Old 03-22-2010, 04:10 PM   #1
DevilGirl
Drives: 09 3dr LB MT
tpms
I've looked and tried to find the answer before asking:
Is there a DIY way to have the car's ECU re-learn a new set of TPMS without having to go somewhere and have it done?
Old 03-22-2010, 04:31 PM   #2
Cosmonaut
The Last Baron
Cosmonaut's Avatar
Drives: 09 Polar White HB
I only remember seeing a DYI disable for them.
Sanction this outbreak, a Virus conspires. Single sparks are Spectral Fires!
| UR 19mm sway |
Cosmonaut is offline   Reply With Quote
Old 03-22-2010, 04:39 PM   #3
The TPWS can only learn new sensors with the use of a service tool. Most tire shops (and of course dealers can do it).
Old 03-23-2010, 07:21 AM   #4
DevilGirl
Do you happen to know what the service tool is? My fiance has a crap load of tools from when he used to work as a mechanic, so it's possible he has it already. That's the main reason I asked.
Old 03-23-2010, 07:54 AM   #5
Not a mechanical tool, but an electronic one - Either the Toyota TechStream tool or a TPMS diagnostic tool.
Old 03-23-2010, 09:48 AM   #6
zachryboles
Chunk love Yarii
Drives: 2008 Silver 3DR Yaris Liftback
ok honest question here.... does it matter if you dont use your sensors at all on aftermarket wheels?
zachryboles is offline   Reply With Quote
Old 03-23-2010, 09:55 AM   #7
Rick
Drives: '08 Yaris LB 5M
Does it matter? To a Federal Bureaucrat it matters. To me, ..... I just disabled the TPMS and have no sensors at all in my aftermarket summer wheels. My winter wheels still have them but they are just useless rotating mass now.
Rick is offline   Reply With Quote
Old 03-23-2010, 10:36 AM   #8
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
If it doesn't bother you to have that low tire pressure warning light constantly lit, and you'll keep your tire pressure checked regularly, it's no biggie.
Old 03-23-2010, 10:42 AM   #9
zachryboles
Chunk love Yarii
well then i dont really care....... i take good care of my vehicle
Old 03-23-2010, 11:56 AM   #10
Yaris Hilton
Smile
I don't like having the TPMS as it is. But wouldn't it be cool if it would give you a readout of the actual pressure in each tire?
Old 03-23-2010, 12:31 PM   #11
schleppy
I love momentum.
schleppy's Avatar
Drives: 2009 Yaris LB, Red
So far as I know, every time you change wheels (if going between winter/summer), you have to pay to have the TPMS re-calibrated. And because of that I simply disabled mine. I check my tires pressures regularly, I don't need a (generally useless) electronic babysitter.
Old 03-23-2010, 12:38 PM   #12
sex
sex's Avatar
Drives: 09 5DR
tirerack.com sells the ATEQ TPM QuickSet Reset Tool for $135. luck123@toyotanation has a review of it
http://www.toyotanation.com/forum/sh...d.php?t=299107
http://www.tirerack.com/accessories/detail.jsp?ID=163
sex is offline   Reply With Quote
Old 03-23-2010, 12:49 PM   #13
It would - They report pressure and temperature, so it would be very cool to have a live display of both for each tire. One of these days I'll figure out the protocol for the Yaris TPWS and make a device to do so. Crashy will be my test platform, since she has my 09 steelies with the sensors. Both of my sets of alloys that I run on my 09 are sensor free.
Old 03-23-2010, 02:23 PM   #14
bronsin
bronsin's Avatar
Hmmm sounds suspiciously like mirror mounted turn signals...
Old 03-23-2010, 03:10 PM   #15
fiia
fiia's Avatar
Drives: 09 Flint Mica Sedan
how did you disable your TPMS? I'm looking for a solution to end once and for all the constant tire pressure light. I didnt get the sensors installed on my after market rims..and don't want to deal with the light anymore
fiia is offline   Reply With Quote
Old 03-23-2010, 03:17 PM   #16
http://www.yarisworld.com/forums/sho...iy+tpws&page=7
Jump right to post #115
Old 03-23-2010, 03:39 PM   #17
fiia
fiia's Avatar
so, in a nutshell, just cut the brown wire?
i read your original post then the pg 3 info w/ all the parts from radio shack...post 115 just looks like the brown wire was cut and tied to the white wire #6. is this correct?
and if so, what did you use to connect the brown and white wires?
Old 03-23-2010, 03:45 PM   #18
I went through a couple iterations of the mod and then one day realized that the simplest method was what I drew in 115.
You are correct with simply cutting the brown and connecting it to the white. You can use a simple tap splice connector to do it (available from any autoparts store).
Tire rotation: Does TPMS recognize tire position? jcdrotos Wheels, Tires and Suspension Forum sponsored by The Tire Rack 17 03-17-2011 02:00 PM
tpms compatibility? bwong2 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 8 07-11-2009 09:33 AM
TPMS Gauges - do they exist? Sodium Duck DIY / Maintenance / Service 24 03-01-2009 12:18 AM
15" TPMS friendly wheels for my '08. Ideas? auxmike Wheels, Tires and Suspension Forum sponsored by The Tire Rack 7 12-08-2008 08:01 PM
TPMS TinyGiant Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 10-22-2008 03:57 PM
