#1 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 07 Yaris 3dr LB (Bayou Blue) Join Date: Oct 2008
bulbs behind headlight reflectors?
Are there small bulbs behind the side reflector on the front headlights?
not the ones on the actual body of the car... but inside the headlight. One side seems to be illuminated and the other not..... how to fix?
-Jen <3 ![]() Quote:
![]() ![]() ![]() ![]() Drives: '07 Yaris HB Join Date: Apr 2006
Yes there are. The only way to get at them is to remove the headlights ...
#3 | |
gosh..... that sucks..... do you have to remove the back part of the light too? ;[
You have to remove the front bumper to remove the headlights. It is actually quite easy - I removed mine to put in my Silverstar bulbs. Look at the lighting section of the service manual, which is posted in the DIY area. It walks you through removing the bumper and light assembly.
Oh, and no you don't have to remove the back of the light, you just twist the bulb socket and pull it out. |
#5 | |
what the bulb number or can I find that in the manual? :p
This thread has the list of all of the bulbs for the Yaris:
http://www.yarisworld.com/forums/sho...ght=bulb+guide |
#7 | ||
not if ya got a skinny hand.. its cake
You don't have to remove the bumper to remove a headlight.
Just remove the bumper retaining pins near the headlight and bend the bumper a bit to expose the one healight bolt that is under the bumper. It's relatively easy. |
| how to change headlight bulbs? | PETERPOOP | DIY / Maintenance / Service | 57 | 05-01-2016 05:06 PM |
| Replacing headlight bulbs | nsmitchell | DIY / Maintenance / Service | 47 | 02-14-2016 09:07 PM |
| Silverstar Ultra 9003/HB2 vs OEM headlight bulb comparison | CTScott | DIY / Maintenance / Service | 54 | 02-14-2011 08:58 AM |
| Yellow, Purple, Green Headlight BULBS? | jamal1984 | Cosmetic Modifications (Exterior/Interior) | 12 | 02-04-2007 08:30 AM |
