Old 12-04-2009, 01:56 AM   #1
pimp my yaris
C'est la vie
pimp my yaris's Avatar
Drives: 2009 2 door hatchback
pics of my drop springs install
First two pics are before install.
pimp my yaris is offline   Reply With Quote
Old 12-04-2009, 01:59 AM   #2
pimp my yaris
C'est la vie
Removing wheel and disconnecting sway bar links.
Old 12-04-2009, 02:05 AM   #3
pimp my yaris
C'est la vie
under hood with wiper motor and windsheild cowl removed.
Old 12-04-2009, 02:15 AM   #4
pimp my yaris
C'est la vie
My springs were megan racing springs, 1.5inch drop. Notice the height difference between front oem springs and Megan springs. Much more then 1.5inch and made me very nervous at first look. I needed to use spring compressors to remove stock springs. New springs could be installed with no compressor. Rear springs were only slightly shorter then oem springs.
Old 12-04-2009, 02:18 AM   #5
pimp my yaris
C'est la vie
Drop spring installed on oem strut.
Old 12-04-2009, 02:26 AM   #6
pimp my yaris
C'est la vie
I purchased strut cam bolts to correct camber settings during alignment, but camber was perfect and well within factory specs during alignment. These bolts were 40$ from local parts store. Since camber was within specs I later returned these bolts and reinstalled factory upper strut mount bolts. Only front toe needed to be adjusted during alignment.
Old 12-04-2009, 02:38 AM   #7
pimp my yaris
C'est la vie
This pic will show a small problem I had witch can be avoided with a little tip. When I removed the left front strut the spindle pulled on the drive axle and pulled on the inner axle boot to far and caused the axle to pop out of its yoke within the boot. You can see the boot is stretched in the pic. Make sure to support the spindle when the strut is removed with bunge cord or coat hanger to prevent this. I was able to pop this back into place but I almost ripped the boot witch would have been real shitty. Also only remove one side at a time so you will have a reference for correct installation!
Old 12-04-2009, 02:48 AM   #8
pimp my yaris
C'est la vie
Rear springs are cake to install and only took about 10 min. The rear of car will need to be supported on jack stands. Then support the center of the axle with your jack. Disconnect your rear shocks and lower the axle slightly so the shocks hang loose. You can then slide the old springs out and the new springs in place. Swing the axle back up with the jack and reconnect your shocks and your good to go!
Old 12-04-2009, 03:08 AM   #9
pimp my yaris
C'est la vie
This job can be completed with some basic mechanical knowlege and metric tools. You will also need a impact gun to remove top strut nut once spring is compressed. You can not hold strut shaft with vice grips or channel locks as you will scratch the shaft and when strut compresses over bumps the seal will be broken and U will have a blown strut. Also when removing drain tray under wiper motor, be careful as it is very sharp sheet metal and will slice you like a razor blade. I bought some cheap spring compressors from harbor freight tools. One needs to be carefully placed on each side of spring. This is also a little dangerous, be carefull, or have a shop complete this task. I am very happy with my new springs. Not to low and not to high. Ride is a little stiffer but not bad. Now this thing corners like its on rails
Old 12-04-2009, 03:12 AM   #10
pimp my yaris
C'est la vie
More pics
Old 12-04-2009, 03:13 AM   #11
pimp my yaris
C'est la vie
The white specs in the pics is the first snow of the season here in Chicago. I wish I lived in Miami!
Old 12-04-2009, 04:19 AM   #12
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
The snow flakes match the wheels and car , isn't that pretty
but seriously it looks great well done
Old 12-04-2009, 08:41 AM   #13
MUSKOKA800
MUSKOKA800's Avatar
Looks good!
Shame you didn't upgrade the dampers at the same time. Let us know how the stockers manage to control those shorter/stiffer springs. Is it bouncy at all?
Old 12-04-2009, 07:33 PM   #14
DandiDani
DandiDani's Avatar
beautiful!
Old 12-04-2009, 10:36 PM   #15
Ryu
The drop looks great !!
Old 12-09-2009, 12:57 AM   #16
taracor
Drives: 2009 5 Dr. Hatch
Very slick looking car. I love it.
taracor is offline   Reply With Quote
Old 12-09-2009, 06:15 AM   #17
evo165
evo165's Avatar
Drives: peArL yAvItZ!!
Send a message via MSN to evo165
Very nice drop on your car with Megan springs!! OEM spings look too TALL to attract any attention.
1NZ-FE Yaris with JDM RS front & rear bumper | JDM Vitz RS taillamp | JDM Vitz window visors | JDM Vitz Netz logos | JDM leather steering wheel & shift knob | 4k HID | K&N panel filter | Fujitsubo Wagolis exhaust | NST 10% crank pully | KYB Excel-G shocks | NF210 Springs | Cusco 4 points lower arm bar & Type OS top struct bar | RZCrew sub-frame collars | Ultra Racing 19mm rear sway bar & rear lower & center braces | PG Rear 13mm hub spacers | Exzess 2-pot calipers with 282mm rotors | Runstop Rear Disc | SSR Semi-Forge Type F 15" rims | Michelin Pilot Sport 3 195/55/15 tyres
evo165 is offline   Reply With Quote
DIY: Liftback Hood insulator install PICS auxmike DIY / Maintenance / Service 35 10-25-2020 08:16 PM
Lowered today on tein springs...pics and alignment question Brentorius Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 09-27-2009 03:28 PM
Megan Racing header install and review with pics. Herbicidal Performance Modifications 6 09-03-2009 09:40 AM
Pics of my AFE intake install + questions auxmike Performance Modifications 48 03-11-2009 06:39 AM
anyone have DIY install inst for lowering springs swapout??? Stargate YARlantIS General Yaris / Vitz Discussion 1 10-20-2008 04:18 PM
