Old 06-25-2009, 06:53 PM   #1
goku87
goku87's Avatar
Drives: Black HB
I want stiffer suspension, not so much lowering.
Sometimes while you are driving down the road in Alaska you are able to let go of the steering wheel and the car will drive itself. Why? The ruts in the road are so deep they keep the wheels going in the right direction. These same ruts, when crossing an intersection, allow for some good air time since you are going at them perpendicularly.
Do they make non-lowering springs? Haha, I kid. But seriously, I just want a suspension that doesn't feel like the car is rolling so much when I take a corner, but I don't want to lower my car so that I drag everywhere (due to the ruts). Any suggestions?
goku87 is offline   Reply With Quote
Old 06-25-2009, 07:01 PM   #2
silver_echo
ekodrvr
silver_echo's Avatar
track down a shop that makes custom springs... there is a shop in my area that will make custom springs for a vehicle, just tell them what you want, send in your old springs for comparison, they want about $700/axle on my 2001 echo for the same purpose... i also am going stiffer without lowering...
i like this smiley...
silver_echo is offline   Reply With Quote
Old 06-25-2009, 08:02 PM   #3
jonismyname
Drives: 08 liftback 5spd
use aftermarket springs with small drop, then use spacers, i believe they're available form jcwhitney. or, place blocks in the factory springs. that's a bad idea. but it'll work.
jonismyname is offline   Reply With Quote
Old 06-25-2009, 08:03 PM   #4
jonismyname
actually, i don't know if it'll work. but it'll stiffen the spring rate. and napa does carry them. it'll also put extra stress on the rest of the spring. but the spacers will work.
Old 06-25-2009, 08:13 PM   #5
Astroman
Modded Moderator
Astroman's Avatar
Eibach makes a stiffer spring that only lowers 1". There are also other non-lowering add-ons you could do. A rear sway bar, rear link bar, underbracing, and a front strut tower bar help.
For the best bang for your buck, go with the rear sway bar. The others help, but that sway bar makes the biggest impact.
Old 06-25-2009, 08:26 PM   #6
Tamago
Tamago's Avatar
Drives: UZJ100
there's a thread here called "racing suspension" .. talk to kngrsll about stiffer springs. or have me build you some coilovers. stiffer shocks/struts will do more for you than stiffer springs.
Old 06-25-2009, 09:18 PM   #7
kngrsll
Apexing Egg!!
kngrsll's Avatar
i would get really stiff shocks (like the Tokico HTS or maybe blues) and a sway bar.
HighTach Motorsports
2007 Toyota Yaris-ARGH!!
Old 06-25-2009, 11:50 PM   #8
CASTREX
Who said Yaris was slow?
CASTREX's Avatar
Drives: Yaris T-Sport 2008
Start with the rear sway bar...
Then, if is not enough for your need, get the Tokico blues... and leave the OE springs alone...
what to look out for when installing lowering springs songa Performance Modifications 34 09-15-2012 03:29 AM
Finishing my suspension ChinoCharles Wheels, Tires and Suspension Forum sponsored by The Tire Rack 11 10-15-2011 09:26 PM
Stiffer suspension - same ride height? fuji Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 01-13-2009 07:53 PM
Is it practical to install stiffer shocks without also installing lowering springs? St_G Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 01-18-2007 01:23 PM
