toyota
UPDATE on PG spacer.. 13mm left/10mm right
for future fitting for new user..try to have the left rear 4mm more than the right to make it even vs right rear wheel spacing only for hatchbacks.. i cannot confirm sedans...
AS we all know our yaris hatchback had issues with left rear being tucked in more than the right so i did the unexpected and ordered 2 offset spacers fr garm.. 1x 13mm (which goes on the left and 1x10mm for the right.. guest what..almost had it to match..i figures the left is about 4mm-5mm off but the extra 3mm did come close.. also confirmed that its the frame thats crooked not the body. the way i did this was to lined up the front tires/rims to the back noticeably off from the front also comparative to the right side.. now the 2nd issue with 13mm on the left and 10mm on the right is i still rub on both sides during dips..hitting a small lip connecting the metal frame to the plastic rear bumper..good thing is its almost even hit might be off by 2 mm so now dont know what to do. by the way im running 205/50/16 +40 offset on a trd spring 1. spend $70 to roll UP LESS THAN 2 inch LENGTH lip issue 2. roll it my self using bat or something or just use pliers and fold it up.. 3. grind it Last edited by marcus; 06-10-2010 at 11:24 AM. |
Add camber. I just finished doing mine 20 minutes ago.
Cost: $4 for stainless steel washers.
toyota
i did have that shim..it came with it just didnt end up putting it..i kinna want it straight rather than tilted....still contemplating..plus you may have different tire setup and frame on the sedan maybe ok..but i know hatch has crooked frame issue off the warehouse
Tilt is barely noticeable.
toyota
hmmm now i dont know if i should open this up again... but now sure if that 1 degree will make a difference..
by the way did you notice the left rear was pushed in more than the right..check it out. |
Yes, that is why I added camber. To deal with the rub on the right side. And I don't have a sedan.
If you are still rubbing after installing the shims, it will atleast be less severe. That way, any further measures you take to eliminate rub will be less drastic.
toyota
cool... let me try to grind that small piece.. if still rubbing then i have no choice but to add that shim..
toyota
pix loaded..
Super Newbie
Drives: 2007 Yaris Liftback White Join Date: Jul 2007
grind away and then add shim....lip is too small and part of it is plastic...usually rubs where the bumper and fender meet. Little bit of camber won't hurt and can improve performance.
If those 2 don't work, get shocks if you only have TRD springs. |
toyota
ok i grinded a 2 inch length and about 3 mm under neath where the metal and the plastic bumper meets..so far so good.. did a metal seal then painted... surprise it came out clean..but so far no rubs yet on dips..but we will see what happen if i put 2 person on the back..
| (Wood) TB Spacer for Yaris | Y@R15 | Performance Modifications | 13 | 10-01-2009 04:31 PM |
| Wheel/hub spacer, PLS help | evo165 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 4 | 08-18-2009 02:21 AM |
| Toyota Throttle Body Spacer: the Best Fuel-Saving Device | davidmills | Performance Modifications | 1 | 07-01-2007 11:38 PM |
| Quality Chrome license Plate Frame? | blacksan | Cosmetic Modifications (Exterior/Interior) | 2 | 05-08-2007 07:45 PM |
| Rolling frame rail and bracket removal | mikeukrainetz | DIY / Maintenance / Service | 6 | 11-23-2006 01:28 PM |
