Old 05-28-2010, 10:30 AM   #1
trx73
Drives: 2006 Toyota Yaris Silver Hatch
205 45 16
Hey there, I just bought a 2006 Yaris and picked up 16x7 rims with no offset. I am torn on what size tires to get. I am worried that 205 45 16 will leave too much of a gap in the wheel well and if I go 205 50 16 I am worried about rubbing . I don't plan on lowering the car for some time but I still want it too look good. Any thoughts???
trx73 is offline   Reply With Quote
Old 05-28-2010, 10:42 AM   #2
MUSKOKA800
MUSKOKA800's Avatar
Zero offset and rubbing may be synonymous for a Yaris. 35-45 mm offset is the norm.
Old 05-28-2010, 10:43 AM   #3
i run 205-45-16's....pic while on coilovers with about 2" drop front/rear
on eibach sportlines...1.25/1.5" f/r drop
Old 05-28-2010, 01:46 PM   #4
trx73
Think I could get away with 205 50 16 with zero offset??
Old 05-28-2010, 01:50 PM   #5
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Maybe if you don't put tires on at all you MIGHT not have rubbing issues, but it won't matter what tire you put on it'll rub. Zero offset put rim outside of the fenders entirely.
Old 05-28-2010, 01:53 PM   #6
trx73
I am assuming it is zero offset as I am sure it would be stamped on the back...wouldn't it??? Sorry I am very new to this. Is there another way to tell. I bought them used and they came from a civic.
Old 05-28-2010, 02:02 PM   #7
take a hi resolution pick of the back of the wheel....and maybe the front too?
Old 05-28-2010, 02:27 PM   #8
severous01
with a tape on the hub.
i'm sure there's some offset, it's extremely rare to find rims with no offset. those are like truck wheels or something...
Old 05-28-2010, 09:43 PM   #9
kimona
kimona's Avatar
Drives: 2014 White VITZ
What is the make/model of the wheels? Post some photos.
The offset is often stamped on the back of the wheel.
Old 05-28-2010, 10:29 PM   #10
ddongbap
WHAT THE FUCK THAT FIRST PICTURE IS SO COOL BARBRA.
Old 05-29-2010, 12:22 AM   #11
Billiam
Drives: '10 White Yaris 4D LB
Long exposure + "painting" with a flashlight = what you see in the pic.
Old 05-29-2010, 01:40 AM   #12
Bluevitz-rs
I'm ginna try that sometime.
Old 06-06-2010, 08:49 PM   #13
trx73
I just got rims back and stamped on the back is "ET 38" is this the offset???
Old 06-06-2010, 08:50 PM   #14
Bluevitz-rs
Yes.
Old 06-06-2010, 08:51 PM   #15
trx73
If so 205 50 16 or 205 45 16 without dropping. I don't want too much space in the wheel well.
Old 06-06-2010, 08:57 PM   #16
Bluevitz-rs
What is you stock tire size?
Old 06-06-2010, 09:02 PM   #17
trx73
175 65 14
Old 06-06-2010, 09:10 PM   #18
Bluevitz-rs
Ok, then you'd want 205/45 16 to keep it as similar to stock as possible. I personally went with 205/40 16, but my transmission has a different speed sensor ratio in so it still reads the same as stock.
With 205/50 16 you'd loose some acceleration because of the larger rotation and your speedo would be reading slower. (good if you need to trade the car in at some point though LOL)
Official YARIS Wheel & Tire Guide Black Yaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 403 08-10-2025 12:20 AM
205 50 17 dun1237 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 04-02-2010 12:29 AM
new tires Creeper Wheels, Tires and Suspension Forum sponsored by The Tire Rack 22 04-25-2009 01:03 PM
15" Konig Heliums+tire weight info CASTREX Wheels, Tires and Suspension Forum sponsored by The Tire Rack 52 02-26-2007 09:38 PM
which size tires for 16" rims? tekmoe Wheels, Tires and Suspension Forum sponsored by The Tire Rack 20 01-28-2007 08:12 PM
