Belt noise?
This morning, when I started the car there was a quick squeak noise. Don't know if it had something to do with the rain we had(it rained it's ass off last night, and cooler morning than we have had) or if it is something wearing out within the belt area. It only made the noise for about 5-7 seconds, then went away, car seemed to run good. It did make this noise before, but not as loud and long (1 second ) in the cooler weather. Any thoughts please?
http://www.midatlanticnostalgiaconvention.com |
![]() ![]() ![]() ![]() Drives: 2008 yaris, stripped, red Join Date: Jan 2009
well...sounds like some time for basic maintenance.
get a new one. it's already been burnt. i'd replace it, and for 10-20 bux it's not gonna kill ya |
#3 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 07 Yaris 3dr LB (Bayou Blue) Join Date: Oct 2008
the rain does funny things to the yaris....
I left mine sitting in the rain for 3 days and it took a few trys to start it up.
-Jen <3 ![]() Quote:
yea rain and my yaris do not mix at all, after it rains the next day i start my car it starts up fine its just when it does start up it sounds like it died for .5 seconds then it goes va-vroooooooooom!!!!!!!! up to close to 3rpm then drops down to 2rpms in 3 seconds.......yea its rained so much i counted it =P but otherwise i think its normal really the belt gets wet and the pullies try to catch it when theres water between them, it happens to me but rarely, well also i have nst pulley set too
#5 | |
![]() ![]() ![]() Drives: '08 5-door Join Date: Apr 2009
![]() ![]() ![]() ![]() Drives: Yaris YR Join Date: Oct 2008
When i installed a new belt for my NST underdrive pulley, my mechanic said if it made any squeaks when starting up i would have to tighten my belt.
Im guessing the same would apply to the noise you may be hearing if its the belt. It is just slipping and getting abit loose, but once it warms up it grips better. You could try tightening the belt first if you have much tightening left. You can see how much more you can tighten on the silver/grey leaver with the bolt just above all the pulleys. Otherwise as someone said early you should just replace the belt they are pretty cheap.
![]() Mods: 17x7 ANZ Tazer Wheels with 215/40/17 Marangoni Tyres | AFE Air Intake System | NST Short Shifter Kit | NST Shifter Cable Bushing Kit | NST 10% Underdrive Crank Pulley | Pedders Sports Springs | Custom 2inch Cat-Back Walker Muffler with 2.5inch Xforce Twin Stainless Steel Tip | RS Side Skirts | RS Euro Spoiler | YRX Front Lip Spoiler | TRD Style Front Grill | 12mm Rear Hub Spacers | Ultra Racing 23mm Rear Sway Bar |
Learn to Relax
Drives: 2007, Meteorite, LB Join Date: Dec 2008
The belt should be adjusted. Feel under the belt and if it's cracked or brittle, then it should be replaced.
![]() ![]() ![]() ![]() Drives: '07 Yaris HB Join Date: Apr 2006
To those saying the belt needs to be replaced ... I'm not so sure. I JUST got my belt replaced and re-tightened, all was fine for a couple months and now the 'squeel' is back. Not sure what it is. Could be a bearing or something on the pully.
![]() ![]() ![]() ![]() ![]() Drives: 2013 Chevy Spark 1LT 5-speed Join Date: Oct 2008
Have somebody check the tension, and I doubt the rain was the problem...just had 22 straight days of rain and never heard a peep out of my belt during start up. If tension is okay, replace. Don't over-tighten...guessing 100lbs should be about right, and 125lbs max? 125lbs-150lbs might cause premature wear in Alt, W/P, etc...new belt will need to be readjusted within the first few hundred miles.
Belt seems to be tight enough , I will take it in, if I hear the noise again. Car has 25,000 miles on it.
![]() ![]() Drives: 08' HB Join Date: Oct 2008
If it just for a couple of seconds in the morning when cold, not a big deal, as long as it's not cracking. If it is slipping when accelerating once running then your loose.
0 - 60 in 3 shifts
#12 | |
#13 | |
Drives: 2007 4 Door Yaris Join Date: Jan 2009
fix things BEFORE they put you in deadly situations... my oil light only comes on when its really hot out and I drive it hard, should I wait til I snap a rod to get it taken care of? |
#14 |
your a moron
0 - 60 in 3 shifts
#15 |
#16 |
And why wait for the micro-v ribs to develope a glazed surface that doesn't grip too well, because of the slipping at start up?
#17 |
take a pair of scissors and cut the belt, take out the belt, oil up ur pullies and then thats it, the noise should be gone =)
#18 |
Parallel Parking Pro
Easy on the name calling.
But yes, a squealing belt is a problem - a correctly tensioned belt will not squeal. The belt runs your water pump and alternator, so your car could fail in a bad way if the water pump goes.
Leong's NCP91 Toyota Yaris E Hankook V12 Evo 195/55/15 on Buddy Club P1 replicas 15x7 ET +38 Stebel horns, Philips Silvervision turn indicator bulbs TTE Lowering Springs, Camber bolts TRD Blue brake pads Fujitsubo Super Wagolis axleback exhaust DC Sports header |
| Noise from the drums.... | Lafiro | General Yaris / Vitz Discussion | 18 | 05-22-2009 09:49 AM |
| Underdrive Pulley Belt | ruimond | Performance Modifications | 11 | 02-14-2009 09:05 AM |
| The Accessory belt? | N9QGS | DIY / Maintenance / Service | 4 | 02-12-2009 11:05 PM |
| Radio noise.. need help | TinyGiant | In Car Entertainment + Electronics (audio / video / alarm) | 13 | 12-06-2008 04:21 PM |
| Best Grease to use on the belt? | hasher22 | DIY / Maintenance / Service | 11 | 04-23-2007 02:20 AM |
