Old 02-24-2010, 08:52 AM   #1
rossman
Drives: 2006 YARIS RS
ABS LIGHT & E BRAKE LIGHT
Hi,
I started my car this morning and the e break light did not turn off and the abs light was on. When I was coming to a complete stop the ABS was kicking in even though I was not slideing? It only happened a few times, then stopped but the lights are both still on.
I then tried to slam the break in the snow to see if the abs would kick in...but no luck, it seems like the abs stopped working.
Any ideas? Has anyone come across this issue?
Thanks
A.R
rossman is offline   Reply With Quote
Old 02-24-2010, 09:42 AM   #2
Get a coffee and read on.
http://www.yarisworld.com/forums/showthread.php?t=11533
http://www.yarisworld.com/forums/showthread.php?t=11355
Old 02-24-2010, 10:40 AM   #3
rossman
Thanks
Old 02-24-2010, 12:05 PM   #4
devinlamothe
devinlamothe's Avatar
Drives: '07 Yaris HB
Welcome to our wonderful world of broken speed sensors and wiring harnesses.
devinlamothe is offline   Reply With Quote
Old 02-25-2010, 07:37 AM   #5
41magmag41
Drives: Loaded 2007 mica silver sedan
Yup, read the above links. I too have had the same problem here in New Hampshire. Parts have been on back order for 2 months. If you have less than 36000 miles on the car it will be taken care under warrany and a TSB posted in June of O8. If not and you don't have the extended warranty it'll cost you between 300 to 500 dollars PER side to fix. Talk with your dealer. Brakes will still work but the ABS will not work. Lights may go out in a day or so or they may not. Good luck
41magmag41 is offline   Reply With Quote
Old 02-25-2010, 11:09 PM   #6
severous01
hey, better than bmw with their fiber optic network and broken hardware....not to mention their continusous upgrades to software.
sorry, bmw tech
The Basics on Brake Upgrades kngrsll Performance Modifications 56 03-06-2024 08:50 AM
HELP! ABS & BRAKE LIGHT ON SIMULTANEOUSLY! mizhgolightly DIY / Maintenance / Service 45 05-03-2022 02:59 PM
How many forum posters does it take to change a light bulb? silver_echo Off-topic / Other Cars / Everything else Discussions 25 06-27-2011 01:50 AM
Emergency brake light is on constantly AdeJong 03 DIY / Maintenance / Service 9 10-10-2009 09:32 PM
Dealer: Disabling the seat belt chime is now illegal? schleppy Cosmetic Modifications (Exterior/Interior) 13 04-18-2009 04:43 PM
