Old 01-06-2009, 05:43 AM   #1
andru47
andru47's Avatar
Drives: 2009 Yaris 3DR LB
Send a message via AIM to andru47
Adding DRL
What would I need in order to get DRLs working on my Yari? I have tried the parking lights thing but it dims my dash way too much. Any suggestions? Can I just buy the relay module and is it an easy install? Or is there complex wiring involved?
Thanks!
My Yaris: The Azure
andru47 is offline   Reply With Quote
Old 01-06-2009, 06:41 AM   #2
pinoypizzaboy
Drives: 08 toyota yaris LB
I think its just plug and play with the relay.
pinoypizzaboy is offline   Reply With Quote
Old 01-06-2009, 05:30 PM   #3
andru47
andru47's Avatar
So where can I obtain this relay? Is anyone who removed the DRLs willing to give it to me? I'll pay shipping, or if someone is in the Orlando area that would be great.
Thanks!
My Yaris: The Azure
Old 01-06-2009, 05:34 PM   #4
can't you adjust how your display looks when your parking lights are on? i can turn mine on to look as bright as they do when my lights arent on....
Old 01-06-2009, 05:39 PM   #5
andru47
andru47's Avatar
I have the little dial all the way up and since I do live in the Sunshine State the illumination is just not enough like I have to force my eyes to see it clearly.
My Yaris: The Azure
Old 01-06-2009, 05:39 PM   #6
doesnt it click past that though...? mine does....
Old 01-06-2009, 05:41 PM   #7
andru47
andru47's Avatar
Hmm will check BRB
My Yaris: The Azure
Old 01-06-2009, 05:46 PM   #8
andru47
andru47's Avatar
You are a genius!!!!
Thanks yeah never would have thought to click it further.
Ok that is a problem solved.
So The DRLs would be parking or normal beams?
My Yaris: The Azure
Old 01-06-2009, 05:49 PM   #9
lol...easier than installing DRL's
drl's come on as low beams, but they dont run at full intensity....so theyre dimmer
why do you want drl's so bad anyways?
Old 01-06-2009, 06:08 PM   #10
andru47
andru47's Avatar
Yeah much easier.
As for reason, my godfather wanted me to have them for safety I guess?
Thanks again!
My Yaris: The Azure
Old 01-06-2009, 06:13 PM   #11
Yeah much easier.
Thanks again!
imo, drl's are over rated.
as long as you turn on your headlights when its foggy/rainy/snowy or at dusk/dawn, youll be ok
drl's dont give you tail lights either
just need common sense, not drls
(btw, that common sense thing isnt a dig on you....but lots of ppl out here think they have drl's so theyre ok....but i cant tell you how many time people SHOULD have their lights on in the fog and dark out here and dont because they can see because of the drl's being on...its sick
/rant)
Old 01-06-2009, 06:17 PM   #12
andru47
andru47's Avatar
Well I am extra safe then cause I don't have real DRLs. Instead I'll have my low beams on and will build a habit to always turn them on. :)
My Yaris: The Azure
Old 01-06-2009, 06:18 PM   #13
Doug007
Doug007's Avatar
Drives: 2007 Yaris S Sedan
Thanks!
Try this website:
http://www.webelectricproducts.com/
I put them on my Yaris and like the look. I believe I have a pic in my garage section with them activated.
2007 Silver Streak Mica Yaris S Sedan 5 Speed
dojo TSUKAMI Shift Nob
Brake Light Pulser
Daytime Running Lights
http://www.webelectricproducts.com/products.htm
Doug007 is offline   Reply With Quote
Old 01-08-2009, 02:29 AM   #14
Jerkratt
Jerkratt's Avatar
i have 2 drl relay boxes.. o took them out of my 07 and my 08
"It hurts more when its wet"
Old 01-08-2009, 03:01 PM   #15
andru47
andru47's Avatar
Problem already solved thanks everyone!
My Yaris: The Azure
Old 01-30-2009, 06:28 PM   #16
RagnaCaT
HacKers WanTed!
RagnaCaT's Avatar
Drives: Yaris S HB & Yaris S SD
LoL a CLICK past the DIMMER!
R-CaT
Project Yar 2ZR
RagnaCaT is offline   Reply With Quote
DRL Questions. AznGouki Cosmetic Modifications (Exterior/Interior) 14 10-28-2008 03:07 PM
DRL disalbled. IllusionX DIY / Maintenance / Service 0 10-22-2008 03:16 PM
Using parking light as DRL? GabL DIY / Maintenance / Service 6 11-11-2006 09:31 AM
adding DRL's..?? static808 DIY / Maintenance / Service 9 10-20-2006 04:15 AM
NO DRL ???? argylesocks DIY / Maintenance / Service 8 08-12-2006 08:24 PM
