![]() ![]() Drives: 2010 Yaris Sedan Join Date: Mar 2010
Optimal MT shift points.
So I'm just wondering when taking off in first gear I'm trying to find the best RPM to engage the clutch at with out hurting the transmission/clutch. Also what does everyone else shift at?
Joey
Drives: '14 Scion xD 5-speed Join Date: Oct 2008
Search button is your friend
Formerly owned Met-Met. '07 Yaris LB 5-speed. A forum post should be like a skirt: Long enough to cover the subject but short enough to keep things interesting. "I don't have an anger problem. I have an idiot problem." -Hank Hill |
Steals terrorist's lunch
Drives: 2007 Yaris Liftback Join Date: Mar 2007
Welcome to YarisWorld, 10DG22.
![]() I always shift at 2k RPM unless I'm merging onto the highway, in which case I allow for 2,400 RPM. On steep grades, such as in the mountains, I shift at 2,600 RPM in order to keep some torque.
- Brian Share the Road I often carry 2 carpool passengers and mountain bikes or snowboards/skis over a 4,500 foot elevation difference. Click the graphic above to see my detailed mileage logs. |
Thanks a lot.
![]() ![]() Drives: Black 5-Spd Sedan S Join Date: Aug 2009
I have the clutch fully engaged under 1,100 RPM. Generally what I do is when letting the clutch out at the very moment it starts catching I give some gas (very little), but continue engaging clutch staying around 1,000 RPM or so. This all happens quickly of course, maybe 1 second? - my goal is to engage the clutch as quickly as possible, and at as low an RPM as possible (without dipping below idle RPM). To me, this will make the most of clutch life. Once I have the clutch engaged it's another story though, I usually accelerate pretty "spirited."
Shift points totally depend...sometimes I play the 2,000 RPM game like BailOut, but usually it's just all about surrounding environment - that's what so perfect about manual transmissions, the shift points happen exactly when and where you want them to, 100% of the time. Don't worry too much about it - listen to what the car tells you and enjoy the drive! |
#6 | |
![]() ![]() Drives: '10 3D Liftback Join Date: Mar 2010
"Stealth Runner"
6500 rpm is the absolute best!
![]() ![]() Drives: 2007 Yaris Sedan (5pd) Join Date: Mar 2010
I shift out of first between 2500 and 3000, and second through fourth at 2500. On braking it really depends how far I have to travel, if traffic's light and the light is red a quarter mile ahead, I go in to neutral and coast, If I am coming of the interstate I leave it in 5th and downshift to fourth around 30, then go to neutral. I have no idea if this is 'optimal' but I get a solid 39mpg in ver cold MN winters and 42-43 in the summer.
#9 | |
![]() ![]() ![]() Drives: 2010 Prius, 2007 Yaris Sedan Join Date: Oct 2009
Debatable. It really depends on how far away that red light/stop sign/etc is. There is a point at which coasting is going to be more efficient than downshifting. Downshifting is practical if I need to come to a stop, or want to casually reduce speed without using the brakes, but if a light has turned green and I know that by the time I get to the light 1/4 or 1/2 mile away all the cars in front of me are up to speed it makes more sense to coast. Think of it this way: Lets assume the speed limit is 55. Am I really saving fuel by leaving the car in gear or downshifting to obtain DFCO and I lose 20 mph of speed (at which point traffic ahead is moving sufficiently to speed up) only to have to accelerate the 20 mph back to 55. If the car was in neutral I may only lose 5 mph over the same distance. Although the engine was burning fuel by idling rather than DFCO, I only need to accelerate 5 mph. You are never going to use more fuel, in any car, than during acceleration. So while your point if valid, if you need to stop or decelerate quicker, it really depends on the distance involved.
#11 | |
The OP is looking for the optimal shift points as it concerns fuel efficiency. The RPMs you listed are much too high for that. In fact, the RPMs you listed are where I shift while accelerating from zero on a 6% grade!
Thanks for everyone's input.
#14 |
My last tank yielded me 36.7MPG (US) with shifts anywhere from 2700-6000rpm. Most of my driving was conservative, but some was WOT having fun with the new 6spd.
So shifting higher doesn't affect MPG as much as you'd think. The higher you rev the motor (to a point at around 3500-4000) the more efficient it is at producing torque. Bogging the motor below 2000 only causes the timing to retard to prevent detonation which decreases it efficiency. |
#15 | |
Higher RPM always means more fuel usage, and bogging is a thing of the past for the most part. Modern ECUs simply retard the timing to match the state of things. In almost 60k miles of hypermiling the Yaris in the mountains I have never heard the engine bog.
#16 |
Only Happy When it Rains
you shouldn't really worry about hurting the clutch. I think it's been proven that the clutch/transmission in the yaris is rather rock solid, like most toyota's.
i also tend to shift around 2000 rpm's.
Colin Chapman disciple |
#17 |
![]() ![]() ![]() Drives: 2007 Yaris Hatchback Join Date: Jan 2010
I always kinda feather the gas while releasing the clutch. No idea on RPM's as I dont have a tach. Probably between 2,500 and 3,000.
1st to 2nd at 15MPH 2nd to 3rd around 35MPH 3rd to 4th around 50 MPH 5th at 60MPH I have 85,000 miles. My last truck was a Ram 1500 V-6 5 speed and I always shifted at the top of the power band. Never tried to save gas and shift early. Hell, a few times I hit 70MPH in 3rd gear. It was high geared. Point is I never lugged it always shifted at same speeds/RPM's and the truck loved it. I sold it at 264,000 miles and still ran great. The Yaris is on it's way to that record |
#18 | |
"LibertyRides!"
Drives: 2010 Yaris 3Dr LB | 2020 Stang Join Date: Mar 2010
I generally don't watch my MPH, but all the time I look at my tach. I think my shifts are roughly? 1st to 2nd at 10MPH 2nd to 3rd around 25MPH 3rd to 4th around 30 MPH 5th at around 40MPH My environment is big valleys and small mountains... the Northern Alleghenies of PA. When I'm level I shift between 1,600 to 1,900 RPM... Hills and ramps around 2,000 to 2,200... PA mountains around 2,300... Shifts are with nothing in the car except me @ 160 lbs. Little higher when I have weight.
~ Mark ~ 2010 Yaris 3-Dr Liftback, 5-Speed Manual, P185/60R 15, Bayou Blue Pearl I Love my YARIS Most miles Tank: 538 tank/10.148 gal = 53.015 MPG / Most MPG: 54.95 MPG (ethanol) 425 tank/7.73 gal "The evils of government are directly proportional to the tolerance of the people." -- Frank Kent |
| Back to school sale Short shifter, Shift Knob, EVERYTHING is on sale! | TWM Performance | TWM Performance | 13 | 09-29-2009 10:55 AM |
| Classic shift knob from TWM Performance now available with engraved shift patterns! | TWM Performance | TWM Performance | 0 | 07-21-2009 10:57 AM |
| TWM Performance weighted shift knobs on sale! | TWM Performance | TWM Performance | 5 | 06-30-2009 09:58 AM |
| New shift knobs available from TWM Performance! | TWM Performance | TWM Performance | 3 | 06-25-2009 04:24 PM |
| October sale on TWM Performance shift knobs! | TWM Performance | TWM Performance | 1 | 10-31-2008 05:01 PM |
