Old 03-22-2010, 10:37 PM   #1
jaimico
Drives: yaris advance
Low rpms with a new battery
Yesterday my 2008 yaris sedan battery just past the way, and I replaced it with a bigger model (from 350 to 500 cca), since I could not find the same size or capacity as the original.
To my surprice, after replacing the battery, I started the car right away, but the rpms just when to the minimum, like 300-500 at idle (normally are around 700), it was like having a 3 cilinder engine, let it run for a while, but did not change, so i took it for a good run, and still the rpms where dropping at idle, and suddenly it just came back to normal.
Today i had my 50K maintenance, and when I came home disconected the battery to adjust the supports, and when I started the car again , the same problem again, but this time at a smaller rate (the rpms where around 500 know).
So, is it something with the car computer the need to adjust after a while, or what??, since the alternator was chargin normally.
jaimico is offline   Reply With Quote
Electrical System Upgrade Advice sqcomp In Car Entertainment + Electronics (audio / video / alarm) 6 03-23-2016 01:15 AM
DIY: Braille Battery install texkid DIY / Maintenance / Service 39 02-19-2013 02:40 PM
Installation of a Battery Isolator frostbitten In Car Entertainment + Electronics (audio / video / alarm) 3 10-07-2009 12:11 PM
FS: not a car... 2004 600rr low miles (SoCal) AdeJong 03 Cars for Sale by private party 8 09-25-2009 11:13 AM
Keep your vehicle protected! sqcomp In Car Entertainment + Electronics (audio / video / alarm) 17 09-10-2009 02:02 AM
