 to '12:2 wipers to 1?
Drives: '12 5-door LE & '14 5-door LE Join Date: Apr 2007
but thats just me talking from 'flat rate' experience |
#14 |
![]() ![]() ![]() Drives: 2008 Yaris sedan A/T Join Date: Oct 2008
shifting calipers back and forth.
#15 |
Tiny Giant Clothing
Drives: 2008 Blazing Blue Yaris 3D LB Join Date: Oct 2008
mine doesnt clunk but i get a little vibration when backing up tiny bit.. not much
Sold the yaris... rocking an 89 vw cabriolet now :) |
#16 |
Joey
Drives: '14 Scion xD 5-speed Join Date: Oct 2008
Are you holding the brake all the way down before you shift?
Formerly owned Met-Met. '07 Yaris LB 5-speed. A forum post should be like a skirt: Long enough to cover the subject but short enough to keep things interesting. "I don't have an anger problem. I have an idiot problem." -Hank Hill |
#17 | |
'09 5dr
Drives: 2009 Yaris 5-Door Bayou Blue Join Date: Oct 2008
I tried putting the gear into N or R for a few seconds before putting into R also, and even tried putting into P and turn off the engine for a few hours too.
2009 5-Door Yaris LB Bayou Blue Pearl 2009 5-Door Yaris LB Black Sand Pearl |
#18 |
I seem to recall a post about the ABS resetting causing such a noise.
2007 Silver Streak Mica Yaris S Sedan 5 Speed dojo TSUKAMI Shift Nob Brake Light Pulser Daytime Running Lights http://www.webelectricproducts.com/products.htm |
| noise while backing up | jonr0613 | General Yaris / Vitz Discussion | 31 | 09-08-2007 06:23 AM |
| Air Conditioner Noise | Cathy | General Yaris / Vitz Discussion | 16 | 05-08-2007 02:08 AM |
| 2007 LB Auto-Trans NOISE in Reverse | Pavel Olavich | General Yaris / Vitz Discussion | 4 | 03-22-2007 07:42 PM |
| long time lurker, first time poster | tekmoe | New YARIS Purchase Forum | 1 | 10-04-2006 12:43 AM |
