Old 11-15-2006, 10:36 PM   #1
jbann
Drives: 07 yaris 3dr mblue
HELP Plsneed ecu diag/ecu pinout vvt-i controller install
Hey guys i need help need to find what wires are coming from ecu and im trying to hook up a few things and need to tap wires at the ecu. im installing a camcon vvt-i controller any help is great i kno u guys will come through
jbann is offline   Reply With Quote
Old 11-15-2006, 11:12 PM   #2
KSIbucky
KSIbucky's Avatar
Drives: 2007 Yaris manual dark silver
Send a message via AIM to KSIbucky Send a message via MSN to KSIbucky
http://rds.yahoo.com/_ylt=A9gnMiZB6V.../pe_camcon.htm
7 Color Tach
Fujita Intake
Momo pedals Shift knob and boot. Full TRD SSK.
Blitz exhaust
Megan Lowering Springs
(Next is DC Header)
KSIbucky is offline   Reply With Quote
Old 11-16-2006, 04:56 PM   #3
Katana
Katana's Avatar
Drives: Yaris LB 1.3lt 06
What are you planning to do???
Old 11-16-2006, 08:48 PM   #4
jbann
I jsut need to wire up the camcon to the vvt-i signal, a/f signal and rpm+/- signal
Old 11-16-2006, 10:42 PM   #5
Black Yaris
der Zeck
Black Yaris's Avatar
the hip bone's connected to the theigh bone.... the theigh bone's connected to the..... what the hell is going on here?
Old 11-16-2006, 10:29 PM   #6
Lafiro
Drives: 06 Yaris Sedan
2nd that question..
Old 11-17-2006, 02:05 AM   #7
Sounds like a device to override the default VVTi engagement point, to tweak the response of the engine... Let us know how it works out, I'm quite interested in this!
Old 11-17-2006, 08:51 AM   #8
Katana
Katana's Avatar
Some guys in Greece tried that out and unfortunately it did not gave very good results.
Old 11-17-2006, 11:06 PM   #9
jbann
Yeah it controls are vvti engagement like vtec controller and controls a/f
Old 11-17-2006, 11:32 PM   #10
Thirty-Nine
Small cars are a big deal
Thirty-Nine's Avatar
Woah, woah. VVTi doesn't engage like VTEC. That's VVTL-i.
VVTi is continuously running. From what I understand, this is basically an air/fuel controller, similar to the Apex SFAC.
Old 11-18-2006, 10:12 AM   #11
Toyotech
Your Toyota Technician
Drives: 06 Cobalt SS/SC, 06 Rolla S
Send a message via AIM to Toyotech
vvti is similar and if it not continuously running... its oil pressure activated.
the camcon does not show such good gains on the 1zz so i doubt you will see much on the 1nz
Toyotech is offline   Reply With Quote
Old 11-20-2006, 11:15 PM   #12
jbann
thanks everyone for replies dont my sole point of the camcon is to make minor adjustments to vvt-i and a/f ratio not to extract mass hp from it, these adjustments also make the car more efficient, want to strength the entire rpm band, mods so far intake, 4-2-1 header obx(scion xb) custom installed with 2" piping removing 2nd cat n resonator. just need ecu diagrams thats it will post my results, thanks
Old 11-18-2006, 03:36 AM   #13
Katana
Katana's Avatar
And the gains in HP aren't that much...
