hook em
NEW SUSPENSION MODS!
upgraded rear springs to Skunk2 Fit springs and raised rear rates up from tanabe 2.2 to a beastly 6.2! then added some PG 13mm spacers and some EZ shims from MI. wheels are 15x6.5 +38
![]() ![]() ![]() Drives: '09 Yaris LB Join Date: Dec 2008
keeping the angle consistent with the pics would be a more 'honest' way to demonstrate the change, but the spacers look dope. nice
DKDC
Drives: Yarlet Join Date: Aug 2006
what springs are you running in the front?
did you have to modify those fit springs?
hook em
well..i "honestly" tried to get the exact same angle with the before and afters guy excuse me for being a little off....but the fronts are tanabe dfs and no i didnt have to modify the skunks to make them fit. unfortunatley they did create some unsightly wheel gap so i went against all things holy and trimmed them lol
#6 | |
Apexing Egg!!
nice to see someone else doing this! I got rear Fit springs from A&J racing and have been running them since september... great setup!
how much did you trim? I took a half a coil off
HighTach Motorsports 2007 Toyota Yaris-ARGH!! Mods: Tokico HTS, 6.6 kg F, 6.1 kg R custom springs, 23 mm RSB, 2-way TRD LSD, 15x7 +25 Team Dynamic wheels, 195/55/15 Dunlop Star Specs, Cobra Suzuka S |
#8 | |
is that safe???
EVERYBODY EVENTUALLY COMES BACK TO YARISWORLD...... |
I ♥ Yaris
Drives: Black 08 LB MT & red 97 Miata Join Date: Oct 2008
supposedly it is not safe... heating up the coil to cut it makes the metal brittle, and the shorter length, messes it up if it's progressive rate springs. Just what I read somewhere, but it makes sense.
The trouble with the world is that the stupid are cocksure and the intelligent are full of doubt. - Bertrand Russell |
Slowy getting there
I have cut springs before they don't heat up that much depending on what you cut them with. I use an airpowered cut off wheel and it only heats up a tiny bit.
hook em
i used a 4 inch grinder for lack of a better means and i took about a half coil. kngrsll you were my inspiration! i was wondering if you had to trim also. lol glad to see im not the only one doing something so taboo
#12 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 07 Yaris 3dr LB (Bayou Blue) Join Date: Oct 2008
side views maybe to see the drop????? :(
-Jen <3 ![]() Quote:
hook em
yea ill snap a few side shots in the morning w/ tanabe vs. skunks
#14 |
hook em
okay here are some side pics. the gap isnt as bad as i thought only a half inch, but it still looks like a 4x4 compared to what im used to looking at lol. keep in mind im running 195/50s and the springs havent settled yet, though i doubt the settle much being so stiff. the side by side of the springs doesn't really show how short they are either. they are easily an inch or more shorter.
#15 |
I ♥ Yaris
funny how the skunks look shorter, but the tanabes are a lower drop. I guess the Tanabes must be a lot softer...
#16 |
Well, the skunk2's still need to settle... I'm guessing they'll drop a bit more in the coming weeks.
I like how these new ones look.
--[ FORUM RULES ]--[ SEARCHING TIPS ]--[ EYELIDS PICS ]--[ RBK SPOILER ]--[ BEST/WORST INVESTMENTS ]--
#17 |
Apexing Egg!!
its all math dudes... http://www.engineersedge.com/calcula...spring_pop.htm
the tanabe spring is 125 lbs, the fit spring is 300 lbs. thats 2.5 times as much! that is a huge difference. and cutting it is not going to harm a thing, that is a crazy myth perpetuated by spring companies to make money. now, applying heat to compress coils, that may be dangerous. great job! any plans on what to do next? i ended up using generic coilover perches on the front with 375 lb springs and putting the rear sway bar back on. although i have not tracked it yet with this set up, i can tell you, it will be good!
#18 |
hook em
well correct me if im wrong but i thought for fwd cars in order to reduce understeer one would use stiffer springs in the rear and softer in the front...thats why i didnt go ahead and beast up the fronts...but if i am incorrect then perhaps something similar to your setup will be in my future
| Finishing my suspension | ChinoCharles | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 11 | 10-15-2011 10:26 PM |
| Suggestions for $300-$400 worth of mods please! | CtrlAltDefeat | Performance Modifications | 51 | 01-05-2011 10:15 AM |
| Sedan owners with full suspension mods? specifically all TRD | AdeJong 03 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 7 | 05-15-2010 01:13 PM |
| mods! mods! mods! | canadian_princess | Cosmetic Modifications (Exterior/Interior) | 32 | 08-23-2009 05:52 PM |
| Performance mods that won't affect/will hardly affect gas mileage?? | Mr.Yaris | Performance Modifications | 15 | 07-30-2007 01:32 AM |
