![]() ![]() ![]() ![]() ![]() Drives: Polar White - 5 Door '09 LB Join Date: Aug 2006
FS: Dashboard Covers for the '07-'09 LB, ProClip Mounts, 180mm Double Din Trim Piece
FS:
Two Dash-Topper dashboard covers. Both are velour. One is black and the other dark gray. http://www.dashtopper.com/shop.net/VelourDT.aspx Both include all pieces they originally came with. The black one will come in its original box and packaging. The dark gray will come wrapped in a plastic bag in a brown box. Also, on both sets the piece that goes on the driver side glovebox has a hole cut in the middle (I have a Garmin GPS mount permanently attached to my driver side glovebox door and the holes were for the mount to stick through). ![]() ![]() ![]() $37 + shipping for each set. ================================================== ================================================== ====================== ProClip Angled Mount (fits LB only): ProClip Item #: 853742 http://www.proclipusa.com/?sectionpath=144&pageid=11575 ![]() ProClip Center Mount (fits both LB and Sedan): ProClip Item #: 853835 http://www.proclipusa.com/?sectionpath=144&pageid=11986 $17 + shipping for each ProClip ================================================== ================================================== ====================== Finally, I have one 180mm Double Din Trim Piece. I tried modifying it to work with my Pioneer head unit, but it wouldn't fit. Using a dremel, I shaved down the inner sides of the frame. It has a scratch on both of the bottom corners. I'm guessing if your good at working with CF or you like wrapping these trim pieces in vinyl or leather, this would be a good piece for you to work on. ![]() ![]() ![]() ![]() ![]() ![]() $34 + shipping for the 180mm DD Trim Piece ================================================== ================================================== ====================== My heatware for references: http://www.heatware.com/eval.php?id=35947 Last edited by IsLNdbOi; 09-10-2009 at 05:03 AM. |
| Group Buy - True Double Din Radio Trim for Liftbacks (180mm opening) | CTScott | Items for Sale by private party | 259 | 06-08-2011 11:13 PM |
| FS: Garmin GPS Unit w/ ProClip Mounts, 180mm Double Din Trim Piece | IsLNdbOi | Items for Sale by private party | 2 | 08-23-2009 02:37 AM |
| True Double Din Radio Trim for Liftbacks (180mm opening) | cruz-gsr | Items for Sale by private party | 3 | 07-05-2009 11:02 PM |
| For Sale True Double Din Radio Trim for Liftbacks (180mm opening) | Adriaan | Items for Sale by private party | 0 | 05-25-2009 11:16 AM |
| Double Din 180mm Trim Bezel | esyres | In Car Entertainment + Electronics (audio / video / alarm) | 19 | 03-19-2009 09:01 PM |
