Old 08-31-2006, 01:11 PM   #1
Lizardboy
Mmmmm, twisties!
Lizardboy's Avatar
Drives: 07 Red Yaris S & 95 Miata
Air Horns
Has anyone installed air horns in an 07 sedan? If so, where did you locate them in the engine bay and where is the factory horn located? Also, what length of horns has anyone installed? If anyone else is interested in this, here are two sites that sell a variety of them.
Inexpensive, lower end:
http://www.wolo-mfg.com/
Expensive, higher end:
www.hornblasters.com
BTW, check out some of the videos on hornblasters. Pretty funny stuff.
Don Neudecker
Ad Compositor Extrodinaire
"The instructions are inside the box." - My I.T. Dept.
Lizardboy is offline   Reply With Quote
Old 08-31-2006, 01:28 PM   #2
argylesocks
Bears eat beets.
argylesocks's Avatar
Drives: Yaris LB
im thinking of getting one, just so i can say "hornblaster" on a regular basis.
Free veggie starter kit!
argylesocks is offline   Reply With Quote
Old 08-31-2006, 07:41 PM   #3
Boo
Boo's Avatar
Drives: PW Yaris LB AT
For LB, the horn is behind the grille and in front of the radiator. I think the sedan will be in the same location.
Boo is offline   Reply With Quote
Old 08-31-2006, 10:25 PM   #4
Lizardboy
Mmmmm, twisties!
Lizardboy's Avatar
Awesome! Thanks! That was my guess. I just didnt' get a chance to check it this morning before I left for work. Hopefully, there will be enough room for some 12 inch horns in there. :)
Don Neudecker
Old 09-01-2006, 09:07 AM   #5
SmellyTofu
好多人&
Drives: .
You need the bumper off to get access to the horn but there isn't much room if you are thinking of anything too thick. My horns just clear the grill area.
SmellyTofu is offline   Reply With Quote
Old 09-01-2006, 09:41 AM   #6
Chris07LB
Chris07LB's Avatar
Drives: Yaris Liftback
Dont forget the air tank, compressor, valve, pressure switch and interior gauge and switch you will still need to mount... thats if your still talking about the Train Horns.
Old 09-01-2006, 10:45 AM   #7
Lizardboy
Mmmmm, twisties!
Lizardboy's Avatar
The horn I was considering has two trumpets which are roughly 12" long. Think they might fit there? I was considering mounting them somewhere between the engine and the firewall.
Don Neudecker
Old 09-01-2006, 10:49 AM   #8
Lizardboy
Mmmmm, twisties!
Lizardboy's Avatar
Oh no. I'm not planning on a train horn. I would love to, but all the space lost and weight gained doesn't make it sound too attractive. I'm just thinking of a cheap, twin trumpet setup with a little compressor. The trumpets are roughly 12" long. It's the Model 417 Long Horn made by Wolo, http://www.wolo-mfg.com/air.htm. Has anyone tried any of the Wolo horns.
Don Neudecker
Old 09-01-2006, 11:29 AM   #9
Violin
Violin's Avatar
Drives: 2007 Yaris LB Auto
There's a good bit of space behind the liftback nose. I don't know about the sedan.
I'm putting these in: http://www.autosupermart.com/store/shop/piaa85112.html
Old 09-01-2006, 12:35 PM   #10
Chris07LB
Chris07LB's Avatar
When are you ordering? Id like to install the same, if you want to get together one weekend.
Old 09-01-2006, 01:09 PM   #11
Violin
Violin's Avatar
I ordered them already - they shipped the other day and I hope to have them today. I'm planning on installing them this weekend along with my head unit.
But yes, we should get together sometime - perhaps do a dual cruise control install.
Old 09-01-2006, 02:07 PM   #12
Lizardboy
Mmmmm, twisties!
Lizardboy's Avatar
So, would you agree with SmellyToFu that the bumber needs to come off to access that space?
Don Neudecker
Old 09-01-2006, 02:18 PM   #13
Violin
Violin's Avatar
On the liftback - yes.
It comes off pretty easily - hasher did a pretty good how-to that showed how to get the bumper off: http://www.yarisworld.com/forums/showthread.php?t=1525
Old 09-01-2006, 03:06 PM   #14
Lizardboy
Mmmmm, twisties!
Lizardboy's Avatar
Wow, that does sound pretty easy. Thanks!
Don Neudecker
Old 09-01-2006, 04:46 PM   #15
SmellyTofu
好多人&
Drives: .
Yes it's easy.. just a pain in the @$$ to do it. :)
It's hard to show it but here's my horns.. there's not a lot of clearance (maybe a finger thick) between the bellow part of the horn and the grill.
Old 09-02-2006, 12:16 PM   #16
Violin
Violin's Avatar
stock horn:
connector:
directions:
There is already a hole here (right side horn), I just had to trim the plastic to get to it:
(I took the right headlight off to get at an existing ground to chasis bolt and ran the ground wire with the existing harness.)
finished:
Sounds great! Much louder than the stock *meep* and a nice two tone note.
PIAA also makes a 400 and 500 Hz set. I chose the higher pair because I think the lower note would confuse other drivers. They'd be looking for a bigger car or truck.
Old 09-02-2006, 04:05 PM   #17
Boo
Boo's Avatar
Nice.. is the PIAA sports horn have more bass? I am thinking to replace the stock one.. since it sounds so thin.
Old 09-02-2006, 04:08 PM   #18
Violin
Violin's Avatar
Much more noticeable sound.
I've done this with every car I've had since an 18 wheeler changed lanes into my Miata at 75 mph and didn't hear my little horn until he nearly ran me over.
Cold Air Intake yariman Performance Modifications 21 10-03-2010 07:20 PM
1.3 Ltr Yaris Air Filter mods aucorium Performance Modifications 9 08-18-2006 08:32 AM
Air selection intake broken? David81 General Yaris / Vitz Discussion 16 06-29-2006 02:51 PM
Cold Air hirosho General Yaris / Vitz Discussion 10 05-22-2006 10:59 PM
Cold Air Intake ? pegcityrs Performance Modifications 47 04-17-2006 07:43 AM
