Old 11-12-2009, 01:30 AM   #1
Pattycake
Drives: Yaris
Send a message via AIM to Pattycake
60K Mile Maintenance
Just curious, has anyone done their 60K mile maintenance yet? If so, what maintenance things have you done? Should I just follow the maintenance guide?
Pattycake is offline   Reply With Quote
Old 11-12-2009, 02:52 AM   #2
yaris-me
Learn to Relax
Drives: 2007, Meteorite, LB
Yes.
Old 11-12-2009, 07:38 AM   #3
TheSilkySmooth
TheSilkySmooth's Avatar
Add this to the list:
If you never did this I would change the trans/axle fluid. Also see if toyota has a water pump lube and conditioner to get that LL coolant to 100K w/o the pump failing. my 05 rav pump seal gave out at 60K - it shouldnt have.
Old 11-12-2009, 10:20 AM   #4
Lafiro
Drives: 06 Yaris Sedan
Im getting closer to that 60k mark. Would you know the exact list of tasks that the schedule calls for?
Old 11-12-2009, 11:43 AM   #5
YarisSedan
Drives: 08 Yaris Sedan
60k requires a oil change and tire rotation and thats about it.... Cost about 300 or more dollars at the dealer or about 30 or so dollars at a local independent shop.
Old 11-12-2009, 04:16 PM   #6
SilverGlow
Drives: 2007 Yaris Hatchback
There is no reason to do this at 60,000 miles, and doing so is a waste of time, and money.
Better to go with the owners manual and you'll see that the trans need not get flushed/fluid replaced until 100,000 miles. And no need to worry about the water pump. Just go with the manual and you'll be fine.
SilverGlow is offline   Reply With Quote
Old 11-13-2009, 03:15 AM   #7
firemachine69
School'er of hard knocks
Drives: Silver Yaris 4dr. HB
I don't know for you guys, but a transmission drain and fill service is required for us Canucks at 96000km's. (aka 60K miles).
Old 11-13-2009, 08:53 AM   #8
R2D2
Crazy Oil Sniffer
R2D2's Avatar
And in my opinion you will be better off for it. IIRC my manual doesn't even mention checking the fluid until 100 or 120k. I checked mine 4 miles up the road from the dealer the day I drove it off the lot..
I will do relatively frequent drain and fills. They are very inexpensive insurance for the DIYer. "Lifetime Fills" have more to do with marketing than engineering and anyone in their automotive relationship for the long haul would be well served by a little service once in a while.
R2
-The Fitful One
Old 11-13-2009, 05:25 PM   #9
SilverGlow
For what years Yaris?
Old 11-13-2009, 05:36 PM   #10
YarisSedan
R2
You cant do drain and fill on our transmission. They specifically state that the new type of transmission fluid in our cars can not be mixed with used/new has to be 100 percent replaced IE use a transmission flush machine.
Also draining the transmission only gets out about 3-4 quarts. The torque converters on our cars probally hold another 9-10 more quarts. So you are just diluting it. Its still going to be dirty. Put it this way. Take a cup of water. And put some mud in it. Its going to look brown. Then drain only a quarter of the water out and fill it with fresh clean water. Its still going to look brown. You wouldnt want to drink it until its 100 percent poored out and refilled with fresh clean water.
Old 11-14-2009, 10:14 AM   #11
R2D2
Crazy Oil Sniffer
R2D2's Avatar
I'm not going to drink it-I'm going to use it to keep a transmission alive. In the service manual it says nothing about mixing new or used fluid. By the logic above you could never top up-you would have to flush the trans if the level was low. The manual says to just top up. Also if the valve body needs to be removed according the service manual the pan is put back on and refilled-there is no mention of flushing the transmission ever unless unusually high levels of sediment are found.
There is a TSB out that warns against REUSING fluid that has been removed from the trans or possibly contaminated but that's just common sense. It also warns to keep WS tightly sealed as the fluid is hydrophilic like brake fluid.
The U340E holds 7.2 qts total and 3.1 qts in the pan so a drain and fill replaces nearly half the fluid volume which performed fairly regularly should keep the fluid pretty clean and much cleaner than never replacing it. If the fluid dosen't possess the despersancy to keep a considerable amount of contamination in suspension with drain and fills it certainly has no business being a "for life" product.
R2
-The Fitful One
Old 11-14-2009, 01:57 PM   #12
Red Horse
Red Horse's Avatar
Drives: 2008 Yaris sedan A/T
How transmission gets dirty?
Old 11-14-2009, 02:42 PM   #13
R2D2
Crazy Oil Sniffer
R2D2's Avatar
Not really "dirty" in the traditional sense but "contaminated" with friction material from clutches, wear metals and eventually the base fluid will oxidize and become acidic.
R2
-The Fitful One
Old 11-14-2009, 08:29 PM   #14
SilverGlow
There is never a need to top-off the auto tranny fluid. If the fluid needs topping off, then there is a leak someplace.
The correct maintenence on our auto-trannies is to remove all the fluid and replace it in it's entirety with fresh WS fluid, and this is best done with a special machine.
100,000 miles is the time to do it...50,000 thereafter, per the manual.
Stop with all this BS that runs contra to the manual already!!!
Old 11-14-2009, 09:41 PM   #15
R2D2
Crazy Oil Sniffer
R2D2's Avatar
Silverglow,
The intent of my posts were not to anger anyone. If you read my posts I made it clear the manual for my 2009 indicates to check the transmission fluid at either 100k or 120k (I can never remember which but I've got plenty of time to look it up again before I hit that kind of mileage). For my 09 that's it-its lifetime fluid and Toyota dosen't recommend changing it. I then voiced what MY intent is which is to do drain and fills. I then quoted the service manual regarding top up and valve body removal as examples that no mention is made in literature I can find that indicates a complete flush is required vs just adding new fluid. In other words I have seen no mention anywhere in my materials of the fact "new and unused" ws can't be added to ws that's already in use in the tranny. If anyone can point me toward where this is written and it applies to my 09 I will stand corrected and will be most appreciative.
Let me also restate I realize there is NO recommended transmission maintenance for my 09 other than inspection of the ATF at 100k or so and apologize if I confused anyone.
R2
-The Fitful One
Old 11-14-2009, 09:48 PM   #16
rningonfumes
rningonfumes's Avatar
Drives: Yaris Sedan 5MT
Question:
Is drain and flush also done on manuals?
Old 11-15-2009, 02:18 AM   #17
WolfWings
WolfWings's Avatar
Originally Posted by rningonfumes View Post
Question:
Changing the manual transmission fluid is no more complex than changing the engine oil:
1) Unscrew FILL plug on transmission first to make sure you can refill it later.
2) Unscrew DRAIN plug on transmission.
3) Wait until it's done gushing, drizzling, and finally dripping.
4) Put DRAIN plug back in. Torque with torque wrench.
5) Fill with 75W-90 GL4 or 75W-90 GL5 gear oil (CHECK YOUR MANUAL/DEALERSHIP FOR TYPE) until it dribbles out the fill hole.
6) Put FILL plug back in. Torque with torque wrench.
Old 11-15-2009, 02:33 AM   #18
rningonfumes
Thanks for the instructions Wolf, I ask because it means whether I do it myself or give it to a mechanic-- the need for flush that is. If I don't need a flush, I would just go a head and do it myself.
4-wheel alignment for 5000 mi. maintenance????? Yari-Chan General Yaris / Vitz Discussion 44 01-28-2011 09:00 PM
Why does 15000 service cost so much more than 5000 and 10000 mile service? monyaris DIY / Maintenance / Service 7 06-25-2009 07:12 PM
10,000 mile service lindstothek DIY / Maintenance / Service 7 01-21-2009 01:42 PM
30,000 mile service: Dealership or non-dealership? EstherK DIY / Maintenance / Service 1 11-12-2008 12:40 PM
Question about required maintenance gm830 DIY / Maintenance / Service 9 11-04-2008 03:14 PM
