Old 09-26-2009, 05:25 PM   #1
Brentorius
Drives: 07 Mazda MX5 Copper Red
Smile Lowered today on tein springs...pics and alignment question
Install went really well, the 17mm nut on the top hats were a pain! I had it aligned and they told me my rear toe was out of spec and non adjustable. I also have 12mm rear hub spacers.
Does anyone else have any rear toe issues or tire wear issues on teins? Toe specs from the shop: Rear Left .44 degrees and Rear Right: -.12 degrees
Before
After
Friends Mr-2 Spyder
Brent
Former Yaris Owner
Brentorius is offline   Reply With Quote
Old 09-27-2009, 12:02 AM   #2
Gideon
★weeaboo★
Gideon's Avatar
Drives: 2008 Bayou LB
No help on the alignment, but just had to say looking good!
MR2 is nice as well. I spy a Midship Runabout front emblem I do believe.
Old 09-27-2009, 12:12 AM   #3
Brentorius
You are correct
Brent
Former Yaris Owner
Old 09-27-2009, 12:13 AM   #4
ozmdd
Reluctantly Crouched...
ozmdd's Avatar
Drives: 2008 Yaris HB M/T
Garm sells the rear camber rings that will allow you to get the toe and camber set where you need it. Cheap and easy, but best to take them to your alignment guy to be installed.
www.microimageonline.com
Old 09-27-2009, 12:15 AM   #5
ozmdd
ozmdd's Avatar
BTW - what rims are those? Look like TE-37's w/o stickers....
Old 09-27-2009, 12:46 AM   #6
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
Probably Rota Grids
Old 09-27-2009, 01:10 AM   #7
Brentorius
Probably Rota Grids
Yes 15" rota grids
Brent
Former Yaris Owner
Old 09-27-2009, 01:58 AM   #8
minired5stby
minired5stby's Avatar
Drives: Yaris S liftback
Lower is always better.
Old 09-27-2009, 04:13 AM   #9
Looks good, but I didn't have any alignment issues. In fact, I drove for a year before I got an alignment done, and that's because the highways in my area became craptastic when they started to repave them that I think it threw off my alignment enough to suddenly cause tire wear.
Old 09-27-2009, 08:40 AM   #10
kuyachris84
kuyachris84's Avatar
Drives: 2008 Yaris Liftback Black
yay for yellow!
2008 YARIS/VITZ LIFTBACK - BLACK SAND PEARL
Representing The Midwest!
http://www.cardomain.com/ride/3132598
kuyachris84 is offline   Reply With Quote
Old 09-27-2009, 09:39 AM   #11
markrg07
markrg07's Avatar
Drives: 2007 toyota yaris 4dr
im an alignment tech and un fortunetly there are no after market kits to fix rear toe. i have lowered my yaris and have the same issue. i lowered it wit trd springs
markrg07 is offline   Reply With Quote
Old 09-27-2009, 11:56 AM   #12
90tsi
90tsi's Avatar
Drives: 09 yaris
i lowered mine on teins and havent had any issues with tire wear.
90tsi is offline   Reply With Quote
Old 09-27-2009, 02:28 PM   #13
Brentorius
Nice. I am not going to worry about it too much then
Brent
Former Yaris Owner
alignment, lower, springs, tein
