Old 04-11-2009, 07:49 PM   #1
ka0sx
ka0sx's Avatar
Drives: bone f*ing stock
whats the caliber of my rifle?
5 points if you can guess the caliber of my new rifle, 500 points if you can guess what rifle =P
ka0sx is offline   Reply With Quote
Old 04-11-2009, 07:55 PM   #2
ka0sx
ka0sx's Avatar
.303 British
Lee-Enfield
close >,<
Old 04-11-2009, 08:01 PM   #3
ka0sx
ka0sx's Avatar
.308
Winchester or Remington
still nope ><
Old 04-11-2009, 08:05 PM   #4
Gideon
★weeaboo★
Gideon's Avatar
Drives: 2008 Bayou LB
.223?
AR type rifle of some kind?
Old 04-11-2009, 08:06 PM   #5
NJBob
NJBob's Avatar
Drives: 2008 Yaris Liftback
5.63mm AK
Old 04-11-2009, 08:09 PM   #6
ka0sx
ka0sx's Avatar
kekeke this is fun! PK is getting very close
Old 04-11-2009, 08:15 PM   #7
ka0sx
ka0sx's Avatar
well im running out of ideas. is it a .300 Winchester?
.300 winmag
Old 04-12-2009, 03:10 PM   #8
GeneW
Drives: 2008 Yaris
Originally Posted by ka0sx View Post
.300 winmag
Damn! Should have noticed the short (less than one caliber) length neck on the case.
Gene
Old 04-11-2009, 08:20 PM   #9
ka0sx
ka0sx's Avatar
actually I bought the Winchester SXR(autoloader)
Old 04-12-2009, 03:11 PM   #10
GeneW
Drives: 2008 Yaris
Somebody makes a self loader for belted magnum cases? That's a new one.
Gene
Old 04-11-2009, 08:25 PM   #11
ka0sx
ka0sx's Avatar
sweet , although im old school and i love the bolt action
I dunno, I like both but I prefer to have an auto loader.
Old 04-11-2009, 08:43 PM   #12
SailDesign
Drives: .
.303 British
Lee-Enfield
Nope! The 303 has a tapered case with a lip at the base.
Old 04-11-2009, 08:47 PM   #13
SailDesign
Drives: .
my buddy has a .303 Lee-Enfield , its an awesome weapon for its age
Be VERY careful, if it has the original barrel - those old ones have a habit of getting fatigue cracks adn blowing out. Painful.
If original, get a decent gunschmidt to check her out.
Other than that, yeah - great guns. We used a set of Parker-Hale tweaked 303s in the rifle team at school, and it was possible to get a 10-inch grouip at 500 yards with service ammo. No bench, no bags, just what you Yanks call a Hasty Sling.
Good times...
Old 04-11-2009, 09:16 PM   #14
ka0sx
ka0sx's Avatar
Painful to say the least, wow, ouch....
Old 04-12-2009, 03:22 PM   #15
GeneW
Drives: 2008 Yaris
will do Sail, i only shot 5 shots and from what my buddy tells me when he bought it it was never shot before. but ill let him know about the condition thanks
The 303 doesn't run "too hot" as far as pressures. I have a 7.7 Arisaka which is close "ballistically" to the 303 Brit. Those old school firearms were not pushed hard because accuracy was a big issue for them. Some of the sights on older rifles were calibrated for over 1,000 yards. You don't get such accuracy with "single base" powders in my experience when you go for high pressures.
Later on studies showed that shooting people over 400 yards away was in general a waste of time, so planners reduced the mass of the ammunition and pushed up the pressures.
I am not experienced with the Lee-Enfield and do not know about barrel fatigue issue. In US made arms such an effect is quite rare in 30 caliber and up rifles. It's common in the 22 caliber military stuff because water will "wick" into the barrel, causing it to split when it's fired.
SMLEs were made in most of the bigger Commonwealth nations. If you're not sure about the rifle's origin it pays to have an experienced person check it out. I can almost guarantee it's been shot before, if only for Proof testing. The markings will appear on the barrel or receiver.
Gene
Old 04-12-2009, 06:52 PM   #16
Bob_VT
Bob_VT's Avatar
Drives: 08 Yaris LB
that's chinese to me ,
i know weapons at an intermediate level and i don't shoot regularly , so you would have to explain the phenomenon to me Gene
Well here is the safety item. ALWAYS wear shooting glasses. If a barrel ruptures it can split and shard but the majority 90% + of the energy is traveling forward ...... away from you. The hot gas, powder and pieces of brass can be thrown back towards the shooter.
Approved shooting safety glasses can save you.
The true phenomena when a barrel explodes and splits is where it happens internally.
A barrel consists of lands and grooves. The lands being the high spots and the groves are cut into the conventional barrel.
When it a barrel fails it is in the thicker area and not the thinner area. The pressure builds and reflects of the thicker areas with more velocity.
Confused now?
Here is a photo I took inside a "larger" barrel of a bigger gun!
Old 04-12-2009, 08:16 PM   #17
GeneW
Drives: 2008 Yaris
The M-16 series of firearms come with a caution regarding water in the barrel. If you shoot them "wet" they may burst.
"uring testing in March 1958, rainwater caused the barrels of both the ArmaLite and Winchester rifles to burst, causing the Army to once again press for a larger round, this time at 0.258 in (6.6 mm). Nevertheless, they suggested continued testing for cold-weather suitability in Alaska. Stoner was later asked to fly in to replace several parts, and when he arrived he found the rifles had been improperly reassembled. When he returned he was surprised to learn that they too had rejected the design even before he had arrived; their report also endorsed the 0.258 in (6.6 mm) round. After reading these reports, General Maxwell Taylor became dead-set against the design, and pressed for continued production of the M14."
No, I don't know why this effect occurs. I do know that I was warned NEVER to shoot the rifle with water in the barrel. The "procedure" after fording water is to aim the barrel towards the ground and allow it to drain.
Gene
Old 04-12-2009, 08:29 PM   #18
SailDesign
Drives: .
Gene
Any water in the barrel is likely to become steam very quickly a the pressures involved, especially if it is behind the round. I.e. any water that is in the chamber is likely to increase in volume by a few thousand percent. That increases the pressure big-time, resulting in bursts. Steam engines have used the principal for years. The bigger the barrel, the greater the capacity to survive this kind of abuse, since the amount of water per inch is a "unit" ratio, and the volume that can absorb the over-pressure is a "square" ratio (per inch of barrel). So, twice the calibre, four times the volume to absorb.
Finish Sedan S Intake, Paint Caliber, Air Vent Lights jamal1984 Performance Modifications 9 03-12-2007 11:57 AM
