yaris universe fog light help
ok if anyoen has installed the fogs from yaris universe i ahve a question. i will be running supplied switch with the factory relay. if i run the fogs to pin 1. put the relay in. Then do i just connect the ground and two switch wires to the stearing column? and if so which colors go to which pin? is that all i have to do in cabin or do i ahve to splice the wire at the auto shifter as well? only 3 wires on the switch from this kit. if you can help that would be great sorry its early in the morning and im half asleep typing this.
#2 | |
ill try and get a picture up. there were no directions.
| replacement fog light switch? | yrsdrgn | Cosmetic Modifications (Exterior/Interior) | 4 | 07-17-2007 04:11 PM |
| Finally installed oem ebay fog light for hatchback | Adriaan | General Yaris / Vitz Discussion | 6 | 12-27-2006 04:24 PM |
