Old 07-20-2009, 11:54 PM   #1
trini_per4mance
trini_per4mance's Avatar
Drives: 2007 Toyota Yaris S Sedan
My 2007 Yaris S doing 350,000 miles in less than 3yrs.
Hey guys, it's that time again for yet another update. As of today 7/20/09, I have hit the 350,000 mile mark. And, yes, I am still running on my original brakes and clutch. I have yet to have any mechanical failure, except for the alternator going out on me, which I replaced with another low mileage OEM one. The only thing I notice with the car is, I get some pinging from the motor when the engine is under load in any gear. I have never changed O2 sensors or Knock sensor. And I have no idea how long these parts are good for or when they need to be replaced. I will be posting my video on youtube as usual. so you guys can look forward to that. FYI, the only things I change on my yaris are, tires, oil, spark plugs, wipers, drive belt and all 4 shocks. I have never flushed the coolant or brake fluid. I only top them up when needed.
I must say, this is the by far the MOST reliable car I have ever driven or for that matter, come across in my lifetime.
Yaris 500,000 miles in 6 years 9 months 3 weeks and 3 days and still going strong!!!
http://www.youtube.com/watch?v=YnTlNLz9Iqc
http://money.cnn.com/galleries/2010/...le_cars/5.html
http://www.subcompactculture.com/200...-miles-on.html
trini_per4mance is offline   Reply With Quote
Old 07-21-2009, 12:14 AM   #2
SilverBack
Joey
SilverBack's Avatar
Drives: '14 Scion xD 5-speed
Once again, congrats!
If I can make a suggestion. Put the links of all your milestone threads in your sig to show the skeptics out there *coughcoughcoughC&Rcough* how reliable the Yaris really is
Old 07-21-2009, 12:15 AM   #3
JumpmanYaris
USAF_SrA_E-4
JumpmanYaris's Avatar
Drives: C300 / Del Sol
damn dude wtf u been doing in ur car. u live in FL and work in NY?? lol
Originally Posted by sw07gt
Old 07-21-2009, 12:25 AM   #4
chriswb
Drives: 09 Yaris Liftback
I hope all of our cars are as reliable as yours!
chriswb is offline   Reply With Quote
Old 07-21-2009, 12:39 AM   #5
trini_per4mance
good idea krayzee. thanx!
Old 07-21-2009, 12:41 AM   #6
highwaypass
Captain Slow
Drives: '08 1.5 hatchback
congrats,man!
There's only 1 brand,2 drive,3 words,4 you: TO-YO-TA
highwaypass is offline   Reply With Quote
Old 07-21-2009, 01:02 AM   #7
silver_echo
ekodrvr
silver_echo's Avatar
hope mine makes it that far with no issues...
i like this smiley...
silver_echo is offline   Reply With Quote
Old 07-21-2009, 01:10 AM   #8
The little red pill
Taking care of Bubbles
Drives: 2009 Yaris LB "Bubbles"
thanks for the update!
2009 Absolutely Red LB. "Bubbles"
The little red pill is offline   Reply With Quote
Old 07-21-2009, 01:35 AM   #9
supmet
Drives: 2007 4 Door Yaris
Any word back from toyota sponsoring you or anything? They should at least put you in a commercial or something...
Old 07-21-2009, 01:36 AM   #10
Congrats! Nice work showing the reliability of the Yaris.
Old 07-21-2009, 03:23 AM   #11
yaris-me
Learn to Relax
Drives: 2007, Meteorite, LB
Congratulations!
Old 07-21-2009, 08:15 AM   #12
IllusionX
Drives: 07 Yaris Sedan Aero
You should consider changing your coolant. The reason i say this is because coolant become acid with time, and should be changed so it would not eat through the rad/engine.
Old 07-21-2009, 08:50 AM   #13
R2D2
Crazy Oil Sniffer
R2D2's Avatar
Thanks for the update-I was just wondering how many miles you were up too a couple of days ago.
As far as the "pinging" problem you're having if your check engine light is not on I would start with a couple healthy doses of (reputable) fuel injector cleaner (such as Chevron Techron). Just be sure to "schedule" both doses for right before an oil change (I would run both doses back to back in your case).
Also if you have access to Shell brand gas I would try to use that exclusively or at least as often as possible. Shell has a well respected additive package.
I think I remember reading that you track your fuel mileage-any drop in fuel economy?
Thanks,
R2
-The Fitful One
Old 07-21-2009, 08:58 AM   #14
kimona
kimona's Avatar
Drives: 2014 White VITZ
350,000 miles? That's amazing!
I remember reading somewhere that Toyota would give a new car to the original owner you hit 1,000,000 miles.
Old 07-21-2009, 10:26 AM   #15
trini_per4mance
Thanks,
R2
I actually added a Gumout fuel system additive yesterday and filled up with Chevron fuel. So far, no pinging. The pinging was actually intermittent. But, I think the additive took care of it so far.
As far as my gas mileage. Yes, I have seen a decrease in it. I only get 36mpg with my a/c on. I use to get 44mpg when I now got the car, even with intake, exhaust and headers.
thanx!
Old 07-21-2009, 03:24 PM   #16
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
thanx!
new sparkplugs, seafoam the bitch and then do an oilchange. Clean that intake manifold right out. Do a can in the intake line... and one in the gas tank.
if there is a problem with carbon/gunk.. that'll fix it up. Seafoam is only like $8 a can.
Old 07-21-2009, 03:36 PM   #17
R2D2
Crazy Oil Sniffer
R2D2's Avatar
Cool, sounds like you've got a handle on it. I'd give it another dose right after this one for good measure.
Do you have access to an OBD 2 scanner with live data? If your mileage dosn't improve after the injecter cleaning it would be worth having someone look at the O2 sensors in real time and make sure they are still "up to snuff". They have certainly served you well up to this point and are far beyond their designed life expectancy :)
I thought I heard somewhere you use the Super Tech syn oil from Walmart and OEM Toyota filters at 5k mi intervals-is this true? Whatever you're using this is a great show! I realize you put the miles on quickly but considering the number of miles this is an extremely impressive display of reliability.
TIA
R2
-The Fitful One
Old 07-21-2009, 03:43 PM   #18
Sodium Duck
╚══════════RN
Sodium Duck's Avatar
Drives: 2008 Liftback
I love reading your posts, this is great. Whenever my friends give me gruff about my car I always bring you up. Keep the shiny up and the greasy down, lol.
TSB's WD-40 General Yaris / Vitz Discussion 27 06-06-2007 01:11 AM
