Drives: 2008 Yaris Join Date: Oct 2008
Extended Radar Contact
On the way home this evening I encountered a strong X-band signal that lasted over two miles on a road with one mild right hand curve and then down a hill. I've been down this same path hundreds if not thousands of times over the years. It's a really poor spot for a radar trap, and the locals are not permitted to use radar anyhow.
Usually Radar Signals are short and sharp and can be found close to a store, bank and what have you. They're used for burglar alarms. Police signals tend to be shorter and sharper still, and usually they're "line of sight" if not they're bounced off of metal. Furthermore in PA only State Police can use them and this was in town. I'm still trying to figure this one out, Folks. This felt for all the world like a mobile source, one that was right behind me and had painted me for well over two miles. That's also strange since the mobile sources are rarely used. Fortunately I was chillin' and dropped speed fast until I was just around the speed limit. So that two mile long signal, that continued with no apparent source and through a slight right hand turn and downward grade, is a mystery to me. I'm mentioning this contact in case anyone else has been through this kind of scenario. Gene |
#2 | |
![]() ![]() ![]() ![]() ![]() Drives: . Join Date: Feb 2007
![]() ![]() ![]() Drives: 2009 Yaris Blazing Blue 3dr Join Date: Dec 2008
Maybe someone with a radar jammer, or a low flying aircraft's weather radar with the antenna depressed?
Drives: 2007 4 Door Yaris Join Date: Jan 2009
Maybe your radar detector is going bad?? I've heard lots of stories of them going off for no particular reason.
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2008 Yaris Liftback (Sprocket) Join Date: Oct 2008
AWACS? Microwave transmissions? Weather?
There are a variety of possible sources for sporadic electromagnetic activity, we have an Electronic Warfare Center where I work, I could ask someone there next week when I return to work...but it will only be theories as no ELINT collection could have been occurring in that area to allow a proper analysis of the event... Cheers! M2 |
Caveatipse?
![]() ![]() ![]() ![]() ![]() Drives: . Join Date: Apr 2007
Went down the same road again today, no issues. No contact within that corridor.
This was an X band contact HAARP is in Alaska, doubt it'd skip that specifically and that far. Closest military post is a NG unit at the south end of town. They're a water purification unit. A few MP units further out. I don't know of any Signals Intel outfits around here. No air defense operations either - last such gigs closed up shop ages ago. The SM-3 missile does use a sea based X-band radar for tracking space objects but those are very large and water borne. They also shoot upwards. Probably toast my detector if I were near one. I'd be amazed if it were an airborne source - look down radars require a huge amount of cleanup to resolve ground clutter, and I'm not sure that such a radar would have sufficient resolution to track a ground based object accurately. However if it is such a thing I'd sure be interested in learning more about it. Aliens? Why there, in broad daylight? No reason. My best guess is that a local drug store radar went off of the deep bend kept broadcasting or one of the local Staties left his or her radar on while they were cruising. Did not see a marked cruiser behind nor in front of me. Nor did I see an X band unit. They must be hiding them now. Maybe. Gene |
If there is a military base or exercise nearby, their radio's travel on a TON of different freq's, and then they are all mashed back together to get a single usable signal. Not to mention they have to be set to the same time... but military stuff set off all kinds of radars. Just a thought.
My other idea would be aliens, but someone else already said that one so... Hey, did you ever see a UFO? Weird stuff man! I still believe it's military or government stuff, but still weird. |
![]() ![]() ![]() ![]() ![]() Drives: yaris 08 sedan Join Date: Oct 2008
Probably the government doing some HAARP testing.
http://www.raven1.net/commsolo.htm |
i disabled the x band on my detector like 3 years ago. what cop uses x band anymore?
#13 | |
Gene |
#14 |
weird! last time i saw x band was in a podunk town in eastern WA back in 1999..
#15 | |
When one considers how many businesses use X band for door openers it's probably a good idea for police to consider re-issuing those old school X band detectors. A lot of users probably shut off their X band detectors for that reason. It's the one you don't see that gets you. Gene |
#16 |
not a radar detector in the world will detect a high flying aircraft timing you over 1/2mile increments (my only two speeding tickets in 5 years)
#17 | |
Apaches cruise around here on the weekends. The NGs are busy training for their sandbox gigs. They are easy to spot since they are quite loud, but if they're being sneaky they don't do that around residential areas. Doubt that they have "look down shoot down" radar. Don't need it, probably don't want it. Not when you have passive infrared that doesn't light you up like a light house. There is a microwave tower near the top of the valley but it's for communication and should not be detectable down there. No metal structures to bounce either. Montreal is a big business center. You all probably have tons of communications going on. We're small potatoes with fewer businesses each year. I'm guessing.... for all I know the DHS is using my hometown as "Everytown America" for training. We've been "occupied" by the NGs are few times over the years. They're decent guys, local people who do their weekend bit. Lot of folks from this area are over in the sandbox. Gene |
#18 | |
Gene |
| Should I get the Extended Service Contract for my 2007 Yaris? | tomato | New YARIS Purchase Forum | 23 | 02-27-2009 04:37 PM |
| FS: Cobra XRS 9430 Radar Detector | FreddysEvolutionIX | Items for Sale by private party | 5 | 02-02-2009 02:35 PM |
| Found a good deal on extended warranty | Bretsuaz | New YARIS Purchase Forum | 1 | 05-02-2007 10:40 PM |
| Extended Service warranties! | Buckethead | New YARIS Purchase Forum | 31 | 07-29-2006 07:46 PM |
