Old 02-01-2012, 04:00 PM   #1
diablo7772
Drives: VVTI 1.0 W reg
Exclamation Help Required VVTI 1.0 W reg
Hello Yaris owners,
My dad owns a yaris 1.0 VVTI on a W reg. 131K on clock
The car has a hole in the exhaust just after the last Lamba sensor, well kind of 4 holes.
I have changed the sump on it last night and left the silicon to dry for over night+ new oil filter, plugs, new air filter + cleaned the maf.
To change the sump, the exhaust had to be taken off and the flywheel cover plate had to be taken off + the out put lamba sensor disconnected.
When i started the car the Hot engine light went on and then straight to cold after about 3 secs.
This evening starting the car it felt slugish and the revs are all messed up.
When i put the foot down on the floor it kind of gradually goes up till the top.
When i took it for a drive it took me ages to accelerate from about 4 mph to 12 in first. Second gear was same as first. As when i put it in third the revs dropped and when i put the foot down it didn't even want to go but only kept at idling and i was loosing speed.
If any one have had this problem or anything similar can you please let me know what i have to change.
The car is on 131k and it never had a new clutch fitted.
Thank you very much
diablo7772 is offline   Reply With Quote
Old 02-01-2012, 04:11 PM   #2
Yury
Yury's Avatar
Drives: 2008 5 Door Liftback Auto
Did you plug the maf back in? I know it's kinda obvious...
1999 Honda Prelude Base 5 speed (summer driver)
Yury is offline   Reply With Quote
Old 02-01-2012, 04:15 PM   #3
diablo7772
Yeah the maf is plugged in and i just took all the plugs off checked them, took the maf out to have a look, took the neg off the bat and held the brake pedal for 10secs to reset ecu.
I will record a video tomorrow :(
Old 02-01-2012, 04:22 PM   #4
Yury
Yury's Avatar
how did you clean the maf?
I guess you can unplug it and see if the car acts any different.
Do you have anything to read OBD2 data?
Old 02-01-2012, 04:30 PM   #5
diablo7772
I used some WD40 and then just soft cloth. I will do that in a sec!
Yeah i have a OBD2 reader.
Old 02-01-2012, 04:35 PM   #6
Yury
Yury's Avatar
Did you spray WD-40 on the maf wires?
Old 02-01-2012, 04:36 PM   #7
diablo7772
Just took of the maf and had a go in the car it has helped the problem a lot but it has put it in limp mode so limited to 3.3k revs.
I will take it off and just dry it :) see if that helps unless the WD has damaged it.
Old 02-01-2012, 04:39 PM   #8
Yury
Yury's Avatar
WD40 is a lubricant...it will stay in the wires forever unless you clean it off. Spray it with some electronic cleaner (or a specialized MAF cleaning spray). Some people use a non-residue carb cleaner, but many say it's too aggressive.
I suppose alcohol would work too.
Old 02-01-2012, 04:37 PM   #9
diablo7772
The oil was only sprayed on the sensor pin.
Old 02-01-2012, 04:41 PM   #10
Yury
Yury's Avatar
what is a sensor pin...the blobby looking thing on the side of the sensor? I presume your sensor look the same as on my 1.5...
Old 02-01-2012, 04:57 PM   #11
diablo7772
yeah, i will have to get some electric cleaner.
Cheers
Old 02-01-2012, 05:23 PM   #12
Yury
Yury's Avatar
good luck.
V Reg 1999 Toyota Yaris 1.0 gls semi auto jshakey UK 1 03-08-2012 03:00 PM
Slow cranking on an 02 1.0 vvti Yaris Duberry UK 0 11-01-2010 09:20 AM
'54 T2 Yaris 1.0 VVTi automatic clutch / gearbox / starting problem Lettuce UK 0 09-30-2010 06:21 AM
03 Yaris 1.0 VVti Engine Swap, URGENT help needed. philwept_33 DIY / Maintenance / Service 1 05-15-2009 12:15 PM
x reg yaris 1.0 vvti gs (feeler) hula hoop Cars for Sale by private party 0 12-04-2008 06:36 AM
