Old 09-20-2009, 09:30 AM   #1
Treyz
~ ambient one ~
Treyz's Avatar
LED Headlight City Light Bulbs
Anyone have any trouble replacing the stock city lights (parking lights) in your headlights? Meaning after a while, they just begin to flicker and then eventually burn out after a while? I had this problem on my old '07 as well. Thought the problem would have been taken care of with the '09's, but seems that it's happening again.
First set were the W5 bulbs from SuperBriteLEDs.com (2 sets) and Eurolite on the '07 and the ones being used now are from Pilot on the '09.
AMBIENTLIFESTYLE
Tri-State Sport Compact EZine
Micro Image
Store - Network - Online
Old 09-20-2009, 10:38 AM   #2
Chris07LB
Chris07LB's Avatar
Drives: Yaris Liftback
Had my HiLed's (search my posts) since late 2006 without one flicker.
Old 09-20-2009, 02:30 PM   #3
RedRide
RedRide's Avatar
The front parking lights are the exact same bulb as the rear license plate light.
I suspect the bulb contacts are not making good contact with the bulb contacts and this is causing the flickering.
The 194/168 bulb contacts are just bare wires (even with an LED) that run along the outside of the bulb and sometimes need to be spread from the base slightly to make better contact.
Personally, I'm partial to "Polarg M4-B1 Hybrid" (hyper white) bulbs.
I have been using them for years and they litterally last for years in most aplications.
The very first thing I did when I first got my Yaris was to replace the front parking and license plate light with them as they look great.
I have yet to find a (white) LED that in IMO looks as great as them to replace a 194/168 bulb.
Old 10-07-2009, 08:17 PM   #4
Lucas13
Drives: 07 Yaris LB
V-leds have 13 SMT led ones that look great w/o any flickering. I recommend them.
Lucas13 is offline   Reply With Quote
Old 10-07-2009, 08:28 PM   #5
mikenacarato
SIPNDEW
mikenacarato's Avatar
Drives: 15 STI
mine are a 5-led bulb from superbrightleds.com, no issues yet! :)
Old 10-08-2009, 12:57 AM   #6
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
I have had mine in for over 12 months
no issues
Old 10-08-2009, 08:10 AM   #7
I see in your garage, that you have a ground wire kit (which is fine). You aren't by any chance running one of the voltage stabilizer modules or something like that?
Old 10-08-2009, 08:35 AM   #8
ive had led's in my parking lights since i got the car in august 07...2 winters w/ -25C temps and no problems
though i actually hear it higher temps that mess up led's
Old 10-08-2009, 01:46 PM   #9
tk-421
tk-421's Avatar
Drives: 5D-07-LB
I have a voltage stabilizer. I installed it because I thought it would help when I get my carpc installed. Should I take it off?
Old 10-08-2009, 02:00 PM   #10
Tamago
Tamago's Avatar
Drives: UZJ100
in all my cars that use city lights, i buy amber 194 incandescent bulbs. i have yet to have a bulb failure in 10 years. sounds like your LED's were not up to industry standard? ( superbrightleds.com FTW though)
Old 10-08-2009, 02:25 PM   #11
Not necessarily. I was just looking for something about his car that is different than others who have not had an issue with the LEDs burning out.
I was thinking that if a voltage stabilizer had a boost regulator that perhaps the LEDs were being overdriven.
Old 10-09-2009, 08:59 PM   #12
Treyz
~ ambient one ~
Treyz's Avatar
I don't have a voltage stabalizer and I thought it was maybe my old 07, but my 09 is doing the same exact thing.
AMBIENTLIFESTYLE
Micro Image
Old 10-09-2009, 09:12 PM   #13
I've noticed with superbrightleds that some of their automotive LEDs are rated for 12 V and others are rated for 14.4 or 14.8 volts. Since our lights get raw battery/alternator output (rather than regulated 12V) maybe the ones that you have bought have the lower rating.
Old 10-10-2009, 01:44 AM   #14
Treyz
~ ambient one ~
Treyz's Avatar
So your saying I should get bulbs that are rated for 14.4?
AMBIENTLIFESTYLE
Micro Image
Old 10-10-2009, 07:04 AM   #15
Yes. When the engine is running, the alternator puts out over 14 V.
Old 10-10-2009, 01:42 PM   #16
Treyz
~ ambient one ~
Treyz's Avatar
I know that, but didn't think that it mattered being that normally anything 12V is for a vehicle no? I'm gonna look into the bulbs and see if they in fact offer something of the sort. Hopefully they won't burn out after a while.
AMBIENTLIFESTYLE
Micro Image
Old 10-10-2009, 08:05 PM   #17
I just noticed that when you look at the specs for superbrightleds automotive products some list the operating voltage range as 12V and others as 14.4V or 14.8V.
If you want to try a test with your existing ones, add a 200 ohm resistor (which would be the difference in required resistance for a 12V rated vs 14.8 V rated device) in series with the LED bulb and see if they stop burning out.
DIY (08' USDM LB): Interior Light Color Change revnull DIY / Maintenance / Service 37 05-21-2016 12:59 PM
How many forum posters does it take to change a light bulb? silver_echo Off-topic / Other Cars / Everything else Discussions 25 06-27-2011 01:50 AM
Side Turn Signal Lights bigsky2 Cosmetic Modifications (Exterior/Interior) 15 08-24-2006 06:06 PM
