Old 01-29-2009, 05:44 AM   #1
CtrlAltDefeat
I ♥ Yaris
CtrlAltDefeat's Avatar
Question Are camber bolts needed after installing springs?
I'm about to install some Tanabe DF210 springs and was told that I'll need an alignment after the springs settle (after a couple weeks) because the lowered stance will give you bad camber and your tires will wear unevenly and wear out fast. Are camber bolts needed to fix the camber problem? A friend of mine said something would need "slotting" to fix it. If I don't get camber bolts, will the "slotting" be expensive? Anybody know?
what to look out for when installing lowering springs songa Performance Modifications 34 09-15-2012 03:29 AM
Adjustable Camber Bolts cali yaris Micro Image 30 12-11-2009 09:38 AM
URGENT help needed :( -DIY springs Masteraal DIY / Maintenance / Service 19 12-23-2008 03:23 AM
Who makes camber bolts? largeorangefont Wheels, Tires and Suspension Forum sponsored by The Tire Rack 21 07-08-2007 12:22 AM
Is it practical to install stiffer shocks without also installing lowering springs? St_G Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 01-18-2007 01:23 PM
