Old 12-25-2008, 07:27 PM   #1
06vitzRS
Drives: 06 Yaris HB
Brake fluid info...
Some people are talking about using racing fluid (DOT5) in their brake systems. I would not and this is why:
There are 3 ratings, DOT3, DOT4, DOT5. 3&4 are glycol based and 5 is silicone based. Glycol based fluids are hygroscopic, which means they can absorb moisture. Silicone based is not. Any moisture in the system will collect in the lowest points of the system. The moisture winds up in the wheel cylinders and calipers. DOT 5 should not be used in ABS systems because the water can collect in the valves of the ABS system, corroding them and rendering them inoperative. Dot 5 is also more prone to trapping air in the fluid, especially when agitated, as happens in an ABS hydrolic controller or pump.
If you are going to use DOT5, at least change it often. DOT4 is good enough and way less to worry about.
4th year apprentice mechanic.
06vitzRS is offline   Reply With Quote
Old 12-25-2008, 07:56 PM   #2
Klink10
Klink10's Avatar
Very good point(s) made there. While in the process of putting my re-built powdercoated calipers on I plan on flushing the system with ATE brand Dot 4 fluid. Most reading I did in arriving at the decision to use ATE indicated that DOT 5 is used primarily in racing applications where the fluid is changed often.
Old 12-25-2008, 09:24 PM   #3
Loren
What?
Loren's Avatar
Drives: 2007 Yaris LB
Not all racing brake fluid is DOT5. Good high-temp DOT4 is available.
Regardless of what type you use, if you're using it on a track, the system should be bled (which will purge whatever is in the calipers) before each track day and flushed at least annually. In other words... DOT5 wouldn't be bad if the system is properly maintained.
That said, I use high-temp DOT4. Usually ATE, it's a good "bang for your buck" fluid considering temp vs. cost.
Old 12-25-2008, 10:28 PM   #4
+1 - that's what I use also.
Old 12-25-2008, 11:28 PM   #5
auxmike
auxmike's Avatar
Does'nt putting DOT5 silicone into a DOT3 factory fill system mess up the seals though?
Old 12-26-2008, 12:05 AM   #6
YarisSedan
Drives: 08 Yaris Sedan
I used valvoline synthetic high performance dot 4 fluid.
DIY INSTALL/REVIEW: Dezod X-Rated Yaris Brake Pads ChinoCharles DIY / Maintenance / Service 40 10-13-2017 05:23 PM
BIG(GER)TM BRAKE KIT Vanderkitten Performance Modifications 23 01-04-2009 07:16 PM
Engine dress up - brake fluid resivoire cap? YarisSedan Cosmetic Modifications (Exterior/Interior) 5 11-15-2008 07:59 AM
big brake kit turboyaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 04-13-2007 01:44 PM
Maintenance - Change Auto Trans Fluid Linkseal DIY / Maintenance / Service 1 08-15-2006 10:57 PM
