Old 06-29-2010, 12:45 PM   #1
Lorenzo1950
Drives: 2010 5 door Hatchback
two observations
How many Toyota models have the outside temperature feature? I sort of like this feature and wish my Yaris had it.
Something I noticed recently is that my turn signal seems to always be on.
Most cars have the feature that the turn signal is disengaged when the steering wheel is rotated to a certain degree. Apparently, the Yaris is not as sensitive to this. I will look on the dash to see my turn signal is still blinking three minutes after I get off the exit ramp. Are there any adjustments to correct this problem? I had a Honda Civic and rarely encountered this problem, because I was usually aware when the turn signal needed to be shut off. Maybe the Yaris is noisier so I do not hear the clicking of the turn signal. The Civic was extremely quiet inside and sometimes I did not even hear the engine running. I realize that you have to manually turn off the turn signal a good percentage of the time on any car, but I think with a Yaris it is more often.
Lorenzo1950 is offline   Reply With Quote
Observations on LB turbulence GeneW Fuel Economy Forum 18 11-28-2008 09:22 PM
Woof's Big Rear Sway Saga..... woof Wheels, Tires and Suspension Forum sponsored by The Tire Rack 7 04-02-2007 11:24 PM
