Old 07-25-2006, 09:04 PM   #1
MacMaster761
Five-Star General
Drives: 07 Silver Streak Mica
Send a message via AIM to MacMaster761
Silverstars?
So anyone have silverstar headlights or similar bulbs, what size is the headlight bulb?
Do the drls use the same bulb?
MacMaster761 is offline   Reply With Quote
Old 07-25-2006, 10:26 PM   #2
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
I have the GE Nighthawks and love them...nice and clear, plus better range. It has been recommended that if you get the SilverStars to get the Osram SilverStars from the UK...they are better. As for the size they are 9003/H4 if memory serves correct. No idea on the DRLs as the S Sedan doesn't have them.
Old 07-26-2006, 12:19 AM   #3
TRD_Yaris
Yarii Hunter
TRD_Yaris's Avatar
Drives: 2007 Yaris Liftback and S13's
yup 9003/H4 ..and if you decide to get the Silverstar bulbs make sure to get the Osram Silverstars (available in Europe) not the Sylvania Silverstars (USA). As someone on the forums correctly pointed out to me, the USA Sylvania Silverstars have a blue coating on them to make them appear blue. OSRAM and Sylvania are basically the same company..one is division of the other.
You can get the Osram Silverstars through
powerbulbs.com
Free shipping and 10% off coupon makes them about $22 !!!! Thank you Pixiedawn for the coupon code!!
"Originally Posted by PixieDawn
I just ordered my Osram set (size h4), btw i found a 10% offer code you can use at check out... (every little bit helps) just enter: ZXRCX111"
Thanks for all the help over the years, YarisWorld!!!
TRD_Yaris is offline   Reply With Quote
Old 07-26-2006, 04:15 AM   #4
paultyler_82
Drives: 07 Meteorite Metallic Yaris LB
I can't stand Sylvania Silverstars (US-Spec), get the Osrams if you want them, but the GE Nighthawks and Sylvania Xtravisions are just as good, and a bit less expensive as well.... the only Silverstars that I buy are the signal bulbs, they look better in the reflector than those ambers and still put out plenty of amber light when lit, plus it's a deep amber, not too yellow or too orange. Further, the headlights are dual filament one bulb units, that one bulb covers your low and high beam as well as your DRL... just as in most Toyotas, all the DRL does is burns your low or high filament at a lower power than normal. that little bulb in the reflector with the headlamp is a 194-type bulb that fills the requirement of a city or locator light in certain countries, it is not your DRL.
paultyler_82 is offline   Reply With Quote
Old 07-26-2006, 08:08 AM   #5
MacMaster761
Five-Star General
wow guys good info, and the yaris sedan in flint mica is all set and ready to go, car will be here in about a week!!
Old 07-26-2006, 08:17 AM   #6
MacMaster761
Five-Star General
i'm thinking about the H4 cool blue, anybody have pictures of somethin like this. Are the GE nighthawks blueish in color?
Old 07-26-2006, 06:52 PM   #7
Chris07LB
Chris07LB's Avatar
Drives: Yaris Liftback
My H4 HID's ($230 shipped!!)
Old 07-26-2006, 10:05 PM   #8
MacMaster761
Five-Star General
those look tight
Old 07-28-2006, 03:16 PM   #9
slvryaris
slvryaris's Avatar
Drives: 2007 Yaris Sedan S
What kind are those??They looklike my PIAA's but in the higher kelvin to give it that purple look.
Old 07-28-2006, 03:15 PM   #10
slvryaris
slvryaris's Avatar
I have a set of the PIAA Xtreme white plus and they are worth the money.
Old 07-28-2006, 04:13 PM   #11
fnkngrv
fnkngrv's Avatar
The GE Nighthawks are pure white light. Actually I was able to pick mine up at Walmart for only 26.99 for the pair! Great deal I think. As for slvryaris, to each their own, but I think that PIAA smokes some good budha for the prices they are asking....but once again, just an opinion.
Old 07-29-2006, 08:11 PM   #12
paultyler_82
Anyone who is more interested in retrofitting projectors into their housings for whatever reason (looks... availiability of bi-xenon) should check out Hidplanet's forums, plenty of people over there retrofitting HID into about anything you can imagine. As for your HID's Chris, they're looking good, I'm amazed at the beam pattern considering these are Halogen reflectors.. did you upgrade your harness though? I really would recomend it, granted HID ballasts only pull 35W running, they surge up at fire-up and I've seen a few toasted harnesses with longtime users of HID conversions that didn't upgrade their harnesses.
Old 07-31-2006, 07:06 PM   #13
TRD_Yaris
Yarii Hunter
TRD_Yaris's Avatar
yeah, i'm no electrician but this was the same explanation given to me about HID ballasts, since they pull more current especially on start up(am I correct?).
I have used MANY many HID bulbs of MANY varieties other than Xenon, and the ballast was always the PITA. Though, i would have to say that it could be BECAUSE OF CHEAP, GENERIC BALLASTS. If you get good ballasts, they shouldn't hurt anything. that's why I run Phillips ballasts that are OEM LEXUS. but, the first few years of "HID retrofitting" saw hundreds of cheap, no-name companies building these Ballast boxes for next-to-nothing and this COULD BE WHY there was such a problem with wiring harness melting back-in-the-day.
The ignitor in HID ballasts can wreak havoc on your fuses and wiring harness, but I can't say that this problem hasn't been addressed...i really haven't heard any horror stories about melted wiring harnesses in the last few years.
HIDPlanet rox. Good info.
Old 07-31-2006, 07:55 PM   #14
OxyG3nE
Drives: Toyota Yaris 2007
Send a message via AIM to OxyG3nE Send a message via MSN to OxyG3nE
you have a website to buy the hid kit?
OxyG3nE is offline   Reply With Quote
Old 08-01-2006, 09:52 AM   #15
Chris07LB
Chris07LB's Avatar
If you are talking about the one in my car, contact me direct.
chris03hd@comcast.net
Old 08-05-2006, 07:22 PM   #16
paultyler_82
TRD Yaris, glad you're enjoying the info over at HIDPlanet, I would agree that toasted harnesses are sort of rare nowadays, but I've seen enough of them, and I know harnesses are a PITA to deal with, so... I'm going to subscribe to the better-safe-than-sorry camp on this one, you can even make your own harness on the cheap and a premade, decent harness would only set you back about 50-60 dollars, think of it as insurance.
Old 09-23-2006, 12:05 PM   #17
Centurion2200
Centurion2200's Avatar
Drives: Yaris Hatchback 07
Send a message via MSN to Centurion2200
Hi, Im new here :)
One thing to say....HID is the way to go.......
All xenon bulbs.....(Piaa, siverstars, etc etc) try to SIMULATE the effect of an HID system.....
buy the real thing.....a little more expensive....but really worth it!
I just bought a '07 5 door hatchback an i put in there some 6000k bulbs....not at blue as the 8000k kit...but a lot brighter.... i'll post some pics tomorrow...
im really HAPPY with my HIDs :D
Centurion2200 is offline   Reply With Quote
