Old 05-19-2009, 06:19 AM   #1
Swallow
Swallow's Avatar
Drives: Yaris Sedan YRS
Something loose in the engine.
HI everybody,
I have just joined this wonderful forum, happy to be between you!
I have bought a Sedan Yaris 3 months ago ( brand new ).
When I pass over some speed bump or something like that, I feel something jumps up in the engine compartment, as if something is loose ...
Has anybody have a similar experience?
ONLY YARIS !
Swallow is offline   Reply With Quote
Old 05-19-2009, 09:19 AM   #2
IllusionX
Drives: 07 Yaris Sedan Aero
jack TOOLS in the trunk?
Old 05-19-2009, 12:30 PM   #3
Swallow
Swallow's Avatar
Thank you for your answer but the sound clearly comes from engine compartment.
Beside that, I hear this sound when the front wheels are passing on a speed bump or something.
ONLY YARIS !
Old 05-19-2009, 12:13 PM   #4
SpaceShot
SpaceShot's Avatar
Drives: 2008 Yaris 5 speed HB
Check that your air cleaner cover is properly latched down. I have seen it a couple of times where a quick oil change place or an inspection will do a `courtesy check' of your fluids and filters and either forget or not figure out how to snap the cover clips back into proper position.
SpaceShot is offline   Reply With Quote
Old 05-19-2009, 12:33 PM   #5
Swallow
Swallow's Avatar
Thanks for your answer... But what I hear seems to be the sound of a HEAVY thing jumping up and down... Doesnt seem to be something like air cleaner cover or similar things... But I am going to check it anyway...
ONLY YARIS !
Old 05-19-2009, 12:33 PM   #6
Swallow
Swallow's Avatar
Any Other Ideas?
ONLY YARIS !
Old 05-19-2009, 12:48 PM   #7
Zaphod
Drives: Big Yellow
Wait till everything cools down and check to see if the exhaust is loose anywhere?
Zaphod is offline   Reply With Quote
Old 05-19-2009, 12:51 PM   #8
The little red pill
Taking care of Bubbles
Drives: 2009 Yaris LB "Bubbles"
It's under warranty so take it to the dealer!
2009 Absolutely Red LB. "Bubbles"
The little red pill is offline   Reply With Quote
Old 05-19-2009, 01:20 PM   #9
Swallow
Swallow's Avatar
I will absolutely do it at the end, but firstly I want some clue!
ONLY YARIS !
Old 05-19-2009, 01:19 PM   #10
Swallow
Swallow's Avatar
I will certainly check that. Thanks
ONLY YARIS !
Old 05-19-2009, 01:21 PM   #11
Swallow
Swallow's Avatar
Any Other clues? similar experiences?
ONLY YARIS !
Old 05-19-2009, 01:42 PM   #12
IllusionX
mine have a metal sound when i go over road bumps (the so called pot holes in Quebec)
but it does sound from the inside of the car, near the ODBII connector.
Old 05-19-2009, 02:12 PM   #13
YarisSedan
Drives: 08 Yaris Sedan
Mine was doing that. Found out the spare tire wasnt completely tightend down. Now the spare tools jump around a bit and clang around now too.
Old 05-19-2009, 02:20 PM   #14
Swallow
Swallow's Avatar
Thank you my friend for sharing your experience. But in my case it cant be spare tire because the sound comes from engine not from trunk.
Thank you anyway ...
ONLY YARIS !
Old 05-19-2009, 03:00 PM   #15
ka0sx
ka0sx's Avatar
Drives: bone f*ing stock
check the motor mounts......? its the only thing i can think of, but if the car is new it shouldnt be an issue, how fast are you going over the speed bumps?
ka0sx is offline   Reply With Quote
Old 05-19-2009, 08:35 PM   #16
Swallow
Swallow's Avatar
Not that fast... say 25km/h
ONLY YARIS !
Old 05-19-2009, 03:15 PM   #17
hatchbackkid82
Drives: .
the hamster is off the wheel
Old 05-19-2009, 03:25 PM   #18
hatchbackkid82
Drives: .
AHHHHHHH!!!!!!!!!!!!!!!!!!!!!
DIY: Intake Installation redyaris DIY / Maintenance / Service 53 08-23-2014 06:34 AM
The last gas question Tonavi DIY / Maintenance / Service 56 04-27-2009 09:40 PM
engine swap update Adriaan Canada 5 03-03-2009 07:21 PM
The Advantages of Nitrous on an Engine KCALB SIRAY Performance Modifications 7 01-02-2009 11:53 AM
