Old 03-16-2010, 03:00 PM   #1
Slick
Slick's Avatar
Drives: '09 3-Dr
Send a message via MSN to Slick
I have a interesting question for everyone...
How much sound abuse can air bags take before the deploy? For example, I have all the airbags, could they take like 150 db without any problems? I realize I wouldn't be listening to 150 db as a dd. But does anyone know the amount of abuse an airbag can take before it explodes?
They may not do anything except enjoy the massage lol. But they also may deploy going 70 down the freeway.
My system pushes a little less than 120 db, so I know it can handle that. My steering wheel and dash rattle but nothing has happened yet.
So, any thoughts? Thanks in advance.
In a world... where things squeak, wont fit,start to bleed, or are just plain hard to do.... ArmorAll will fix that
Slick is offline   Reply With Quote
Old 03-16-2010, 04:07 PM   #2
sqcomp
Roadrunner Jr.
sqcomp's Avatar
Don't the airbags deploy based off sensors close to the exterior of the vehicle?
One sniping comment...
I KNOW you have got to be doing more than 120 dB. I metered 136 dB at a competition with just two sealed 15" D series Solobarics and two ZR 360 amps back in the day...
― Thomas Paine
Old 03-16-2010, 04:10 PM   #3
I haven't found a spec for the force required to pop the Yaris' airbags, but the sensors are accelerometers. The CPU monitoring them must be able to distinguish between normal road bumps and vibrations and the impact force of a crash. I don't believe that a stereo system could induce force with a high enough amplitude in the proper direction to make one of the sensors think that a collision occurred.
Old 03-17-2010, 01:47 AM   #4
Slick
Slick's Avatar
Drives: '09 3-Dr
@sq- idk for sure what it makes. I knew for a fact more than a hundred, but I haven't listened to too many 130-140 db notes so i wouldn't know how to judge it. I figured 120 was at least near the ball park lol
@ct- accelerometers u say... Neat lol. Out if curiosity, is there a way to disarm the airbags all together? Like make a toggle switch or something?
Old 03-17-2010, 08:42 AM   #5
You could selectively disable the SRS using a switch on the power feed to the SRS ECU.
Old 03-17-2010, 12:00 PM   #6
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
Sounds pressure just isn't that strong.
I had my mazda meter over 140dB on the Termlab meter which is the stiffest and most accurate spl meter. No air bag problems... However, I couldn't get the deck to keep from skipping, The score would've been higher had the deck not kept skipping.
Old 03-17-2010, 03:24 AM   #7
sqcomp
Roadrunner Jr.
sqcomp's Avatar
Come on man! You're in Texas...they have to have some big boy SPL rigs out there.
― Thomas Paine
Old 03-17-2010, 02:09 PM   #8
90tsi
90tsi's Avatar
Drives: 09 yaris
i have crushed the frontend of an 07 but my bags never deployed and my 2 12s i have ran around 132db and they never deployied. i used to have the pic of as avatar. so im sure it takes quite a bit.
90tsi is offline   Reply With Quote
Old 03-17-2010, 02:29 PM   #9
127.0.0.1
soundwaves that could set off an airbag sensor
would need to be well above lethal pressures, such
as from sonic-boom stun-guns called "Thunder Generator cannons"
Old 03-17-2010, 11:14 PM   #10
sbergman27
sbergman27's Avatar
Drives: 2008 Yaris Sedan
Originally Posted by 127.0.0.1 View Post
soundwaves that could set off an airbag sensor would need to be well above lethal pressures, such as from sonic-boom stun-guns called "Thunder Generator cannons"
I live along a major thoroughfare in Oklahoma City, and I think we get one or two of those cruising by per night.
-Steve
sbergman27 is offline   Reply With Quote
Old 03-17-2010, 04:24 PM   #11
Mobius1
Installer
Mobius1's Avatar
Drives: 2008 Yaris HB
worst question ever
Mobius1 is offline   Reply With Quote
Old 03-17-2010, 10:59 PM   #12
Slick
Slick's Avatar
Drives: '09 3-Dr
Well, that's all I needed to know. Thanks for the useful and useless info :D
@sq - I didn't say there was a lack of hard hitters. It's just a lack of medium hitters lol.
@Mobius - there are no stupid questions... only stupid answers.
Old 04-16-2010, 09:13 PM   #13
Malifabian
Malifabian's Avatar
Drives: Yaris Sedan 2008
I havent found anything in regards to sound that would make your Airbags deploy
Malifabian is offline   Reply With Quote
Old 04-17-2010, 04:24 PM   #14
goku87
goku87's Avatar
Drives: Black HB
I once screamed @ 126 dB.
goku87 is offline   Reply With Quote
Voltage regulator and Amperage question... cr.chango DIY / Maintenance / Service 13 11-24-2009 12:59 PM
ctrl-alt-delete question & free anti-virus question Shroomster Off-topic / Other Cars / Everything else Discussions 18 09-08-2009 03:57 AM
Amplifier Watt Question....noob question hasher22 In Car Entertainment + Electronics (audio / video / alarm) 4 09-27-2007 03:59 PM
AUX connector for Toyota Yaris (EU markets) and another interesting question api In Car Entertainment + Electronics (audio / video / alarm) 4 08-30-2007 12:00 PM
