Startin small.
Drives: 2007 Yaris S Join Date: Apr 2009
Intake HP Increases
So I've been lookin around here and on some vendor sites (Mostly Micro Image) for intakes. First off, is an AFE or AEM better? Secondly, what is the approximate increase in HP and MPG (if applicable) for each type?
Well, the AFE would require less work to clean the filter since the filter sits in the engine bay, whereas the AEM goes down behind the foglight, and to clean it would require removal of the front bumper, or removal of the front wheel and fender liner to access the filter. Both are essentially CAI (the AFE has a heat shield, and the AEM is a true CAI). HP gains by itself will probably be negligible, and FE will be affected depending on how you drive. If you drive lightly, it should increase your mpg (I know it did on my GTI), but if you push harder to hear it suck in air, then you'll eat up more gas.
Startin small.
So the TRD site says their CAI would increase about 11.2 at 6000+ rpm... is that actually negligible? I'm looking to boost some HP a bit while making sure that any increase in sound is as throaty as possible so as to be distinguishable from a ricer with stupid fart pipes. Actually, on the subject of exhaust... what's the best way to go with that? Do I need headers, or a midrange (as I know the Yaris' is restricted), or is it just a rear piece/muffler. I've never even looked at my exhaust to be honest! But I like the nice throaty sound with some HP increase. Advice?
#4 | |
As for the exhaust, go with custom cat-back. It'll be cheaper. Go with either Magnaflow or Flowmaster if you want a throaty sound. I have a Magna on my sedan, and I had a Flowmaster on my GTI. |
No intake is going to net you 10 hp, I don't care what the claims are. But, every little bit helps with our cars and they do add up.
I prefer the AFE right now, it's easier to take care of, makes the same amount of power (in my opinion), costs less and sounds great.
Also, the AFE is aesthetically more pleasing imo since it doesn't leave a huge gap in the engine bay. hehehe. But that's just me.
+1
on the AFE intake , got one and love it ,if you get one you won't regret it
#8 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: '08 Bayou Blue LB AT Join Date: Oct 2008
I like the gap so that I can cram in the oil catch can. I took the metal heat shield off the aFe setup to make more room. Pictures this weekend.
aFe Intake | Blitz Supercharger | Megan Header | TRD Exhaust | NST Pulley Set TRD Shocks/Struts | Tanabe NF210 Springs | TRD Sway Bar | Motegi TRAKLITE wheels | Kuhmo Ecsta XS R1 Concepts slotted rotors | Carbotech 1521 brake pads | stainless steel brake lines | Seibon vented carbon fiber hood Last edited by LtNoogie; 05-06-2009 at 06:19 PM. |
![]() ![]() ![]() ![]() Drives: 2008 yaris, stripped, red Join Date: Jan 2009
once i finally installed mine properly i had no problems with my afe. i got about 3 mpg out of it and if anything i driver harder than i used to....but i get to speed and stay there.
any way, it comes with 2 really thick nylon washers....ur supposed to put those in the rubber holes for factory box and then put some bolts through into the heat shield. when locked down it doesnt rattle like it used to at all. that's the only prob i had. |
ebay ftw
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '08 Yaris Join Date: Oct 2008
![]() ![]() ![]() Drives: yaris Join Date: Oct 2008
AEM ftw. Just to be diffrent.
![]() ![]() btw the TRD intake is an AEM intake, just has a TRD badge on it.
ballin on a budget. |
#14 |
Modded Moderator
Drives: 07 Toyota Yaris, 71 Galaxie Join Date: Mar 2007
I love my AEM, and with my foglight cover mod it reduced the intake temperature by 10 degrees.
#15 |
![]() ![]() ![]() ![]() ![]() Drives: 2007 Yaris HB Join Date: Apr 2007
I also have the AEM, works great, love the sound it makes
![]() Ah, Astroman! I coulda sworn someone did this but could not remember who or find a pic! I just sold my foglights and will be making the same type vent soon--did you back yours with any kind of mesh? did you use a dremel or utility knife? |
#16 |
ooh, we need a carbon fiber version of that.
#17 |
Startin small.
Yeah I definitely didn't believe the claim of "up to 11 HP increase"... just a bit of BS... Where's the best place to get the Magnaflow? Also, with the exhaust, do you need to get headers? Or just the tail end? Again, haha I don't know how the whole exhaust goes together.
#18 |
Startin small.
Oh and another question about the intakes. With the CAI, is the temperature decrease negligible because of the distance of the tubing that the engine could warm the intake pipe which would then make the difference about the same as the short ram? I saw one thread where the owner wrapped the CAI tube in insulating tape and he said it helped. Sorry for all the questions! I'm just really torn between the two! Also, with the CAI, is there really that much of an increase of danger for hydrolock?
| DIY: Intake Installation | redyaris | DIY / Maintenance / Service | 53 | 08-23-2014 05:34 AM |
| MY new PRM Intake... | marcus | Performance Modifications | 27 | 05-03-2009 11:04 PM |
| Bomz Ebay Intake - Partial Review | Split | Performance Modifications | 11 | 11-19-2008 02:12 AM |
| Intake Systems Decision Maker.. | Blenjar | Performance Modifications | 25 | 09-15-2007 10:07 PM |
| WR Secret Weapon Intake Dyno Tested.. | WRLEO | Performance Modifications | 70 | 05-17-2007 03:00 PM |
