Old 12-08-2006, 12:24 PM   #1
mikeukrainetz
mikeukrainetz's Avatar
Drives: 2006 Toyota Yaris
Motor oil debate - interesting info but a long read.
Oil issues and the modifications to oil formulas il
There is a raging controversy on the recent modifications to oil formulations on almost all major oil companies products .
You'll find a lot about it on the MGCC UK site, look under TD/TF. It seems that at least in the USA, the oil companies have modified an old favorite ;Castrol 20W-50 by reducing the zinc compound. The zinc compound (ZDDP) protects rubbing surfaces like cams and lifters. This has been the subject of articles in the last 3 months of Skinned Knuckles magazine and numerous hot rod magazines.
The bottom line is that you must not try to break in newly rebuilt engines with these new oils, nor should you continue to run your old engines on the new formulation. .
Crane Cams has been very concerned about the new oil formulations ,and placed some information on their website ;
1. Lobe wear
2. Correct break-in lubricant.
"Use only the Moly Paste, Part Number 99002-1. It has the necessary zinc to help in Lobe wear ." That is what is included with the their cams. "This Moly Paste must be applied to every cam lobe surface, and to the bottom of every lifter face of all flat tappet cams."
Roller tappet cams only require engine oil to be applied to the lifters and cam." Also, apply the Moly Paste to the distributor gears on the cam and distributor for all camshafts."
For extra protection, Crane Cams recommends that an anti-wear additive ( with a significant amount of zinc ) be used . They recommend their Crane Super Lube, Part Number 99003-1.
OIL IS KILLING OUR OLD CARS
By: Keith Ansell, Foreign Parts Positively, Inc.
About a year ago I read about the reduction of zinc dithiophosphate (ZDDP) in the oils supplied with API approval that could affect sliding and high pressure (EP) friction in our cars. The reduction of these chemicals in supplied oil was based on the fact that zinc, manganese and/or phosphates reduce the effectiveness and eventually damage catalytic converters and introduce minute amounts of pollutants into our atmosphere.
A month or so ago I had a member of the Columbia Gorge MG Club bring a totally failed camshaft and lifters back to me that had only 900 miles on them!! I immediately contacted the camshaft re-grinder and asked how this could happen. They were well aware of this problem as they were starting to have many failures of this type. In the past, the lack of a molybdenum disulfide camshaft assembly lubricant, at assembly, was about the only thing that could create this type of problem. My customer has assembled many engines and had lubricated the camshaft properly and followed correct break in procedures.
This got me on the phone to Delta Camshaft, one of our major suppliers. Then the bad news came out: It’s today’s “modern” API (American Petroleum Industry) approved oils that are killing our engines.
Next call: To another major camshaft supplier, both stock and performance (Crane). They now have an additive for whatever oil you are using during break-in so that the camshaft and lifters won’t fail in an unreasonably short period of time. They also suggest using a diesel rated oil on flat tappet engines.
Next call: To a racing oil manufacturer that we use for the race cars (Redline). Their response: “We are well aware of the problem and we still use the correct amounts of those additives in our products”. They continued to tell me they are not producing API approved oils so they don’t have to test and comply. Their oils were NOT the “new, improved and approved” ones that destroy flat tappet engines! “We just build the best lubricants possible”. Sounds stupid, doesn't’t it, New-Approved but inferior products, but it seems to be true for our cars.
To top this off: Our representative from a major supplier of performance and street engine parts (EPWI) stopped by to “warn us” of the problem of the NEW oils on flat tappet engines. This was a call that the representative was making only because of this problem to warn their engine builders! “The reduction of the zinc, manganese and phosphates are causing very early destruction of cams and followers”. They are recommending that, for now at least, there must be a proper oil additive put in the first oil used on new engines, beyond the liberal use of molydisulfide assembly lube. They have been told that the first oil is the time the additives are needed but remain skeptical that the first change is all that is necessary. Their statement: Use diesel rated oils such as Delo or Rotella that are usually available at auto stores and gas stations.
This problem is BIG! American Engine Rebuilder's Association (AERA) Bulletin #TB2333 directly addresses this problem. I had a short discussion with their engineer and he agreed with all that I had been finding.
Next phone call was to a retired engineer from Clevite, a major bearing and component manufacturer. First surprise was that he restored older British Motor bikes. The second surprise was that he was “VERY” aware of this problem because many of the old bikes had rectangular tappets that couldn't’t rotate and are having a very large problem with the new oils. He has written an article for the British Bike community that verify all the “bad news” we have been finding.
Comp Cams put out “#225 Tech Bulletin: Flat Tappet Camshafts”. They have both an assembly lube and an oil additive. The telling sentence in the bulletin was “While this additive was originally developed specifically for break-in protection, subsequent testing has proven the durability benefits of its long term use. This special blend of additives promotes proper break-in and protects against premature cam and lifter failure by replacing some of the beneficial ingredients that the oil companies have been required to remove from the off the-shelf oil”.
Next question: Now what do we do?
From the camshaft re-grinders (DeltaCam) “Use oils rated for diesel use”, Delo (Standard Oil product) was named. About the same price as other quality petroleum based oils. They are not API formulated and have the zinc dithiophosphate we need in weights we are familiar with.
From the camshaft manufacturer (Crane): “use our additive” for at least the first 500 miles.
From General Motors (Chevrolet): add EOS, their oil fortifier, to your oil, it’s only about $12.00 for each oil change for an 8 ounce can (This problem seems to be something GM has known about for some time!).
From Redline Oil: Use our street formulated synthetics. They have what we need!
From our major oil distributor: Distributing Castro, Redline, Valvoline and Industrial oils: “After over a week of contacts we have verified that the major oil companies are aware of the problem”. “The representatives of the oil companies today are only aware of marketing programs and have no knowledge of formulation”. The only major oil companies they were aware of for doing anything to address this are Valvoline that is offering an “Off Road 20W-50” and Redline.
From Castrol: We are beginning to see a pattern emerging on older cars. It may be advantageous to use a non-approved lubricant, such as oils that are Diesel rated, 4 Cycle Motorcycle oils and other specified diesel oils.
Last question: So what are we at Foreign Parts Positively going to do? After much research we are switching to Redline Street rated oils and stocking the Castrol products that are diesel rated. Castrol, owned by British Petroleum, is now just a brand name. This is a difficult decision as we have been a dealer and great believer in all Castrol Products for over 40 years. We have been using Castrol Syntech oil in new engines for about 3 years so the cost difference in changing to Redline is minimal. The actual cost in operation is also less as the additive package in Redline makes a 1-year or up to 18,000 mile change recommended! Yes, it is a long change interval but with lowered sulfur levels and the elimination of lead and many other chemicals in the fuels there are less contaminants in our oil from the fuel, which is the major contributor to oil degradation. We will continue to offer the Castrol products but will now only stock the suggested diesel oils that they produce.
Too many things are starting to show up on this subject and it has cost us money and time. Be aware that “New and Improved”, or even products we have been using for many years, are destroying our cars as it isn’t the same stuff we were getting even a year ago.
For the cars that use “engine oil” in their gearboxes this may even pose a problem as these additives that have been removed could be very critical in gear wear. We will be using oil specifically formulated for Manual Gearboxes with Brass Synchronizers. The only oils we are aware of that fit the criteria are from General Motors and Redline.
If you have any additional input let us know. We need to let every flat tappet engine owner, i.e.: every British Car owner know that things are changing and we MUST meet the challenge.
Keith Ansell, President
www.ForeignPartsPositively.com
360-882-3596
Larry Ayres, California I was looking for one of the above mentioned additives to use with the castrol 20-50 now in my car, and couldn't find them. I did find that good old STP has zinc (ZDDP) in it though, and remembered that my old British car mechanic in the 60's swore by the stuff. So I got some and put it in. Today, I noticed quite an improvement. The engine was quieter on startup (that 2-3 seconds when the valve train is noisy until the oil pressure is up), and seems much quieter overall. The STP bottle specifically mentions cushioning hard metal parts. I plan to switch to redline non racing 10-40 oil, next oil change. You should read about the oils on their site before selecting one. They are very specific about the applicability of the various oils. regards, Larry
gblawson - TD#27667, Ontario, Pennzoil/Shell reply: They/he managed to side step the 'older' engines... Thank you for your inquiry. Pennzoil has marketed, for a number of years, a "Pennzoil Racing Motor Oil" that would be suitable to use in older vehicles or high performance engines that incorporate high lift cams with high tension valve springs. The Pennzoil Racing Motor Oil is available in the SAE 25W-50, 50, and 60 weight. The product part number is 3623, 3589, and 3599 respectively. Given the part number, any retail outlet that carries Pennzoil products, can obtain this oil. This formulation contains nearly three times as much zinc as most commercially available API "SM" motor oils in the market. I would recommend using this formulation, for truly high performance engines, over the heavy -duty diesel engine oils because this oil has approximately 50% more zinc than most API "CI-4" quality diesel engine oils. Best Regards, Technical Service
VALVOLINE VR1 RACING OIL and ZINC
It appears that Valvoline makes two types of racing oil: the stuff in the gray bottle (VR1) and the stuff in the black bottle (available in conventional and synthetic). Both contain zinc.
On the back of the VR1 bottle it states: "For use in high performance passenger cars and race cars" and "API Service SM." The fact that it mentions passenger cars would suggest its ok to use in our cars. No where on the bottle, however, does it say anything about detergents. We need to call their 800 number (1-800-TEAM VAL) and ask about detergents, or lack thereof, in VR1.
By comparison, the stuff in the black bottle (they don't give it a catchy name like VR1) has " increased amounts of zinc for extra engine protection" "
Here is the link to the Valvoline web page that lists their motor oil products. Scroll down the page until you see the Racing Motor Oil section.
http://www.valvoline.com/pages/produ...gory.asp?cid=9
VALVOLINE TECH LINE
I called the tech help line at Valvoline with questions on the zinc in the Valvoline products
The Tech said their VR1 Racing oil is fully API rated and contains the detergents needed to keep the engine clean, plus it contains zinc
They said that their regular oils still contain some zinc, albeit a bit lower amount (.08) than before, They said their VR1 has a bit more zinc (.12) than the regular oils and the "racing only" oils in the black bottle, more still. He said the VR1 was not necessary for older engines but it certainly would not hurt.
That's what I think I will put into my MG TC .John
Carl Floyd, Tennessee, USA, cmfloyd@yahoo.com For the U.S., market looks like Valvoline Racing VR1 20W-50 will do nicely. It is API SM/SL/SJ approved so it is for street & track. At $5 a quart, it a bit pricey. Another choice, not usually suitable for our old cars, are the synthetics like Amsoil, Redline, Royal Purple, & Mobil 1. I found out that Castrol Syntec is NOT a true synthetic motor oil. Only the Castrol SLX 0W-30 made in Germany is. So, I'm looking at an additive instead. GM EOS, Valvoline Synpower Oil Treatment, and SX-UP (by Specialty Formulations) have been recommended. Here's an oil analysis for the SX-Up: We had a request to see the elemental analysis for SX-UP from Specialty Formulations. The elements reported are averaged over 5 different lab reports and rounded. Please recognize that there is more to SX-UP than just these elements. As per our PDS, we also use many ashless organic compounds (not shown on elemental analysis, of course) and agents such as rust inhibitors, Friction Modifiers, Anti-Oxidants, viscosity index improvers, surfactants, metal deactivators for copper (copper corrosion inhibitors), detergents, dispersants, etc. The base oils are PAO's and esters ("Quad-Esters"). Anything less than 10 ppm was ignored. Molybdenum - 1400 ppm (Friction Reduction, AW, AO) Boron - 500 ppm (AW, FM) Tin - 12 (AW) Phosphorus - 1500 (AW) Zinc - 2900 (AW) Calcium - 4200 (Detergent, AW, FM) Magnesium - 250 (Detergent) TBN 19.3 KV @100 C - 16.5 This product was originally developed for engine oils in muscle and classic cars from approx. 1955 to about 1980 in order to boost the additive levels of current SF/SH oils to approx. API SD equivalent AW status. The original SD oils had ZDDP levels approximately equivalent to today's HDEO oils. The SX-UP seems to be the superior additive. It is recommended for gasoline and diesel engines using SAE 10 to 40 weight oils at the rate of 1 pint for every 4 to 5 quarts of oil at oil change. It cost $13-14 a pint. I think either Castrol or Valvoline 10W-40 plus a pint of SX-UP would get it done. I did find that though both companies have reduced the ZDDP levels, Valvoline retained a smidge more than Castrol. Also, the European market has motor oils with higher levels of ZDDP than is available here in the U.S. I found an interesting forum full of gear heads that are quite anal about their oil and have it analyzed regularly:
Carl Floyd, Tennessee, USA, Update. The price I quoted for the Valvoline Racing VR1 20W50 was an internet price from Jeg's (surprised they are that high). I just called around. It's $3.28 at Advance & $2.79 at Autozone. That is cheaper than adding additives. I'm off to AutoZone. My MGs & '68 Camaro (with a very big cam) will be using the Valvoline Racing VR1 20W50
mikeukrainetz is offline   Reply With Quote
Old 12-08-2006, 01:28 PM   #2
acrbill
Drives: Polar White Hatch
what does that have to do with the Yaris?
http://home.comcast.net/~job0b/ywsig.gif
ChinoCharles Intake supporter.
acrbill is offline   Reply With Quote
Old 12-08-2006, 03:48 PM   #3
mikeukrainetz
nothing specific to the yaris, the questions been bounced around about what oil is best, when to switch, which would be detrimental to engine break-in etc etc.
Old 12-08-2006, 04:11 PM   #4
acrbill
I would say a synthetic oil would be best. But the question is whether or not the Yaris would benefit from it. I had a high output turbo motor that I used synthetic on because of the extremes the engine went through. Its more stable at high temps and whatnot.
If you have ever seen the innards of an engine that used synthetic you would see that it actually impregnates the metal so that you will see the staining . Its pretty cool stuff.
I would think that a Yaris that is driven in a way it was designed for would never actually need the benefits that synthetic gives. Meaning, by the time the engine is worn out (using regular oil) the car would have soo many miles that the chassis would be worn.
I think that article pertains to older type and racing motors that have no direct connection to new/oem built motors.
Its an interesting article none the less.
Old 12-08-2006, 08:46 PM   #5
60 Somethings
Old Folks
60 Somethings's Avatar
Drives: 2007 Yaris LB, 2006 4Runner V8
Would tend to agree with the above.
We are the proud owners YARI -
He's a loaded Silver LB with ATTITUDE!
60 Somethings is offline   Reply With Quote
Old 12-09-2006, 02:24 AM   #6
07WYarisRS
HardlyDangerous
07WYarisRS's Avatar
Drives: 09 Yaris LE, H/B, auto
Reagrdless what type of engine or what the use. reduce heat and friction you gain MPG and perofmance. And over time you reduce wear so you maintain that performance longer. Yeah it's more important for a race engine to maintain PEAK power because a 5-10hp loss on a long race can cost you a win. BUT the wear that causes a 10hp loss over a couple years of regular driving on the street will cost you a lot of $$$ in extra fuel and oil.
Any engine will benifit from a better lubricant.
I run my cars for 300,000 k to 500,000 km and don't want to have to deal with a gutless oil burner.
I just recently tore down the engine from my Laser while parting it out and after 300,000km the cross hatch is still visable on the cylinder and still well within' specs, no carbon deposits etc. The engine is flawless, never used a drop of oil and still had compression levels within' 5psi of stock. Too bad the rest of the car fell apart. This engine could have easily gone another 300,000km and not shown any signs of wear.
The early bird gets the worm, but the second mouse gets the cheese.
07WYarisRS is offline   Reply With Quote
Old 12-10-2006, 08:16 PM   #7
Don Mason
Drives: Yaris
Flat Tappet Cams
Much of this information is concerning premature wear in flat tappet engine designs utilizing push rods and rocker arms for valve actuation, primarily cam lobes and the followers (lifters).
Most modern engines are not of this type. In most, an overhead camshaft design is used. The design has far less valve train inertia and mass, so valve springs need far less tension to prevent valve float at high RPM's. The other added benefit is less power required to run the valve train, yielding more miles per gallon.
I wouldn't worry too much about the valve train in the Yaris, when using modern lubricants.
Don Mason is offline   Reply With Quote
VANCOUVER - MEET - READ THIS THREAD FOR INFO. AND FEEDBACK bigsky2 Canada 94 01-29-2007 02:42 AM
Interesting Info on the Yaris from AU mikeukrainetz General Yaris / Vitz Discussion 3 11-24-2006 09:18 PM
