Old 05-03-2011, 04:11 PM   #1
SKurj
Drives: 09 Yaris 3dr HB, BRZ
Tein Springs - Cut Bumpstop? 3dr
With my echo I never bothered, didn't know whether we needed to either.
Anyways, I received a set of Tokico blues and Tein Springs (thanks Garm) today, and will be putting them on myself (Brother did the echo, i held the beer..)
So, is cutting the bumpstop neccessary for this application?
Thanks
SKurj is offline   Reply With Quote
Old 05-03-2011, 04:28 PM   #2
marlondog
Shut your fricken suck!!!
marlondog's Avatar
Drives: 07' liftback
Thanks
I had Tein's and cut the bumpstops according to regs. When I removed them to replace them with coilovers, I noticed that both bumpstops were FUBAR. I would leave the bumpstops alone for a couple of months. If you don"t feel like your cars struts are gonna break off, then there's no problem.
marlondog is offline   Reply With Quote
Old 05-03-2011, 04:47 PM   #3
SKurj
Thanks,
Can't find anythign on the website or in the box they came in so was at a bit of a loss.
Old 05-04-2011, 02:16 AM   #4
Dperry
Dperry's Avatar
Drives: 2007 black yaris hb
im running tein stechs and tokico blues been for several months now...i cut the bumpstops just below the plastic bushing ring thing...you will see what im talked about wen you get ur bumpstop out. u do need to cut them because the tein springs are soft so u will compress and hit ut bumpstops if you dont. i havent had any problems with bottoming out yet so thers my 2 cents
Dperry is offline   Reply With Quote
Old 05-05-2011, 06:03 PM   #5
Viperoni
Drives: 2005 Toyota Echo
Frankly, I'd rather protect the strut from bottoming than have a slightly more comfortable ride.
2006 Saturn Ion Redline
Old 05-05-2011, 09:08 PM   #6
mazilla
advocatus diaboli
mazilla's Avatar
Drives: 07 Yaris hatch
The issue IME is when your traveling fast with a heavy load, you hit a large dip and break your back(not literally) when the car comes to a sudden stop halfway through it. Other than that it's probably not going to be a problem leaving them longer.
I did cut mine when I installed my DF's on factory shocks because I was worried they would be super bouncy and keep slamming me around.
-Type 07 FFL-
My odometer 03/11
Old 05-09-2011, 11:33 PM   #7
SAV912
Pirate Yaaaaris
SAV912's Avatar
When I did TRD springs and struts, I did not cut them. If you have the accompanying shocks with the springs, it's not necessary to cut the stops. If you're doing just springs, then you might want to cut the stops. That's what I've heard. There are so many different opinions on this matter though.
Georgia Bulldogs!
'09 Yaris LB 5MT Sold.
Old 05-10-2011, 08:41 AM   #8
SKurj
In the end I didn't cut them I am going to see how it goes. The car has a 2nd person in it maybe 2x a year, and the only time it has a load in it is when I take the winter wheels to the stealership to have them mounted (no charge of course!)
Old 05-10-2011, 09:14 AM   #9
you should have cut them...but with that kind of drop, your wheels will likely rub before you hit the bump stop
Old 05-10-2011, 11:36 AM   #10
marlondog
marlondog's Avatar
Let us know in a couple of weeks how things are going.
Old 05-10-2011, 02:57 PM   #11
SKurj
I had Teins on my echo hb and didn't cut bumpstops, I can recall hitting the bumpstop maybe once in the 5 years I had it. It would rub at the front on rare occasions (195/50/15's on ET38 rims at least i think that was the offset) but it would have to be extreme for it to happen. The echo actually sat lower than the Yaris is so far.
Not been using the car much since I did it, on vacation and have the place to myself so being a bum for a week!
Can't wait for the wheels to arrive... then to see if 17 " ET42 will work with/without 10mm spacers in the rear..
Done! D2 Brake System, Tein Springs and H&R Wheel Spacers Installed RedVitz Photo-Video-Media Gallery 18 10-09-2010 03:36 PM
Tein S-tech Springs with Stock shocks combination. daddz07 California 11 08-21-2010 01:49 PM
Tein S-tech Springs with Stock shocks combination. daddz07 Performance Modifications 1 08-09-2010 03:45 PM
TEIN S-Tech Springs *NOW AVAILABLE* EnduroMTS Sponsors Classifieds Area 1 10-12-2006 02:08 PM
